Forum Topic - Change nic configuration at runtime?: (7 Items)
Is it possible to change the nic parameters like speed,duplex at run time? if yes what utility can i use to change these
 things?
RE: Change nic configuration at runtime?
If this is for 6.3.2, then the only way is to restart the driver with
the speed and duplex command line options. I cannot comment on the 6.4
drivers.
From: Vijayanandham Kamalasekaran [mailto:community-noreply@qnx.com]
Sent: Thursday, December 04, 2008 2:00 AM
To: drivers-networking
Subject: Change nic configuration at runtime?
time? if yes what utility can i use to change these things?
Networking Drivers
http://community.qnx.com/sf/go/post17899
> the driver with the speed and duplex command
> line options.
> I cannot comment on the 6.4 drivers
Actually 6.4 does have support to change the
speed, duplex etc during runtime.  See the
ifconfig utility - the mediaopt option.
Note that only native 6.4 drivers, and bsd
drivers, support this API - see bsd_media.c
in the source - to get and set the media options.
If you are running a 6.3 (io-net) driver
with the shim, since the underlying driver
does not support the changing of speed and
duplex during runtime, neither does the shim.
aboyd
Re: RE: Change nic configuration at runtime?
Andrew,
           I will look into bsd_media.c.Thanks.
Hugh,
        If i need to change configurations at runtime for io-net drivers can i implement those config changes as
devctls().I beleive there is no change in ifconfig utility between 6.3.2 and 6.4.
Hugh,
        sorry for that stupid question about ifconfig across 6.3.2 and 6.4.0.I believe there should be lot of
differences internally.Lets say iam writing my own utility can i use devctls() from it to control speed and duplex
parameter.
RE: RE: Change nic configuration at runtime?
Yes, you can do this, but the driver will have to be re-started to
implement the changes, unless you change the driver architecture.
Sent: Friday, December 05, 2008 5:08 AM
Subject: Re: RE: Change nic configuration at runtime?
Hugh,
6.4.0.I believe there should be lot of differences internally.Lets say
and duplex parameter.
Networking Drivers
http://community.qnx.com/sf/go/post17990
Well I don't see the mediaopts under the 6.3.2 version of ifconfig, so I
don't think that this is possible under 6.3.2.
Sent: Friday, December 05, 2008 1:14 AM
Andrew,
Hugh,
can i implement those config changes as devctls().I beleive there is no
Networking Drivers
http://community.qnx.com/sf/go/post17987
