Forum Topic - QNX does not detect the third network card: Page 1 of 2 (30 Items)
Hi all,
I added a new network card which is "Intel  	82572EI_COPPER  	0x107D  	devnp-e1000.so  	 ARM, MIPS, PPC, SH4, X86
driver support for Intel gigabit " to my target PC (x86) which has already one built in network card and one intel PRO
1000 GT network card.
Unfortunately QNX does not detect the new network card and I see just two devices in TCP/IP configuration. what should I
 do to solve this problem?
Mohammad
RE: QNX does not detect the third network card
What version of the O/S are you running? The devnp-* drivers only work
with io-pkt.
From: Mohammad Dadashzadeh [mailto:community-noreply@qnx.com]
Sent: Friday, August 07, 2009 10:49 AM
To: drivers-networking
Subject: QNX does not detect the third network card
Hi all,
already one built in network card and one intel PRO 1000 GT network
card.
two devices in TCP/IP configuration. what should I do to solve this
problem?
Mohammad
Networking Drivers
http://community.qnx.com/sf/go/post35468
Re: RE: QNX does not detect the third network card
QNX 6.4.1 and io-pkt-v4-hc
RE: RE: QNX does not detect the third network card
If you do the following, does the driver work?
slay io-pkt-v4-hc
io-pkt-v4-hc -de1000
nicinfo
Does nicinfo show a device or are there any error messages when you
start io-pkt?
Sent: Friday, August 07, 2009 10:57 AM
Subject: Re: RE: QNX does not detect the third network card
Networking Drivers
http://community.qnx.com/sf/go/post35471
Re: RE: RE: QNX does not detect the third network card
I did it, no error. but it does not recognize any network card anymore.
Mohammad
RE: RE: RE: QNX does not detect the third network card
Please do the following:
sloginfo -c
slay io-pkt-v4-hc
io-pkt-v4-hc -de1000 verbose
Please can you post the output from 'pci -v' as well as the output from
'sloginfo'.
Sent: Friday, August 07, 2009 11:08 AM
Subject: Re: RE: RE: QNX does not detect the third network card
Mohammad
Networking Drivers
http://community.qnx.com/sf/go/post35474
Re: RE: RE: RE: QNX does not detect the third network card
Sloginfo -c results
Aug 07 11:26:22    2    12     0 ps2 - Device Timeout (0x5e)
Aug 07 11:26:22    2    12     0 ps2 - Device Timeout (0x54)
Aug 07 11:26:22    2    12     0 ps2 - Device Timeout (0x56)
Aug 07 11:26:22    2    12     0 ps2 - Device Timeout (0x52)
Aug 07 11:26:23    2    19   1500 devb-ahci 1.00A (Oct 20 2008 23:23:51)
Aug 07 11:26:23    2     5     0 libcam.so (Oct 20 2008 23:22:34) bver 6040001
Aug 07 11:26:23    2     5     0 xpt_configure:  ahci SIM attach failure
Aug 07 11:26:23    2    19     0 devb-eide 1.00A (Oct 20 2008 23:27:28)
Aug 07 11:26:23    2    19     0 eide_identify_devices: Intel 82801FB vid 8086, did 266f, class 1018a rev 3,
busno 0, dfunc f9
Aug 07 11:26:23    2    19     0 eide_identify_devices: cmd_addr 1f0, cntl_addr 3f4, irq e, chnl 0, udma 5, m
dma 2, sdma 0, pio 4
Aug 07 11:26:23    2    19     0 eide_identify_devices: probing dev 0 status 50, error 0
Aug 07 11:26:23    2    19     0 eide_identify_devices: probing dev 1 status 0, error 0
Aug 07 11:26:23    2    19     0 eide_identify: chk 4 cmd ec, tid 0, status 51, astatus 51, error 4
Aug 07 11:26:23    2    19     0 eide_display_devices: mdl HL-DT-ST DVDRAM GSA-4163B sn K3151CI1252 fw A102 t
id 0, cable 40, max udma 2, cur udma 2, max mdma 2, cur mdma 0, max sdma -1, cur sdma -1, pio 4, mblk 0
Aug 07 11:26:23    2    19     0 eide_init_devices: HL-DT-ST DVDRAM GSA-4163B path 0, tid 0, udma 2, mdma 2,
busno 0, dfunc f9
Aug 07 11:26:23    2    19     0 eide_identify_devices: cmd_addr 170, cntl_addr 374, irq f, chnl 1, udma 5, m
Aug 07 11:26:23    2    19     0 eide_identify_devices: probing dev 0 status 7f, error 7f
Aug 07 11:26:23    2    19     0 eide_identify_devices: probing dev 1 status 7f, error 7f
Aug 07 11:26:23    2    19     0 eide_identify_devices: Intel 82801FB/W SATA vid 8086, did 2651, class 1018f
rev 3, busno 0, dfunc fa
Aug 07 11:26:23    2    19     0 eide_identify_devices: cmd_addr e800, cntl_addr e400, irq a, chnl 0, udma 5,
 mdma 2, sdma 0, pio 4
Aug 07 11:26:23    2    19     0 eide_parse_identify:  IDENTIFY DRIVE CMD cksum failure 192
Aug 07 11:26:23    2    19     0 eide_display_devices: mdl WDC WD1600JD-22HBB0 sn WD-WCAL9266037 fw 08.02D08
tid 0, cable 40, max udma 6, cur udma 5, max mdma 2, cur mdma 0, max sdma -1, cur sdma -1, pio 4, mblk 16
Aug 07 11:26:23    2    19     0 eide_init_devices: WDC WD1600JD-22HBB0 path 1, tid 0, udma 5, mdma 2, sdma -
1, pio 4, mblk 16
Aug 07 11:26:23    2    19     0 eide_identify_devices: cmd_addr e000, cntl_addr dc00, irq a, chnl 1, udma 5,
Aug 07 11:26:23    2    19     0 eide_init_devices: WDC WD1600JD-22HBB0...
