Alex Pavloff
Xilinx devn-xemac not fully functioning with shim layer
Alex Pavloff
11/21/2008 2:56 PM
post17095
(Originally posted in the io-pkt migration, which was the wrong place, sorry).
Hi all,
I'm trying to use the devn-xemac driver with io-pkt, using the shim. This driver is present in the Xilinx Virtex II-Pro
BSP, and is basically a thin QNX layer around Xilinx's EDK-provided source function.
No problems in 6.3.2.
Here's what's happening in 6.4 (using io-pkt-v4).
# io-pkt -ptcpip
# mount -T io-net -o mac=00112233445566 devn-xemac.so
# ifconfig
en0: flags=80008802<BROADCAST,SIMPLEX,MULTICAST,SHIM> mtu 1500
address: 00:00:00:00:00:00
# ifconfig en0 192.168.230.100
# ifconfig
en0: flags=80008843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST,SHIM> mtu 1500
inet 192.168.230.100 netmask 0xffffff00 broadcast 192.168.230.255
Now, when I try to ping another host, I see outgoing ARP packets, I see the response from the target host... but it
looks like the packets aren't being processed by io-pkt properly. nicinfo report bytes transmitted just fine, but
nothing recieved.
Another issue appears to be that the shim layer isn't picking up the mac address, as it comes in at the default.
I suspect the problem is in the xemac driver not quite agreeing with the shim -- any suggestions on where to look?
Robert Craig
RE: Xilinx devn-xemac not fully functioning with shim layer
Robert Craig
11/21/2008 3:04 PM
post17098
And my turn to post in the wrong group :>. I'll move the answer here as
well:
This certainly looks like a MAC problem of some sort. All 0's
for the MAC is a bad thing...
I think that your MAC is incorrectly specified on the command line. It
should be 001122334455. While I don't think that this is the cause of
the problem, let's start there and see if it makes any difference. You
can also try:
io-pkt-v4 -dxemac.so verbose
To start up the stack with the driver in verbose mode and then you can
post the output from sloginfo (assuming that you have slogger running)
and that might give us a bit more info.
Robert.
From: Alex Pavloff [mailto:community-noreply@qnx.com]
Sent: Friday, November 21, 2008 2:57 PM
To: drivers-networking
Subject: Xilinx devn-xemac not fully functioning with shim layer
sorry).
Hi all,
This driver is present in the Xilinx Virtex II-Pro BSP, and is
# io-pkt -ptcpip
# mount -T io-net -o mac=00112233445566 devn-xemac.so # ifconfig
# ifconfig
1500
192.168.230.255
the response from the target host... but it looks like the packets
transmitted just fine, but nothing recieved.
Networking Drivers
http://community.qnx.com/sf/go/post17095
Andrew Boyd(deleted)
11/21/2008 3:35 PM
post17102
> nicinfo report bytes transmitted just fine, but nothing received
Often that's a sign of an interrupt problem - it's
not unmasked or firing or functional on the platform.
What does
# pidin irq
say?
aboyd
Alex Pavloff
Re: RE: Xilinx devn-xemac not fully functioning with shim layer
Alex Pavloff
11/21/2008 4:07 PM
post17106
It tells me that the irq isn't hooked.
Going through the driver, the xemac driver looks like a barely 6.3 driver -- it didn't implement DCMD_IO_NET_GET_CONFIG
or DCMD_IO_NET_GET_STATS, rather, using the old DCMD_IO_NET_NICINFO and DCMD_IO_NET_TXRX_COUNT.
Does the shim driver expect DCMD_IO_NET_GET_CONFIG with a proper config structure, and since it ain't getting, doesn't
know irq and MAC address and everything it's expecting?
Robert Craig
RE: RE: Xilinx devn-xemac not fully functioning with shim layer
Robert Craig
11/21/2008 4:26 PM
post17107
Hmmm... The DCMD..._GET are simply for displaying stat and config and
likely won't affect the driver implementation (other than not properly
displaying the information externally). (I say "likely", because I can't
say that I've seen a driver that doesn't do this properly...). The
driver itself takes care of registering for interrupts and setting the
MAC. This isn't done by the shim.
