A Gagne(deleted)
11/20/2008 4:15 PM
post17008
I am trying to use BPF to read and write raw packets to the network using io-pkt in QNX 6.4.0. The program I wrote
appeared to work fine, but would hang whenever anything else tried to communicate with the board where it was running.
In an attempt to track down the problem, I created a separate test program that simply opens BPF, binds it to the
network adapter, and reads packets from it. Even this test program hangs under the same conditions.
I can connect to and communicate with the device with an ftp or telnet client, without any issues, as long as the test
program is not running. The test program runs fine as long as nothing else is talking directly to the device, like an
ftp or telnet client. If the program is running and I try to connect to the device with anything else that uses the
network, such as an ftp client or a telnet client, io-pkt hangs.
364560 1 /boot/io-pkt-v6-hc 21r SIGWAITINFO
364560 2 /boot/io-pkt-v6-hc 21r MUTEX (0x481732c0) 364560-02 #0
364560 3 /boot/io-pkt-v6-hc 21r RECEIVE 16
364560 4 /boot/io-pkt-v6-hc 21r RECEIVE 20
I tried it with both io-pkt-v4-hc and io-pkt-v6-hc with the same results. Attached are the test program, the pidin
results after a failure, and the output of the program to the point of failure.
Any insight is greatly appreciated.
A G