RE: RE: RE: RE: QNX does not detect the third network card
I don't want the sloginfo -c results. I want you to do the following:
slay io-pkt-v4-hc
sloginfo > file
Post the output 'file'.
Thanks.
Sent: Friday, August 07, 2009 11:33 AM
Subject: Re: RE: RE: RE: QNX does not detect the third network card
Sloginfo -c results
6040001
6040001
busno 0, dfunc f9
status 50, error 0
status 0, error 0
busno 0, dfunc f9
status 7f, error 7f
status 7f, error 7f
status 50, error 0
status 0, error 0
1, pio 4, mblk 16
status 50, error 0
Aug 07 11:26:23    2    19     0...
Re: RE: RE: RE: RE: QNX does not detect the third network card
I figure out there is no devnp-e1000.so in x86\lib\dll so I copied from Momentics machine to target machine after that I
 run
slay io-pkt-v4-hc
sloginfo > file
and below is the result. Now my target machine recognizes new network card but it removed the built in network card. I
guess there is a  limitation of two network cards somewhere?
Aug 07 11:55:29    2    12     0 ps2 - Device Timeout (0x5e)
Aug 07 11:55:29    2    12     0 ps2 - Device Timeout (0x54)
Aug 07 11:55:29    2    12     0 ps2 - Device Timeout (0x56)
Aug 07 11:55:29    2    12     0 ps2 - Device Timeout (0x52)
Aug 07 11:55:30    2    12     0 ps2 - Device Timeout (0x56)
Aug 07 11:55:30    2    19   1500 devb-ahci 1.00A (Oct 20 2008 23:23:51)
Aug 07 11:55:30    2     5     0 libcam.so (Oct 20 2008 23:22:34) bver 6040001
Aug 07 11:55:30    2     5     0 xpt_configure:  ahci SIM attach failure
Aug 07 11:55:30    2    19     0 devb-eide 1.00A (Oct 20 2008 23:27:28)
Aug 07 11:55:30    2    19     0 eide_identify_devices: Intel 82801FB vid 8086, did 266f, class 1018a rev 3, busno 0,
dfunc f9
Aug 07 11:55:30    2    19     0 eide_identify_devices: cmd_addr 1f0, cntl_addr 3f4, irq e, chnl 0, udma 5, mdma 2, sdma
 0, pio 4
Aug 07 11:55:30    2    19     0 eide_identify_devices: probing dev 0 status 50, error 0
Aug 07 11:55:30    2    19     0 eide_identify_devices: probing dev 1 status 0, error 0
Aug 07 11:55:30    2    19     0 eide_identify: chk 4 cmd ec, tid 0, status 51, astatus 51, error 4
Aug 07 11:55:30    2    19     0 eide_display_devices: mdl HL-DT-ST DVDRAM GSA-4163B sn K3151CI1252 fw A102 tid 0, cable
Aug 07 11:55:30    2    19     0 eide_init_devices: HL-DT-ST DVDRAM GSA-4163B path 0, tid 0, udma 2, mdma 2, sdma -1,
pio 4, mblk 0
dfunc f9
Aug 07 11:55:30    2    19     0 eide_identify_devices: cmd_addr 170, cntl_addr 374, irq f, chnl 1, udma 5, mdma 2, sdma
 0, pio 4
Aug 07 11:55:30    2    19     0 eide_identify_devices: probing dev 0 status 7f, error 7f
Aug 07 11:55:30    2    19     0 eide_identify_devices: probing dev 1 status 7f, error 7f
Aug 07 11:55:30    2    19     0 eide_identify_devices: Intel 82801FB/W SATA vid 8086, did 2651, class 1018f rev 3,
busno 0, dfunc fa
Aug 07 11:55:30    2    19     0 eide_identify_devices: cmd_addr e800, cntl_addr e400, irq a, chnl 0, udma 5, mdma 2,
sdma 0, pio 4
Aug 07 11:55:30    2    19     0 eide_parse_identify:  IDENTIFY DRIVE CMD cksum failure 192
Aug 07 11:55:30    2    19     0 eide_display_devices: mdl WDC WD1600JD-22HBB0 sn WD-WCAL9266037 fw 08.02D08 tid 0,
Aug 07 11:55:30    2    19     0 eide_init_devices: WDC WD1600JD-22HBB0 path 1, tid 0, udma 5, mdma 2, sdma -1, pio 4,
mblk 16
busno 0, dfunc fa
Aug 07 11:55:30    2    19     0 eide_identify_devices: cmd_addr e000, cntl_addr dc00, irq a, chnl 1, udma 5, mdma 2,
sdma 0, pio 4
Aug 07 11:55:30    2    19     0 eide_identify_devices: probing dev 0 status 7f, error ff
Aug 07 11:55:30    2    19     0 eide_identify_devices: probing dev 1 status 7f, error ff
Aug 07 11:55:30    2     5  ...
