Forum Topic - BCM5708: (12 Items)
BCM5708
The M8 bge driver does seem to detect the NetXtreme II BCM5708 ( the doc says it supports 57xx).
I tried forcing the did and vid but apparently devnp-bge doesn't support any option, that confirmed use devnp-bge.
- Mario
RE: BCM5708
Hi Mario:
	What are the did, vid for that card?  It's quite possible that
support for that card wasn't in the NetBSD 4 branch when we took it.
	Robert.
Sent: Friday, October 03, 2008 4:48 PM
To: drivers-networking
Subject: BCM5708
- Mario
Networking Drivers
http://community.qnx.com/sf/go/post14457
RE: BCM5708
Hi Mario:
	I did some quick searching around and 57xx!=5708.  For whatever
reason, it appears that those chips actually require a completely
different driver:
http://netbsd.gw.com/cgi-bin/man-cgi?bnx++NetBSD-current
Care to take a shot at porting a NetBSD driver?
	Robert.
Subject: BCM5708
- Mario
Networking Drivers
Re: RE: BCM5708
> Hi Mario:
> different driver:
I'll give it a shot and will keep you posted.
> 	Robert.
> Subject: BCM5708
> - Mario
> Networking Drivers
RE: RE: BCM5708
Good luck!  There's the "porting technote" in trunk/sys/dev/docs.  I
don't think it's gotten TOO stale since it was last updated.  Let us
know if you hit any problems and we'll make sure that the pain stops
with you by adding the info into the doc :->>.
	Robert.
Sent: Monday, October 06, 2008 4:28 PM
Subject: Re: RE: BCM5708
> Hi Mario:
> different driver:
> 	Robert.
> Subject: BCM5708
doc
support
> - Mario
> Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post14545
Re: RE: RE: BCM5708
> 	Robert.
I was able to compile it.  When trying to mount it the symbol bnx_pci_ca is undefined. I see it's defined extern in init
.c but I can't find where it's declared.  I looked at other drivers (bge) and I can't find where bge_pci_ca either.
> > Hi Mario:
> > different driver:
> > 	Robert.
> > Subject: BCM5708
> doc
> support
> > - Mario
> > Networking Drivers
> Networking Drivers
RE: RE: RE: BCM5708
pre-processor magic - grep for
___CONCAT likely in init.c
aboyd
Re: RE: RE: RE: BCM5708
I figured it out. I forgot to change bnx to bnx_pci in if_bnx.c/CFATTACH_DECL
To my utter amazement on the first try it worked, holy God of drivers!  I would have NEVER bet on that ( I don't bet
anyway ).
All is not perfect thought, the machine crashed when I slayed io-pkt-v4, I'm not worry about that one.
It only works at 100Mbits though.  I tried speed=1000,duplex=1 but no change. I can see in syslog that it detected
support for 1G though.  I'll keep on digging.
If I run ifconfig -m on my target, I get a sigsegv.  If I run ifconfig -m on M8 system (i82544), I don't get any info on
 supported media?
> aboyd
RE: RE: RE: RE: BCM5708
Another (mostly happy) customer :->>.  Believe me... I was just as
surprised as you were when I did my first BSD driver port.
Anyway.  In terms of slaying io-pkt, I suspect that you need to add a
shutdown hook which will quiesce the hardware and prevent it from
DMA-ing data into buffers which it no longer owns.
You might have to add your own routine.  For the bge, this was
 * Stop all chip I/O so that the kernel's probe routines don't
 * get confused by errant DMAs when rebooting.
static void
bge_shutdown(void *xsc)
	struct bge_softc *sc = (struct bge_softc *)xsc;
	bge_stop(sc);
	bge_reset(sc);
At the end of the attach routine, you will see in the bge driver
#ifdef __QNXNTO__
	shutdownhook_establish(bge_shutdown, sc);
    return EOK;
#endif
Make sure that you have a if_stop routine registered (see if_bge, rev
456).
static void
bge_stop_if(struct ifnet *ifp, int disable)
	struct bge_softc *sc = ifp->if_softc;
	bge_stop(sc);
	Robert.
Sent: Tuesday, October 07, 2008 3:51 PM
Subject: Re: RE: RE: RE: BCM5708
I would have NEVER bet on that ( I don't bet anyway ).
change. I can see in syslog that it detected support for 1G though.
-m on M8 system (i82544), I don't get any info on supported media?
> aboyd
Networking Drivers
http://community.qnx.com/sf/go/post14631
In terms of the ifconfig, I wonder if there's some sort of
incompatibility with the NetBSD phy library built into libnbdrvr?  Did
you take the code directly from the NetBSD 4 code base?  It's possible
that there's a PHY being detected that isn't supported (I remember
having to add in a new phy module for the wm driver).
	Robert.
> aboyd
Networking Drivers
> I can see in syslog that it detected support for 1G though.  I'll keep on
> digging.
It just won't work at 1000Mbits.  I'll investigate in the MII stuff but without the specs that is going to be hard.
Maybe an update to MII code is required.
RE: RE: RE: BCM5708
If you look in the dev/bge directory at the init.c file, you'll see
#define DRVR bge
#define PCI_CFATTACH_STRUCT	___CONCAT(DRVR, _pci_ca) /* eg:
ath_pci_ca */
#define DRVR_ENTRY		___CONCAT(DRVR, _entry)  /* eg:
ath_entry */
So all you should have to do is to change that first #define DRVR to bnx
and away you go.
	Robert.
Sent: Tuesday, October 07, 2008 2:56 PM
Subject: Re: RE: RE: BCM5708
> 	Robert.
is undefined. I see it's defined extern in init.c but I can't find where
bge_pci_ca either.
> > Hi Mario:
> > different driver:
> > 	Robert.
> > Subject: BCM5708
> doc
> support
> > - Mario
> > Networking Drivers
> Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post14626
