Forum Topic - build of io-pkt drivers failing: (4 Items)
Hello all.
I'm on the way to write an io-pkt driver based on the model of mpc85xx, for example, under QNX 6.4.0.
I've downloaded the core_networking with SVN.
I've also downloaded the patch for QNX 6.4.0, and I tried to build the core networking lib doing a make install (I have
imported the project in QDE, maybe it's a problem ?). I got a lot of errors then.
I just tried to build a driver, and it failed also.
Problem is that some include files are not found :
for example, iopkt_driver.h or syslog.h are not found.
see attachment for more errors.
Do I miss something. Do I proceed wrong ?
Thanks.
Guillaume.
Attachment: Text buildlog.txt 69.66 KB
RE: build of io-pkt drivers failing
Hi Guillaume:
Just to double check when you refer to the patch, is it the patch covered at the end of this wiki page?
http://community.qnx.com/sf/wiki/do/viewPage/projects.networking/wiki/Drivers_wiki_page
(There's also the patch for a macro which was added and that's covered in the source guide wiki.)
   Robert.
From: Guillaume Varlet [mailto:community-noreply@qnx.com]
Sent: Fri 4/24/2009 5:48 AM
To: drivers-networking
Subject: build of io-pkt drivers failing
Hello all.
Thanks.
Guillaume.
Networking Drivers
http://community.qnx.com/sf/go/post27967
Attachment: Text winmail.dat 2.97 KB
Looking through the log, I also wonder if you've got conflicting tool sets installed
"/WindRiver/workbench-2.4/x86-win32/bin/make.exe"
would seem to indicate that you aren't running the QNX make.
   Robert.
Hello all.
Thanks.
Guillaume.
Networking Drivers
Attachment: Text winmail.dat 2.95 KB
Re: RE: build of io-pkt drivers failing
Hello Robert.
I've installed the iopkt_build_headers.tar.gz and follow the advise on link you give me : Now, I can build the driver.
Thank you very much ! :)
I have also vxWorks installed, but it does not matter, since include files are now installed.
Guillaume.
