Sean Boudreau(deleted)
Re: Running Multiple TCP/IP stacks
12/16/2008 9:49 AM
post18703
On Tue, Dec 16, 2008 at 05:16:53AM -0500, RAHUL SABLE wrote:
> Hi all,
> I am running multiple tcp/ip stack with command
> io-net -i1 -del900 pci=0x1 -ptcpip prefix=/sock2
> then i am setting SOCK environment varable in my server application as /sock2.I am doing the same thing in client
application.I am able to receive the data in same node or machine on tcp/ip stack with prefix sock2.
> But i am facing problem when i am running the client application on remote node and trying to receive the data.I tried
to receive the data without setting the SOCK environ variable on default tcp/ip stack and also tried by running another
tcp/ip stack with same command and setting the SOCK environ variable in client application then also i am not able to
receive.Is it possibe to do like this or there is any other way to do this.
> I did not understand how this tcp/ip stack with prefix sock2 connects to remote node tcp/ip stack (either default or
tcp/ip stack with prefix sock2).Please let me know the solution i am new to tcp/ip.
The SOCK environmental variable only controls which stack
gets the initial socket() call. After that normal ip
routing is involved: you need an addr at each end, a route
to each dest, connect() bind() accept().
