Eric Dong(deleted)
Wanna eliminate the problems of WLAN btw QNX and XP machines
Eric Dong(deleted)
03/02/2009 9:06 AM
post23183
Hi all,
I have two target installed with the QNX632, and one XP as the IDE machine. I started the Orinoco 802.11b PC card on
both of the QNX632 machines, and on the XP as well. configure them as the adhoc mode.
Then i tried to ping from one another. For the two qnx machines, with "nicinfo -r en1", only the number of bytes
increased while the # of received pkts remained all the time.
Previously, the three could work fine but still failed to work well sometimes. Overall, it seems that this 3 nodes adhoc
network is somehow not robust. Would appreciate any ideas and suggestions.
P.S. : the Orinoco card on XP should be working just like a normal commercial 802.11b card(the led indicating the
network activity keeps flashing), while on qnx, the led just got fired after around 2 seconds, seems rather inactive.
Eric
Hugh Brown
RE: Wanna eliminate the problems of WLAN btw QNX and XP machines
Hugh Brown
03/02/2009 2:43 PM
post23250
Unfortunately I don't have 3 Orinoco adapters to test with. If you just
run 2 adapters, does it work OK?
Sent: Monday, March 02, 2009 9:07 AM
To: drivers-networking
Subject: Wanna eliminate the problems of WLAN btw QNX and XP machines
Hi all,
machine. I started the Orinoco 802.11b PC card on both of the QNX632
"nicinfo -r en1", only the number of bytes increased while the # of
sometimes. Overall, it seems that this 3 nodes adhoc network is somehow
commercial 802.11b card(the led indicating the network activity keeps
Eric
Networking Drivers
http://community.qnx.com/sf/go/post23183
Eric Dong(deleted)
Re: RE: Wanna eliminate the problems of WLAN btw QNX and XP machines
Eric Dong(deleted)
03/03/2009 1:18 AM
post23296
thx, for the 2 orinoco cards case, it is the same problem.
The pccard on XP machine seems working well, while on the QNX target, the pccard seems to be in the idle state(since the
two leds, should be one power and one signal, only get fired together with a period of 2-3 seconds).
But i mounted the orinoco on qnx with the full version tcpip stack. it should be working just as XP. I think this
probably be the source of the sequencing problems -- undetermined connectivity. Though without tests, I believe that
there would be no problems in two Xp machines. What's your opinions?
Eric
Hugh Brown
RE: RE: Wanna eliminate the problems of WLAN btw QNX and XP machines
Hugh Brown
03/03/2009 8:17 AM
post23303
I know that the Orinoco driver works, so can you please start the driver
in verbose mode and send me the command line that you are using as well
as the output from 'sloginfo'.
Thanks.
Sent: Tuesday, March 03, 2009 1:18 AM
Subject: Re: RE: Wanna eliminate the problems of WLAN btw QNX and XP
machines
the pccard seems to be in the idle state(since the two leds, should be
seconds).
should be working just as XP. I think this probably be the source of the
I believe that there would be no problems in two Xp machines. What's
your opinions?
Eric
Networking Drivers
http://community.qnx.com/sf/go/post23296
Eric Dong(deleted)
Re: RE: RE: Wanna eliminate the problems of WLAN btw QNX and XP machines
Eric Dong(deleted)
03/03/2009 9:09 AM
post23308
thx, the scripts i used for starting the network:
/proc/boot/devp-pccard -vvv ss -m
waitfor /dev/pccard 59
display "Configure the ns83815"
io-net -d ns83815 -p tcpip stacksize=100000 -p qnet bind=en0
waitfor /dev/io-net/en0
waitfor /dev/socket
ifconfig en0 *.*.*.*netmask 255.255.0.0
sleep 3
display_msg "configuring adhoc network mode"
mount -o channel=11,network=work,mode=adhoc -T io-net devn-orinoco.so
waitfor /dev/io-net/en1
ifconfig en1 192.168.1.1 netmask 255.255.255.0
the output of sloginfo is as attached, seemed sth wrong. thx again.
Eric
> Thanks.
> From: Eric Dong [mailto:community-noreply@qnx.com]
> machines
> seconds).
> your opinions?
> Thanks,
> Eric
> Networking Drivers
Hugh Brown
RE: RE: RE: Wanna eliminate the problems of WLAN btw QNX and XP machines
Hugh Brown
03/03/2009 9:25 AM
post23318
You are not specifying an ssid on your command line. That is why you are
not getting a connection.
Sent: Tuesday, March 03, 2009 9:09 AM
Subject: Re: RE: RE: Wanna eliminate the problems of WLAN btw QNX and XP
machines
waitfor /dev/socket
sleep 3
devn-orinoco.so
Eric
driver
well
> Thanks.