The xemac driver looks quite old. I take it that it worked OK with
io-net on 6.3.x?
What does "pidin irq" report?
Robert.
Sent: Friday, November 21, 2008 4:07 PM
Subject: Re: RE: Xilinx devn-xemac not fully functioning with shim layer
driver -- it didn't implement DCMD_IO_NET_GET_CONFIG or
structure, and since it ain't getting, doesn't know irq and MAC address
Networking Drivers
http://community.qnx.com/sf/go/post17106
Alex Pavloff
Re: RE: RE: Xilinx devn-xemac not fully functioning with shim layer
Alex Pavloff
11/21/2008 4:33 PM
post17108
The driver did work fine on 6.3.2.
Here's the pidin irqs.
1216519 1 bin/io-pkt
1216519 2 bin/io-pkt
3 0x80010000 0 T-- @0x4808131c:0x480d2fc0
4 0 0 TP- =PULSE 0x40000010:21 0:0xfe39f958
1216519 3 bin/io-pkt
Alex Pavloff
Alex Pavloff
11/21/2008 6:59 PM
post17114
After modifying the driver to be more like a 6.3 driver, things work a little better -- the MAC gets picked up properly
by ifconfig, and it pings and responds.
Now, there's some herky jerky things going on that I'm still trying to figure out.
Alex Pavloff
Alex Pavloff
11/21/2008 7:19 PM
post17115
> better -- the MAC gets picked up properly by ifconfig, and it pings and
> responds.
> out.
I must clarify. The MAC is picked up correctly, but I haven't gotten a ping since the one time it worked.
One other thing odd I noticed is that, even if I just start io-pkt on the command line, with no drivers whatsoever, it
chews up 10% of the CPU.
Any ideas?
Sean Boudreau(deleted)
RE: RE: RE: Xilinx devn-xemac not fully functioning with shim layer
11/21/2008 10:36 PM
post17121
Is that from hogs? It's probably not accurate. io-pkt attaches
to the timer interrupt so it happens to be busy while hogs is
doing its accounting.
Sent: Fri 11/21/2008 7:19 PM
Subject: Re: RE: RE: Xilinx devn-xemac not fully functioning with shim layer
> responds.
> out.
Any ideas?
Networking Drivers
http://community.qnx.com/sf/go/post17115
Robert Craig
Robert Craig
11/24/2008 11:45 AM
post17198
So it worked ONCE and then stopped? I'd try instrumenting the driver
(specifically the receive path) to see if you're actually getting
packets delivered...
In 99% of the cases where we've had drivers not working with the shim,
they have proven to be latent bugs in the io-net driver that had to be
fixed, so that's probably indicative of something :->>
If you really want to get a view of CPU usage, you're always better off
using the system profiler with the instrumented kernel. Hogs hooks into
the system tick just like a number of other utilities, so if often
produces aliased results that are way out of whack with reality (we also
see this all the time with the USB utility). Hogs is OK for generic
things, but you have to be very careful with it's usage when viewing
anything that connects to the system tick.
Robert.
Sent: Friday, November 21, 2008 7:20 PM
layer
> little better -- the MAC gets picked up properly by ifconfig, and it
> pings and responds.
> figure out.
the command line, with no drivers whatsoever, it chews up 10% of the
CPU.
Any ideas?
Networking Drivers
Alex Pavloff
Re: RE: RE: RE: Xilinx devn-xemac not fully functioning with shim layer
Alex Pavloff
11/24/2008 12:48 PM
post17202
So if io-pkt taking 10% is an artifact of the measuring strategy, I think I'm good.
Taking a massive hack at the driver using a more recent one as a template appears to have made everything work the way
it's expected, both from a "respond to packets" as well as a "get the proper MAC address" behavior, which I blame on not
implementing the right devctl messages.
Robert Craig
RE: RE: RE: RE: Xilinx devn-xemac not fully functioning with shim layer
Robert Craig
11/24/2008 12:51 PM
post17204
Hi Alex:
You can always double check with the instrumented kernel. We
did recently have a report that the stack was using slightly more CPU
than io-net (something like 1.5% instead of .5%) in the idle case and
this was due to a timer running at 10ms instead of 50 ms. We've changed
that in the source already.
