Forum Topic - Send Raw ethernet packet using bpf: (13 Items)
Hi
I use BPF to send raw Ethernet packet, but packets never arrive when sending packet without the TCP/IP header.
In my code I try to send to packets. A packet with a EtherCAT type where the first 12 bytes is the source and
destination. And after this the type and the data.
The other packet I send is a ping packet.
Before running the program I started tcpdump with
tcpdump -iwm0 -XX
to catch the packets on the target PC.
And connected to the network card wm0 there is connected a computer with wireshark.
When run the program I see both packet in the terminal running tcpdump, but in wireshark i only see the ping packet.
So I wondering where my packet is blocked or stalled?
Is it in the bpf because it dont allow packet without tcpip header. Or is it something in the io-pkt there blocking for
non tcp packet?
/Lasse
Attachment: Text DemoApp.cc 11.38 KB
Re: Send Raw ethernet packet using bpf
I found something  about loading a filterprogram to the BPF device by using, BIOCSETF.
But the packet with another ethernet type is not send out on the ethernet card.
I attached the code with small differences to this post.
/Lasse
Attachment: Text DemoApp.cc 11.98 KB
RE: Send Raw ethernet packet using bpf
Just to confirm, if you DON'T add the filter, does the packet get sent
out?
Also, does the filter work in terms of the packets being received?
As a side note, one thing you might want to examine with this sort of
implementation is the real-time performance of the packet reception.
The stack hasn't been designed for highly-deterministic response to
packet reception / transmission through the socket resource manager
interface (representative of BPF) so there can be a significant amount
of jitter (especially under load) for packets being received by your
application.  I understand that EtherCAT is "real-time", so you might
want to ensure that the performance is "good enough" for this.  You also
have the possibility of using the lsm-nraw resource manager interface
which we've recently added to the repository (this provides the same
sort of interface that the nfm-nraw interface did in io-net).
	Robert.
From: Lasse Skov [mailto:community-noreply@qnx.com]
Sent: Monday, February 23, 2009 10:40 AM
To: general-networking
Subject: Re: Send Raw ethernet packet using bpf
using, BIOCSETF.
ethernet card.
/Lasse
General
http://community.qnx.com/sf/go/post22738
Re: RE: Send Raw ethernet packet using bpf
I tried to run a program without the filter. But no packet is send out on the ethernet port except the TCP packet.
If i run a program there looks like DemoApp but instead of write to the bpf0 i read from it i catch both packets.
And it is the same with tcpdump.
Actual a filter is not necessary because the netcard is only used to ethercat communication.
Actually i don't understand, when the filter program is loaded, and if there is a way to see witch filter program is
started? Or is it not possible.
And when adding a filterprogram to a bpf device is this overwrite the existing program on the bpf?
Maybe the lsm-nraw is a better way to communicate.
How is this connected to the io-pkt and how is the stack implemented to this?
/Lasse
RE: RE: Send Raw ethernet packet using bpf
Here's an example of how to create and send / receive ICMP ping packets.
Compile it
cc -lsocket -oicmp icmp.c
Run it:
./icmp interface src-mac src-ip dst-mac dst-ip.
There are obviously ways to snarf out the relevant source information so
that you don't have to add them on the command line, but I took the path
of least resistance with some example code that we had lying around for
io-net.
lsm-nraw hooks into the stack using the packet filter interface.  See
http://community.qnx.com/sf/wiki/do/viewPage/projects.networking/wiki/Fi
ltering_wiki_page
	Robert.
Sent: Tuesday, February 24, 2009 1:24 PM
Subject: Re: RE: Send Raw ethernet packet using bpf
there is a way to see witch filter program is started? Or is it not
possible.
this?
/Lasse
General
http://community.qnx.com/sf/go/post22847
Attachment: Text icmp.c 5.76 KB
Re: RE: RE: Send Raw ethernet packet using bpf
This is working and it's possible to send a lot of data.
Now im woundering how it is possible to let io-pkt create a bpf more.
So i have two bpf one named
/dev/bpf0
/dev/bpf1
So i can setup multiple filter on those two devices bound to the same network adapter.
/Lasse
Hi Robert Craig,
I am also trying to send/receive raw packets using BPF. I am using QNX 6.3.2. On QNX 6.3.2 BPF was not there.
I mounted nfm-bpf.so using “mount –T io-net nfm-bpf.so” command.
On mounting “en-en0” was created in /dev/io-net. And also bpf is available in /dev/socket in QNX 6.3.2.
I did a sample program to open bpf . It was successful.
When i am running using "./icmp interface src-mac src-ip dst-mac dst-ip"
its saying
icmp: write: Function not implemented.
I am new to QNX and BPF. No idea about the error.
May i know why I am facing this error. Thanks in advance.
bpf wasn't officially supported in 6.3.2.  It was read only.
I suggest going to 6.5 is possible.
On Thu, Jul 21, 2011 at 12:07:54PM -0400, Nagarjuna b wrote:
> Hi Robert Craig,
> I mounted nfm-bpf.so using ???mount ???T io-net nfm-bpf.so??? command.
> On mounting ???en-en0??? was created in /dev/io-net. And also bpf is available in /dev/socket in QNX 6.3.2.
> its saying
> http://community.qnx.com/sf/go/post87502
hi Sean Boudreau,
Thankyou for quick reply. Don't we have any option to implement in QNX 6.3.2 ?
As of now there is no scope for me to upgrading to higher version of QNX .
Also please let me know why am i getting that error?
"write:function not implemenmted"
BPF was read only in 6.3.2.  Write wasn't implemented.
----- Original Message -----
From: Nagarjuna b [mailto:community-noreply@qnx.com]
Sent: Thursday, July 21, 2011 12:17 PM
To: general-networking <post87505@community.qnx.com>
Subject: Re: RE: RE: Send Raw ethernet packet using bpf
hi Sean Boudreau,
General
http://community.qnx.com/sf/go/post87505
Sean Boudreau
Thankyou very much for your reply :)
Hi Sean Boudreau,
We have mounted nfm-bpf.so and nfm-nraw.so in QNX 6.3.2
I have learned bpf can be used to receive and nraw to send raw packets in QNX6.3.2.
We are successful in testing receive function.
How can we use nraw to send raw packets?
Can I get any documents or sample code to send raw packets using "nraw"?
Please help.
Sorry!! The previous post was not complete. I Tried the code posted above  (icmp.c)
Compilation was success. When i run it says write: function not implemented.
Please help.
