Forum Topic - Reg -Packet filter example: (3 Items)
Hi ,
I have gone through the packet filter interface document,is there any other example code.
is there any possibility to send the mbuf structure to my application.
How can my application use to interact packet filter interface and tell compile and load the pf support.
Thanks and Regards
K.Senthil
Re: Reg -Packet filter example
On Sun, Jun 21, 2009 at 08:54:46AM -0400, Senthil K wrote:
> Hi ,
lsm-pf.so is an example that uses the pfil interface.
There's currently no way to pass an mbuf out of
the stack.  If pfil is used in a stack module
an mbuf can be manipulated directly.
If by "application" you mean a process outside of io-pkt
then the pfil interface can't be used.  If you want to
pass packet data outside of the stack take a look at BPF /
libpcap.
Hi sean,
I m only getting arp packets alone in the lsm-packfil.so but i m not able to receive other packets.
What should i do to receive all the packets in packet filter module.
Regards
K.Senthil