Glad to hear that the driver is working for you now.
Robert.
Sent: Monday, November 24, 2008 12:49 PM
Subject: Re: RE: RE: RE: Xilinx devn-xemac not fully functioning with
shim layer
think I'm good.
template appears to have made everything work the way it's expected,
address" behavior, which I blame on not implementing the right devctl
messages.
Networking Drivers
http://community.qnx.com/sf/go/post17202
Alex Pavloff
Re: RE: RE: RE: RE: Xilinx devn-xemac not fully functioning with shim layer
Alex Pavloff
11/26/2008 9:02 PM
post17438
I will check that.
I have one more issue -- I'm unable to set the broadcast flag or broadcast address with ifconfig.
I configure the drivers with:
io-pkt-v4
waitfor /dev/socket/ 1
mount -T io-net -o mac=$XEMAC_MAC1,verbose devn-xemac.so
waitfor /dev/io-net/en0 1
ifconfig en0 $XEMAC_IP1
mount -T io-net -o mac=$XEMAC_MAC2,ioport=$XEMAC_IOPORT2,irq=$XEMAC_IRQ2,verbose devn-xemac.so
waitfor /dev/io-net/en1 1
ifconfig en1 $XEMAC_IP2 broadcast $XEMAC_IP2_BROADCAST
ifconfig returns with:
en0: flags=80000041<UP,RUNNING,SHIM> mtu 1500
address: 00:30:b2:ca:fe:99
en1: flags=80000041<UP,RUNNING,SHIM> mtu 1500
address: 00:30:b2:be:ef:44
inet 10.1.0.230 netmask 0xff000000
ifconfig en1 broadcast 10.1.0.255 (for example) has no effect, and the programs that are trying to broadcast ARP (and
fail the sendto call).
Is this the driver or something in ifconfig that I'm not understanding?
11/27/2008 9:29 AM
post17463
On Wed, Nov 26, 2008 at 09:02:41PM -0500, Alex Pavloff wrote:
> I will check that.
> io-pkt-v4
The stack doesn't think the interface supports broadcast
as IFF_BROADCAST isn't set. Is this flag still being set
in the driver's advertise packet? The source I have here
does:
int
xtemac_advertise(int reg_hdl, void *func_hdl)
io_net_msg_dl_advert_t *ap;
ap->iflags = IFF_SIMPLEX | IFF_BROADCAST | IFF_RUNNING /* |IFF_MULTICAST*/;
Alex Pavloff
Alex Pavloff
12/01/2008 12:20 PM
post17655
That's the "xtemac", which is similar, but the same line appears.
int
xemac_advertise(int reg_hdl, void *func_hdl)
ap->iflags = IFF_SIMPLEX | IFF_BROADCAST | IFF_RUNNING;
Multicast isn't there because that code wasn't finished in the xemac driver.
Alex Pavloff
Alex Pavloff
12/01/2008 9:32 PM
post17701
Replying to myself, the problem is fixed.
The advertise function wasn't being called.
Following the model of the other network driver I have (the mpc5200), I added a direct call to the advertise function
from the register_device function, and now all the flags are set properly and the broadcast is working.
Robert Craig
RE: RE: RE: RE: RE: Xilinx devn-xemac not fully functioning with shim layer
Robert Craig
12/01/2008 9:50 PM
post17702
Hi Alex:
Thanks for the update! It's good to have a thread finish off on a positive note.
Robert.
Sent: Mon 12/1/2008 9:32 PM
Subject: Re: RE: RE: RE: RE: Xilinx devn-xemac not fully functioning with shim layer
Networking Drivers
http://community.qnx.com/sf/go/post17701
Alex Pavloff
Re: RE: RE: RE: RE: RE: Xilinx devn-xemac not fully functioning with shim layer
Alex Pavloff
12/02/2008 11:54 AM
post17764
It just really bugs me when people show up with a GIANT PROBLEM, get some help, say "I'll try that", and never respond
as to whether or not their problem is fixed.
It's like a giant cliffhanger!
