Forum Topic - Reg -MII Phy: (1 Item)
Reg -MII Phy
I have requirement to use the initialize the PHY and read/write the register value.
But instead of writing all those things i have found one driver code for mpc85xx in BSP directory.
there is a file  mii.c file have all the mii_read/write functions.
i want to use the dirver dev_mpc85xx.so file to read/write the register using the driver function mii_read/write.
is there any poosibilty to use the same driver to read/write from my application using the driver functions.
if its possible tell the way or send me any smaple code.
Thanks and Regards
K.Senthil