RE: RE: RE: RE: RE: QNX does not detect the third network card
No, there is no limitation of 2 network cards. If you reboot your
machine, now that you have the driver in /lib/dll, you should see all 3
interfaces.
Sent: Friday, August 07, 2009 12:02 PM
Subject: Re: RE: RE: RE: RE: QNX does not detect the third network card
Momentics machine to target machine after that I run
slay io-pkt-v4-hc
sloginfo > file
card but it removed the built in network card. I guess there is a
6040001
6040001
vid 8086, did 266f, class 1018a rev 3, busno 0, dfunc f9
cntl_addr 3f4, irq e, chnl 0, udma 5, mdma 2, sdma 0, pio 4
status 50, error 0
status 0, error 0
DVDRAM GSA-4163B sn K3151CI1252 fw A102 tid 0, cable 40, max udma 2, cur
GSA-4163B path 0, tid 0, udma 2, mdma 2, sdma -1, pio 4, mblk 0
cntl_addr 374, irq f, chnl 1, udma 5, mdma 2, sdma 0, pio 4
status 7f, error 7f
status 7f, error 7f
SATA vid 8086, did 2651, class 1018f rev 3, busno 0, dfunc fa
cntl_addr e400, irq a, chnl 0, udma 5, mdma 2, sdma 0, pio 4
status 50, error 0
status 0, error 0
WD1600JD-22HBB0 sn WD-WCAL9266037 fw 08.02D08 tid 0, cable 40, max udma
mblk 16
path 1, tid 0, udma 5, mdma 2, sdma -1, pio 4, mblk 16
Aug 07 11:55:30    2    19     0 eide_identify_devices: Intel...
I had four i82544 interfaces up yesterday
with a single driver.
aboyd
Re: RE: RE: RE: RE: RE: QNX does not detect the third network card
I reboot my system. Now it recognizes just the two network cards (Intel Pro 100 and intel Pro 1000 GT) same as before.
It does not recognize the third network card (Intel Pro 1000 PT) which is connected to PCI express slot. if I run below
code, it removes the first network card from the list and adds the third network card to the list. If I reboot the
system I will get back to the default configuration with the first and second network cards.
slay io-pkt-v4-hc
Mohammad
RE: RE: RE: RE: RE: RE: QNX does not detect the third network card
Please look at you /etc/system/enum/devices/net file and see if both of
the device IDs for your gigabit adapters are in the file. If not, you
can copy one of the lines and add the device ID. Then reboot your
system.
Sent: Monday, August 10, 2009 8:32 AM
Subject: Re: RE: RE: RE: RE: RE: QNX does not detect the third network
card
Pro 100 and intel Pro 1000 GT) same as before. It does not recognize the
slot. if I run below code, it removes the first network card from the
list and adds the third network card to the list. If I reboot the system
network cards.
slay io-pkt-v4-hc
Mohammad
Networking Drivers
http://community.qnx.com/sf/go/post35537
Re: RE: RE: RE: RE: RE: RE: QNX does not detect the third network card
Hi Hugh,
Thanks a lot. It solved the problem.
Mohammad
QNX recognizes the third network card also I can set the IP address. However, when I ping another PC in the same network
 or vise versa , ping does not work. Should I do something else after adding the device ID to the net file and rebooting
. I am sure that I have set the IP address correctly as the other network cards work perfectly.
Mohammad
RE: RE: RE: RE: RE: RE: RE: QNX does not detect the third network card
Have you configured the network addresses using the Photon network setup
or are you doing it manually? If you are doing it manually, make sure
that you slay dhcp.client and netmanager before configuring the
interfaces.