> machines
> seconds).
the
tests,
> your opinions?
> Thanks,
> Eric
> Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post23308
Eric Dong(deleted)
Re: RE: RE: RE: Wanna eliminate the problems of WLAN btw QNX and XP machines
Eric Dong(deleted)
03/03/2009 9:43 AM
post23325
Thanks, i have tried to specify ssid the same as the network, but still could not get connected. and i checked the doc
of orinoco, ssid and network seems the same. Previously, if worked fine on the qnx machine, the signal led would keep
flashing with relative high frequency.
Eric
> machines
> waitfor /dev/socket
> sleep 3
> devn-orinoco.so
> Eric
> driver
> well
> > Thanks.
> > machines
> > seconds).
> the
> tests,
> > your opinions?
> > Thanks,
> > Eric
> > Networking Drivers
> Networking Drivers
Eric Dong(deleted)
Eric Dong(deleted)
03/04/2009 6:39 AM
post23441
Hi, Hugh.
I mounted the Orinoco card on a pure qnx laptop. Then tried the connection btw xp and qnx. The orinoco on qnx machine
behaved almost the same as that on my pc104 target.
However, when i configured the orinoco in the ap mode, i could surf the internet just as normal as that in xp machine. I
don't know why this happens. Look forward to suggestions. thx.
Eric
Hugh Brown
RE: RE: RE: RE: Wanna eliminate the problems of WLAN btw QNX and XP machines
Hugh Brown
03/04/2009 7:55 AM
post23445
I don't have any answers for you right now as I am rather busy. I will
set this up and try it as soon as I have a chance. I do know that it
works, as I have run it myself.
Sent: Wednesday, March 04, 2009 6:40 AM
Subject: Re: RE: RE: RE: Wanna eliminate the problems of WLAN btw QNX
and XP machines
Hi, Hugh.
connection btw xp and qnx. The orinoco on qnx machine behaved almost the
internet just as normal as that in xp machine. I don't know why this
Eric
Networking Drivers
http://community.qnx.com/sf/go/post23441
Eric Dong(deleted)
Re: RE: RE: RE: RE: Wanna eliminate the problems of WLAN btw QNX and XP machines
Eric Dong(deleted)
03/04/2009 8:32 AM
post23450
sure, thx very much.
Eric
Hugh Brown
Hugh Brown
03/05/2009 10:08 AM
post23600
Eric,
I have verified that this problem exists with the Orinoco adapter, so if
you want to get it fixed, you will have to contact your support
representative, so that this problem will be routed through the correct
channels.
Thanks, Hugh.
and XP machines
Hi, Hugh.
Eric
Networking Drivers
Eric Dong(deleted)
Eric Dong(deleted)
03/06/2009 11:42 AM
post23796
thanks very much, Hugh. Actually this information is so disappointed. The orinoco 802.11b PCCard is already phased out
on the market.
And i would like to confirm that this problem is only in the adhoc mode, right?
And that would be really great if you could provide me with another similar network adapter available on the market.
Thank you.
Best,
Eric
> Eric,
> channels.
> Thanks, Hugh.
> and XP machines
> Hi, Hugh.
> Eric
> Networking Drivers
Hugh Brown
RE: RE: RE: RE: RE: Wanna eliminate the problems of WLAN btw QNX and XP machines
Hugh Brown
03/06/2009 12:52 PM
post23804
Eric,
Yes, this is only a problem with adhoc mode. It is very difficult for us
to recommend wireless adapters, as the manufacturers are always changing
chipsets. If you can find adapters with Broadcom BCM43xx chipsets in
them, the devn-bcm43xx.so driver will support them.
Hugh.
Sent: Friday, March 06, 2009 11:43 AM
Subject: Re: RE: RE: RE: RE: Wanna eliminate the problems of WLAN btw
QNX and XP machines
The orinoco 802.11b PCCard is already phased out on the market.
right?
similar network adapter available on the market. Thank you.
Best,
Eric
> Eric,
if
correct
> channels.
> Thanks, Hugh.
> and XP machines
> Hi, Hugh.
the
the
> Eric
> Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post23796
Robert Craig
Robert Craig
03/06/2009 12:53 PM
post23805
On 6.4.0, there are also drivers available for Atheros and Ralink cards
in addition to the BCM43xx.
Robert.
From: Hugh Brown [mailto:community-noreply@qnx.com]
Sent: Friday, March 06, 2009 12:53 PM
Subject: RE: RE: RE: RE: RE: Wanna eliminate the problems of WLAN btw
QNX and XP machines
Eric,
Hugh.
