Forum Topic - problem with intel 82576 and e1000 driver: (11 Items)
I just installed 6.4.1 on a Xeon system with dual 82576 Gb ethernet controllers. The e1000 driver loaded fine that gave
me wm0 and wm1 devices. However networking doesn't work (plugged in our network, DHCP failed).
I then connected the system directly to a working laptop, and  here are the ping behaviors:
if I initiate ping from the laptop, nicinfo shows all packets and bytes received OK, but no increment on Tx packets and
bytes.
if I initiate ping from the system, nicinfo shows all packets and bytes transmitted OK, with some increment on the Rx
packets and bytes but less than the number transmitted.
greatly appreciate any input on this.
ZY
RE: problem with intel 82576 and e1000 driver
It sounds to me as though interrupts are not working. Please can you
post the output from 'pci -v' on the system. Also, please check the BIOS
to see if there is an option to turn off Plug 'n Play.
Thanks, Hugh.
From: Zhiyuan Ren [mailto:community-noreply@qnx.com]
Sent: Wednesday, September 02, 2009 11:42 AM
To: drivers-networking
Subject: problem with intel 82576 and e1000 driver
controllers. The e1000 driver loaded fine that gave me wm0 and wm1
failed).
the ping behaviors:
received OK, but no increment on Tx packets and bytes.
transmitted OK, with some increment on the Rx packets and bytes but less
ZY
Networking Drivers
http://community.qnx.com/sf/go/post37174
Re: RE: problem with intel 82576 and e1000 driver
Thanks for the reply. Yes, the PnP OS was disabled in the BIOS. Attached is the output of pci -v
ZY
Attachment: Text pci-v.out 39 KB
RE: RE: problem with intel 82576 and e1000 driver
The pci output looks fine. Have you tried starting the network driver
with different interrupts?
Eg. io-pkt-v4 -de1000 irq=11,pci=0
Try various interrupts in the "irq=.." command line argument and see if
any of them work, This will start a driver on only the first interface.
If you want to try the second interface use "pci=1".
You might also try slaying io-usb and see if that makes any difference.
Sent: Wednesday, September 02, 2009 12:31 PM
Subject: Re: RE: problem with intel 82576 and e1000 driver
ZY
Networking Drivers
http://community.qnx.com/sf/go/post37194
Re: RE: RE: problem with intel 82576 and e1000 driver
I tried to load the driver with various irq settings, and it didn't work (failed to give me wm0/wm1 devices). I won't be
 able to slay io-usb since i need the keyboard, there is no network so i won't be able telnet. I guess i can try the
serial terminal...
ZY
RE: RE: RE: problem with intel 82576 and e1000 driver
Does Windows or any other O/S run on this machine? If so, can you see
what interrupts are being used for the Ethernet adapters.
Sent: Wednesday, September 02, 2009 3:01 PM
Subject: Re: RE: RE: problem with intel 82576 and e1000 driver
(failed to give me wm0/wm1 devices). I won't be able to slay io-usb
telnet. I guess i can try the serial terminal...
ZY
Networking Drivers
http://community.qnx.com/sf/go/post37223
Re: RE: RE: RE: problem with intel 82576 and e1000 driver
i just installed Suse Linux enterprise server 10 SP2 on another partition. The driver coming with the installtion didn't
 work either, I had download the new intel igb src for 82576 and make install to make the network finally work. Here is
the info in dmesg, so it's using the message interrupt that QNX doesn't support yet
igb: eth0: igb_probe: Intel(R) Gigabit Ethernet Network Connection
igb: eth0: igb_probe: (PCIe:2.5Gb/s:Width x4) 00:30:48:ca:ba:02
igb: eth0: igb_probe: Using MSI-X interrupts. 1 rx queue(s), 1 tx queue(s)
ACPI: PCI Interrupt 0000:0a:00.1[B] -> GSI 17 (level, low) -> IRQ 169
PCI: Setting latency timer of device 0000:0a:00.1 to 64
igb: eth1: igb_probe: Intel(R) Gigabit Ethernet Network Connection
igb: eth1: igb_probe: (PCIe:2.5Gb/s:Width x4) 00:30:48:ca:ba:03
igb: eth1: igb_probe: Using MSI-X interrupts. 1 rx queue(s), 1 tx queue(s)
GSI 19 sharing vector 0x6A and IRQ 19
ACPI: PCI Interrupt 0000:00:1a.7[C] -> GSI 18 (level, low) -> IRQ 106
PCI: Setting latency timer of device 0000:00:1a.7 to 64
ZY
RE: RE: RE: RE: problem with intel 82576 and e1000 driver
We will be supporting MSI in a future release.
Sent: Thursday, September 03, 2009 5:50 PM
Subject: Re: RE: RE: RE: problem with intel 82576 and e1000 driver
partition. The driver coming with the installtion didn't work either, I
the network finally work. Here is the info in dmesg, so it's using the
queue(s)
queue(s)
ZY
Networking Drivers
http://community.qnx.com/sf/go/post37337
Re: RE: RE: RE: RE: problem with intel 82576 and e1000 driver
now it's 2010, do you have an ETA for the mentioned release?
RE: RE: RE: RE: RE: problem with intel 82576 and e1000 driver
Sometime in the next few months. I can't give you an exact date.
Sent: Tuesday, January 12, 2010 11:11 AM
Subject: Re: RE: RE: RE: RE: problem with intel 82576 and e1000 driver
Networking Drivers
http://community.qnx.com/sf/go/post45059
Re: problem with intel 82576 and e1000 driver
I think this has something to do with the incorrect (redirection table) settings of the IOAPIC in my 5520 northbridge.
Interrupts from a PCI-X to PCIe bridge connecting to that northbridge is not being forwarded to the CPU either. So far
only the interrupts from the ICH10 southbridge are being served.
Zhiyuan