Sent: Monday, August 10, 2009 9:23 AM
Subject: Re: RE: RE: RE: RE: RE: RE: QNX does not detect the third
network card
However, when I ping another PC in the same network or vise versa , ping
the net file and rebooting. I am sure that I have set the IP address
Mohammad
Networking Drivers
http://community.qnx.com/sf/go/post35546
>> ping does not work
A simple way to check to see if the driver is
functioning with the nic is with the
  # nicinfo -r enX
utility, where X is a small positive integer.
Ensure that for each interface, it has negotiated
to a valid link speed and duplex, and check the
"Packets Received Ok" count - it should be non-zero
on almost any network, which indicates that the nic
interrupt is functioning.
Once you think the hardware and driver are functioning
then you can go on to the protocols.
aboyd
Re: RE: RE: RE: RE: RE: RE: RE: QNX does not detect the third network card
Packet Received is non-zero however packet transmit is zero even though I pinged its IP address from the other computer
in the network. I think this is the reason ping does not work.
Mohammad
RE: RE: RE: RE: RE: RE: RE: RE: QNX does not detect the third network card
What is the output from 'netstat -in' after the interfaces have been
configured?
Sent: Monday, August 10, 2009 10:04 AM
Subject: Re: RE: RE: RE: RE: RE: RE: RE: QNX does not detect the third
network card
I pinged its IP address from the other computer in the network. I think
Mohammad
Networking Drivers
http://community.qnx.com/sf/go/post35565
Re: RE: RE: RE: RE: RE: RE: RE: RE: QNX does not detect the third network card
# netstat -in
Name  Mtu   Network       Address              Ipkts Ierrs    Opkts Oerrs Colls
lo0   33192 <Link>                                18     0       18     0     0
lo0   33192 127/8         127.0.0.1               18     0       18     0     0
fxp0  1500  <Link>        00:11:11:6e:07:2e     1259     0      348     0     0
fxp0  1500  129.100.227/2 129.100.227.188       1259     0      348     0     0
wm0   1500  <Link>        00:15:17:b9:5f:13      584     0      520     0     0
wm0   1500  192.168.1/24  192.168.1.5            584     0      520     0     0
wm1   1500  <Link>        00:1b:21:3b:59:42       75     0        1     0     0
wm1   1500  192.168.1/24  192.168.1.6             75     0        1     0     0
On Mon, Aug 10, 2009 at 10:14:24AM -0400, Mohammad Dadashzadeh wrote:
> # netstat -in
wm0 and wm1 are on the same subnet.  All packets
routed to 192.168.1/24 will go out one or the other
(check your routing table).  In your case it seems
to be wm0.
RE: RE: RE: RE: RE: RE: RE: RE: RE: QNX does not detect the third network card
You have 2 links on the same subnet. You can't do that!
Wm0 and wm1 have the same subnet.
Sent: Monday, August 10, 2009 10:14 AM
Subject: Re: RE: RE: RE: RE: RE: RE: RE: RE: QNX does not detect the
third network card
# netstat -in
Oerrs Colls
0     0
0     0
0     0
0     0
0     0
0     0
0     0
0     0
Networking Drivers
http://community.qnx.com/sf/go/post35574
Re: RE: RE: RE: RE: RE: RE: RE: RE: RE: QNX does not detect the third network card
Is this the case in QNX since in my windows machine I have two network cards with
the same subnet mask.
Windows IP Configuration
Ethernet adapter Local Area Connection 5:
        Connection-specific DNS Suffix  . :
        IP Address. . . . . . . . . . . . : 192.168.1.3
        Subnet Mask . . . . . . . . . . . : 255.255.255.0
        Default Gateway . . . . . . . . . :
Ethernet adapter Local Area Connection:
        Connection-specific DNS Suffix  . : uwo.ca
        IP Address. . . . . . . . . . . . : 129.100.227.15
        Default Gateway . . . . . . . . . : 129.100.227.1
Mohammad
Those have the same subnet masks but when applied
against the ip addresses they result in different
subnets.  On your QNX box they're the same:
On windows:
(192.168.1.3 & 255.255.255.0)    = 192.168.1.0
(129.100.227.15 & 255.255.255.0) = 129.100.227.0
On QNX:
(192.168.1.5 & 255.255.255.0)    = 192.168.1.0
(192.168.1.6 & 255.255.255.0)    = 192.168.1.0
You are right I even checked it in windows, the same problem. I guess I have a conceptual problem. I have a private
network with the ip addresses 192.168.1.1-254 and subnet mask 255.255.255.0. Is it possible to have multiple network
cards in one PC connected to the same network. If I want that I have to set all the network cards IP address in this
range 192.168.1.1-254 and subnet 255.255.255.255. It seems that it is impossible. I am totally confused.
Mohammad