QNX and XP machines
right?
Best,
Eric
> Eric,
if
correct
> channels.
> Thanks, Hugh.
> and XP machines
> Hi, Hugh.
the
the
> Eric
> Networking Drivers
Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post23804
Eric Dong(deleted)
Re: RE: RE: RE: RE: RE: Wanna eliminate the problems of WLAN btw QNX and XP machines
Eric Dong(deleted)
03/21/2009 2:41 AM
post24950
Sorry for late response, Hugh.
Actually, I am now using 6.3.2. Regarding the network card, the qnx website lists the supporting wifi cards, in which
the broadcom includes 0x14E4, 0x4301, 0x4307, 0x4311, 0x4320, 0x4321, 0x4324, 0x4325.
As i checked from the broadcom website, currently only the model 0x4325 is available. Of course, they provide many other
models, but i hope i could confirm with you that which model exactly will be working well in adhoc mode. Since i have
no broadcom cards available at this time. Thanks again.
Best,
Eric
Hugh Brown
RE: RE: RE: RE: RE: RE: Wanna eliminate the problems of WLAN btw QNX and XP machines
Hugh Brown
03/23/2009 7:55 AM
post24981
Yes, that device should be supported by our driver.
Sent: Saturday, March 21, 2009 2:41 AM
Subject: Re: RE: RE: RE: RE: RE: Wanna eliminate the problems of WLAN
website lists the supporting wifi cards, in which the broadcom includes
is available. Of course, they provide many other models, but i hope i
adhoc mode. Since i have no broadcom cards available at this time.
Thanks again.
Best,
Eric
Networking Drivers
http://community.qnx.com/sf/go/post24950
Weijie Zhang(deleted)
03/23/2009 9:55 AM
post25003
I think we don't support 0x4320. At least on io-pkt we don't support
0x4320 (cf PR 53039) and the bcm43xx driver on io-pkt was actually
ported from its counterpart on io-net which is defaultly running on nto
6.3.2.
Weijie
Sent: March 23, 2009 7:55 AM
Subject: RE: RE: RE: RE: RE: RE: Wanna eliminate the problems of WLAN
Thanks again.
Best,
Eric
Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post24981
Eric Dong(deleted)
Re: RE: RE: RE: RE: RE: RE: Wanna eliminate the problems of WLAN btw QNX and XP machines
Eric Dong(deleted)
03/23/2009 12:22 PM
post25032
Thanks for reply. I checked the broadcom website, seems all the supporting products are chips instead of COTS wifi cards
. I do appreciate that you could provide me a list of pccards supporting adhoc mode in QNX632(pcmcia preferred). thx.
Eric
> 6.3.2.
> Thanks
> Weijie
> Thanks again.
> Best,
> Eric
> Networking Drivers
> Networking Drivers
Hugh Brown
RE: RE: RE: RE: RE: RE: RE: Wanna eliminate the problems of WLAN btw QNX and XP machines
Hugh Brown
03/23/2009 3:05 PM
post25043
The only other wireless chipset that we support is the Agere Hermes2
chipset. I don't know whether this is still available.
Sent: Monday, March 23, 2009 12:22 PM
Subject: Re: RE: RE: RE: RE: RE: RE: Wanna eliminate the problems of
supporting products are chips instead of COTS wifi cards. I do
Eric
nto
> 6.3.2.
> Thanks
> Weijie
includes
0x4325
in
> Thanks again.
> Best,
> Eric
> Networking Drivers
> Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post25032
Eric Dong(deleted)
Re: RE: RE: RE: RE: RE: RE: RE: Wanna eliminate the problems of WLAN btw QNX and XP machines
Eric Dong(deleted)
03/29/2009 1:08 PM
post25500
Dear Hugh,
I think the orinoco pc card work very well in adhoc mode in Xp machines. So is it possible that you could modify the
current devn-orinoco.so so that it could also work under adhoc mode in QNX 6.3.2 targets? Thanks very much.
Best,
Eric
Hugh Brown
RE: RE: RE: RE: RE: RE: RE: RE: Wanna eliminate the problems of WLAN btw QNX and XP machines
Hugh Brown
03/30/2009 7:46 AM
post25513
Eric,
I can't just do work without it being scheduled, so you will have to
make a formal application through your sales representative to get this
work done.
Hugh.
Sent: Sunday, March 29, 2009 1:09 PM
Subject: Re: RE: RE: RE: RE: RE: RE: RE: Wanna eliminate the problems of
Dear Hugh,
So is it possible that you could modify the current devn-orinoco.so so
very much.
Best,
Eric
Networking Drivers
http://community.qnx.com/sf/go/post25500
