Sean Boudreau
Re: How to open socket from command line?
Sean Boudreau
07/03/2008 8:41 AM
post10005
On Thu, Jul 03, 2008 at 07:55:29AM -0400, bob lipka wrote:
> My program talks with remote server thru /dev/ser[number here]. Communication path is given as a parameter. Now I want
to change serial for client socket.
> How can I open client socket outside my program and have some path (presumably /dev/socket/...) ready to give to my
program as a communication stream?
You can't just call open() as about the only thing you'll be
able to do with the fd is fstat() since there's no way to
pass _FTYPE_SOCKET to open(). You'll need to call socket().
Robert Craig
RE: How to open socket from command line?
Robert Craig
07/03/2008 10:36 AM
post10021
Socket communications are handled through the standard BSD style socket
API which is different from direct communications through a serial
driver. I'd recommend reading up a bit on basic socket operations.
This code has to be implemented as part of your application.
(For example, take a look at
http://en.wikipedia.org/wiki/Berkeley_sockets)
Robert.
P.S. you got post 10000. That's a milestone of some sort :>.
Sent: Thursday, July 03, 2008 7:55 AM
To: general-networking
Subject: How to open socket from command line?
Communication path is given as a parameter. Now I want to change serial
for client socket.
(presumably /dev/socket/...) ready to give to my program as a
RobertL
General
http://community.qnx.com/sf/go/post10000
