Forum Topic - Ref - Packet Filter compilation problem: (7 Items)
Hi ,
I have copied the sample code for PF from QNX site and try to compile in QNX x86 PC but it throws an error.
Please tell me how to compile and load.
make -j 1 -Cdll -fMakefile
make[1]: Entering directory `/home/senthil/pfil/x86/dll'
../../common.mk:10: /home/senthil/pfil/../lsm.mk: No such file or directory
make[1]: *** No rule to make target `/home/senthil/pfil/../lsm.mk'.  Stop.
make[1]: Leaving directory `/home/senthil/pfil/x86/dll'
make: *** [all] Error 2
K.Senthil
Re: Ref - Packet Filter compilation problem
On Wed, Jun 24, 2009 at 05:00:19AM -0400, Senthil K wrote:
> Hi ,
> Thanks
> K.Senthil
Looks like you didn't copy enough.  Please see this page.
Picking out an isolated piece and trying to build it
isn't a supported configuration.
http://community.qnx.com/sf/wiki/do/viewPage/projects.networking/wiki/Source_Guide
I copied from their and compile the previous problem got solved but another problem i faced.
Please find the below errors
make -j 1 -Cx86 -fMakefile
make[1]: Entering directory `/home/senthil/pfil/x86'
make[2]: Entering directory `/home/senthil/pfil/x86/dll'
/usr/qnx640/host/qnx6/x86/usr/bin/qcc -Vgcc_ntox86 -c -Wc,-Wall -Wc,-Wno-parentheses  -O -DNDEBUG   -I. -I/home/senthil/
pfil/x86/dll -I/home/senthil/pfil/x86 -I/home/senthil/pfil -I/usr/qnx640/target/qnx6/usr/include      -shared -
DVARIANT_dll -DBUILDENV_qss  /home/senthil/pfil/pfhook.c
/home/senthil/pfil/pfhook.c: In function 'deinit_module':
/home/senthil/pfil/pfhook.c:61: warning: implicit declaration of function 'pfil_remove_hook'
/home/senthil/pfil/pfhook.c:63: warning: implicit declaration of function 'pfil_head_get'
/home/senthil/pfil/pfhook.c:63: warning: assignment makes pointer from integer without a cast
/home/senthil/pfil/pfhook.c: At top level:
/home/senthil/pfil/pfhook.c:78: warning: 'struct _iopkt_self' declared inside parameter list
/home/senthil/pfil/pfhook.c:78: warning: its scope is only this definition or declaration, which is probably not what
you want
/home/senthil/pfil/pfhook.c: In function 'pfil_entry':
/home/senthil/pfil/pfhook.c:83: warning: implicit declaration of function 'pfil_add_hook'
/home/senthil/pfil/pfhook.c:86: warning: assignment makes pointer from integer without a cast
/home/senthil/pfil/pfhook.c:98: warning: parameter names (without types) in function declaration
/home/senthil/pfil/pfhook.c:98: error: function 'IOPKT_LSM_ENTRY_SYM' is initialized like a variable
/home/senthil/pfil/pfhook.c:99: warning: implicit declaration of function 'IOPKT_LSM_ENTRY_SYM_INIT'
cc: /usr/qnx640/host/qnx6/x86/usr/lib/gcc/i386-pc-nto-qnx6.4.0/4.2.4/cc1 error 1
make[2]: *** [pfhook.o] Error 1
Thanks and Regards
K.Senthil
On Thu, Jun 25, 2009 at 01:53:05AM -0400, Senthil K wrote:
senthil/pfil/x86/dll -I/home/senthil/pfil/x86 -I/home/senthil/pfil -I/usr/qnx640/target/qnx6/usr/include      -shared -
you want
You need to include <net/pfil.h> and have _KERNEL defined.
<sys/io-pkt.h>
Hi ,
I have attached the code tell me if any thing wrong.
Thanks and Regards
K.Senthil
Attachment: Text pfhook.c 2.11 KB
Hi ,
After adding the _KERNEL macro and <net/pfil.h> file.
still i m getting the error
Thanks and Regards
K.Senthil
On Fri, Jun 26, 2009 at 01:46:43AM -0400, Senthil K wrote:
> Hi ,
The following works for, where /home/seanb/io-pkt
is where I have the networking repo checked out.
$ cc -shared  -I /home/seanb/io-pkt/sys -Wall -fno-builtin-log \
 -D_KERNEL -Wp,-include -Wp,/home/seanb/io-pkt/sys/qnx.h \
 -Wl,-Bsymbolic -o lsm-senthil.so s.c
