Forum Topic - 6.3.2 io-net cores: (5 Items)
6.3.2 io-net cores
Hi:
Every now and then we get instances of io-net coreing. Running it through gdb gives the following information:
Program terminated with signal 4, Illegal instruction.
#0  0xfe39bffc in arpintr1 ()
   from /opt/qnx632/target/qnx6/ppcbe/lib/dll/npm-tcpip-v4.so
Anyone know if this is a 'known' issue.
thanks
robert
RE: 6.3.2 io-net cores
A new one on me.
I would disassemble the code around 0xfe39bffc to see
if it looks sensible.  While you're at it, print a
screen dump of it and compare it to a disassembly
of what it npm-tcpip-v4.so should be ie before the dump.
If you're getting corrupted memory, that's an
interesting problem.  Often on some boards it
goes away when you disable the highest-level
cache (L3 or L2).
aboyd
Andrew:
I tried your suggestion and from the gdb session on the corefile tried
to disassemble around the offending address but get the following:
(gdb) disassem  0xfe39bffc
Dump of assembler code for function arpintr1:
0xfe39bf74 <arpintr1+0>:        Cannot access memory at address
0xfe39bf74
Fine. Continuing on, I did an objdump -d on the executable but I end up
with a dump of the entire .text section list with no function names (I
guess 'cause it was stripped). Also the memory addresses are offsets,
any idea of how to determine the actual load address of the library?
thanks
From: Andrew Boyd [mailto:community-noreply@qnx.com]
Sent: Monday, August 10, 2009 2:47 PM
To: drivers-networking
Subject: RE: 6.3.2 io-net cores
A new one on me.
cache (L3 or L2).
aboyd
Networking Drivers
http://community.qnx.com/sf/go/post35605
> Cannot access memory at address 0xfe39bf74
Argh.  Sometimes it can be hard to tell exactly
what's going on with the tools - sometimes dumper
and gdb don't always do the right thing, and our
long-suffering tools people - who pretty much run
away when they see me now - have fixed a lot of stuff
like this, esp for non-x86 cpus.
Anyways, if it didn't capture the offending
memory, I'm not sure what you can do.  Is it
possible the core is getting truncated somehow
by dumper?  I think it has a command line option
to do that, which you don't want.  Also, you can
sometimes be limited by memory available for
/dev/shmem if that's where the core is going.
aboyd
> Sent: Monday, August 10, 2009 3:44 PM
Try dressing up as a green girl.  That could change their minds.
> aboyd
> Networking Drivers
> http://community.qnx.com/sf/go/post35622
