Mark Dowdy
Activating a '2nd' Network Adapter
Mark Dowdy
09/04/2008 9:58 PM
post12895
Our system, running 6.3.0 SP2, has a hard-wired Intel 82546GB dual-port
network adapter. Our application requires the addition of a third
ethernet interface so I added an Intel Pro/1000 GT adapter board. The
Pro/1000 has an Intel 82541PI. The pci command lists the newly added
device (see below, the PCI ID is 0x107c) but io-net doesn't find it
(i.e. /dev/io-net only contains two en's 0 and 1). Not surprisingly,
ifconfig doesn't know about the new adapter either. PCI device ID 0x107c
is in the Intel network adapter section of /etc/system/enum/devices/net
file (I applied patch 214). Any ideas why the ethernet interface on the
new adapter isn't starting? Thanks.
# pci
PCI version = 2.10
Class = Mass Storage (IDE)
Vendor ID = 8086h, Intel Corporation
Device ID = 24d1h, Unknown Unknown
PCI index = 0h
PCI IO Address = 0h enabled
PCI IO Address = 14b0h enabled
PCI Int Pin = INT A
Interrupt line = no connection
Class = Network (Ethernet)
Device ID = 1079h, Unknown Unknown
PCI index = 0h
PCI Mem Address = dd200000h enabled
PCI IO Address = 2000h enabled
PCI Int Pin = INT A
Interrupt line = 10
CPU Interrupt = ah
PCI index = 1h
PCI Mem Address = dd220000h enabled
PCI IO Address = 2040h enabled
PCI Int Pin = INT B
Interrupt line = 11
CPU Interrupt = bh
Device ID = 107ch, Unknown Unknown
PCI index = 0h
PCI Mem Address = dd320000h enabled
PCI Mem Address = dd300000h enabled
PCI IO Address = 3000h enabled
PCI Int Pin = INT A
Interrupt line = 10
CPU Interrupt = ah
Class = Display (VGA)
Vendor ID = 1002h, ATI Technologies
Device ID = 4752h, Rage XL PCI
PCI index = 0h
PCI Mem Address = de000000h enabled
PCI IO Address = 4000h disabled
PCI Mem Address = dd400000h enabled
PCI Int Pin = INT A
Interrupt line = 10
CPU Interrupt = ah
# ls /dev/io-net
en0 en1 ip0 ip_en
