Forum Topic - Reg - MII Compilation: (9 Items)
Hi ,
I Wrote a sample MII interface driver,for that i refered exPhy.c.
After written i tried to compile that file it throws an error.
i got error from system files.
I have included my files also.
please find the below error:
In file included from sam_mii.h:20,
                 from sam_mii.c:7:
/usr/qnx640/target/qnx6/usr/include/sys/device.h:97:23: error: sys/evcnt.h: No such file or directory
/usr/qnx640/target/qnx6/usr/include/sys/device.h:100:23: error: sys/systm.h: No such file or directory
                 from sam_mii.c:7:
/usr/qnx640/target/qnx6/usr/include/sys/device.h:154: error: field 'dv_callback' has incomplete type
In file included from sam_mii.h:24,
                 from sam_mii.c:7:
/usr/qnx640/target/qnx6/usr/include/dev/mii/miivar.h:82: error: field 'mii_media' has incomplete type
/usr/qnx640/target/qnx6/usr/include/dev/mii/miivar.h:137: error: expected specifier-qualifier-list before 'u_int32_t'
/usr/qnx640/target/qnx6/usr/include/dev/mii/miivar.h:204: error: expected specifier-qualifier-list before 'u_int32_t'
sam_mii.c:10: error: 'samPHY' undeclared here (not in a function)
sam_mii.c:10: error: initializer element is not constant
sam_mii.c:10: error: (near initialization for 'samPHY_ca.ca_name')
sam_mii.c:10: error: 'mii_phy_detach' undeclared here (not in a function)
sam_mii.c:10: error: 'mii_phy_activate' undeclared here (not in a function)
sam_mii.c: In function 'samphy_attach':
sam_mii.c:99: error: 'struct mii_softc' has no member named 'mii_inst'
sam_mii.c:100: error: 'struct mii_softc' has no member named 'mii_phy'
sam_mii.c:101: error: 'struct mii_softc' has no member named 'mii_funcs'
sam_mii.c:102: error: 'struct mii_softc' has no member named 'mii_pdata'
sam_mii.c:103: error: 'struct mii_softc' has no member named 'mii_flags'
sam_mii.c:104: error: 'struct mii_softc' has no member named 'mii_anegticks'
sam_mii.c:119: error: 'struct mii_softc' has no member named 'mii_flags'
sam_mii.c:123: error: 'struct mii_softc' has no member named 'mii_capabilities'
sam_mii.c:126: error: 'struct mii_softc' has no member named 'mii_capabilities'
cc: /usr/qnx640/host/qnx6/x86/usr/lib/gcc/i386-pc-nto-qnx6.4.0/4.2.4/cc1 error 1
Thanks and Regards
K.Senthil
Attachment: Text sam_mii.h 11.33 KB
Re: Reg - MII Compilation
On Mon, Aug 10, 2009 at 09:25:07AM -0400, Senthil K wrote:
> Hi ,
Check out the -I option to qcc.  It's probably
easiest to base your Makefile off an existing
one.
Hi Sean,
i gave the below command
 qcc -o mii -I /usr/qnx640/target/qnx6/usr/include/ sam_mii.c
The same error i faced .
Can you please tell me how other phy interface driver like exphy.c ikphy.c compiling.
is there any make file ,please tell me.
Thanks and Regards
K.Senthil
On Mon, Aug 10, 2009 at 09:37:06AM -0400, Senthil K wrote:
> Hi Sean,
You get /usr/qnx640/target/qnx6/usr/include/ by default.  The
files in question aren't there, they're in the networking repo.
They compile with a straight 'make' if you check out the
entire networking repo and compile as described here:
http://community.qnx.com/sf/wiki/do/viewPage/projects.networking/wiki/Source_Guide
The required makefiles and environment are already
supplied in the networking repo.
Hi Sean,
Shall i put my sam_mii.c file in directory where other mii driver resides example exphy.c,ikphy.c.
Then i follow the compilation procedure.
is that correct?
Thanks and Regards
K.Senthil
Hi Sean,
I have followed steps which given in the link.
but i tried to compile,following are the logs.
Steps are done in my Pc.
# cd $QNX_TARGET/../..
# ls
.                              host                           srcversion-patch-6.4.0.tar
..                             install                        target
# tar -xpf srcversion-patch-6.4.0.tar
# make CPULIST="x86" install
make: Nothing to be done for `install'.
# make CPULIST=x86 install
# make install
Any thing i missed please guide me.
Thanks and Regards
K.Senthil
On Mon, Aug 10, 2009 at 10:29:40AM -0400, Senthil K wrote:
> Hi Sean,
> # ls
> ..                             install                        target
> # make install
There's no Makefile there.  You have to 'make'
where you've checked out the networking repo.
Hi Sean,
I refered one make file and compiled my code successfully and i got .so
while i mount
using
# mount -T io-pkt /lib/dll/devnp-MPC.so
mount: Can't mount / (type io-pkt)
mount: Possible reason: No such device or address.
Sloginfo
Aug 11 18:08:13    2    14     0 Unable to load /lib/dll/devnp-MPC.so: Symbol not found
it throws symbol not found.
How can i see whcih symbol is not found.
Regards
Senthil
Hi Sean,
one more question,
I have compiled the entire QNX core networking code.
But i found that, there is deirectory in /sys/dev/mii
there is no make file in that directory.
But in that directory there are lot of files how those files are getting compiled.
Thanks and Regards
K.Senthil
