Forum Topic - memcpy() : (14 Items)
memcpy()
Hi Robert,
This is Shannon again, recently we have been observing some problems while testing our WIFI resource manager which
manage wireless driver in security mode;
1. packet content has been cut off; when our AP set up the mode to both WPA and WPA2, the scan results received from
ieee80211 driver showed only WPA, seems that WPA2 ie has been lost; but APs with either one mode set are fine;
2. getting scan results via select() will either time out or encounter count errors when a lot of APs (roughly more than
 20) presents;
memcpy() does not guarantee to work on overlapping buffer, my question is have you seen these problems before? I think
at least this routine is very suspicious especially there are larger buffers involved, could you let me know the reason
why this has not been changed to memmove()?
Shannon
Re: memcpy()
On Tue, Sep 16, 2008 at 06:00:35PM -0400, Shannon Gu wrote:
> Hi Robert,
than 20) presents;
Which instance of memcpy() are you refering to?
Re: memcpy()
the one in ieee80211_ioctl_getscanresults() and related functions.
Thx,
Shannon
RE: memcpy()
> memcpy() in ieee80211_ioctl_getscanresults()
Could you explain how the source and destination
pointers of the three memcpy()'s in
ieee80211_ioctl_getscanresults() could be overlapping?
I've looked through the source, and it isn't obvious
to me (sorry).
aboyd
Re: memcpy()
> Thx,
> Shannon
I don't see an issue with the three memcpy()s in
ieee80211_ioctl_getscanresults().  They're
copying from various dests to a new buffer on the
stack.  The buffer on the stack then gets copied
out to userland with copyout().
Re: memcpy()
> > Thx,
> > Shannon
                       srcs
> -seanb
RE: memcpy()
Out of curiosity, why would you think that there's a problem with the
memcpy?  Do you know for sure that all of the scan information is being
retrieved?
Don't know if this will help, but you can turn on debugging in the
802.11 stack
The debug information dump is compiled in and enabled / disabled using
sysctls. If you do:
 sysctl -a | grep 80211
with a WiFi driver, you'll see net.link.ieee80211.debug and
net.link.ieee80211.vap0.debug sysctls.
   sysctl -w net.link.ieee80211.debug = 1
   sysctl -w net.link.ieee80211.vap0.debug=0xffffffff
turns on the debug output and now when you type "sloginfo" you'll see
the debug log output being generated.
	Robert.
From: Shannon Gu [mailto:community-noreply@qnx.com]
Sent: Tuesday, September 16, 2008 6:32 PM
To: drivers-networking
Subject: Re: memcpy()
Thx,
Shannon
Networking Drivers
http://community.qnx.com/sf/go/post13528
Re: RE: memcpy()
Robert,
Apparently I can not turn the debug on, which I have no idea of:
[/fcp/bin]# sysctl -a |grep 80211
net.link.ieee80211.debug = 0
net.link.ieee80211.vap0.parent = ath0
net.link.ieee80211.vap0.debug = 0
net.link.ieee80211.vap0.inact_run = 300
net.link.ieee80211.vap0.inact_probe = 30
net.link.ieee80211.vap0.inact_auth = 180
net.link.ieee80211.vap0.inact_init = 30
net.link.ieee80211.vap0.driver_caps = 126084367
net.link.ieee80211.vap0.bmiss_max = 2
[/fcp/bin]# sysctl -w net.link.ieee80211.vap0.debug = 0xffffffff
sysctl: top level name '' in '' is invalid
[/fcp/bin]# sysctl -w net.link.ieee80211.debug = 1
[/fcp/bin]#
Could you pls. let me know what is wrong here?
Thanks a lot,
Shannon
RE: RE: memcpy()
Try it without the spaces ie
# sysctl -w foo=0
aboyd
Re: memcpy()
Regarding #1 problem in my last post "
ieee80211 driver showed only WPA, seems that WPA2 ie has been lost;"
when I look at source code of ieee80211_ioctl_getscanresults(); I am not quite sure if it can handle mixed mode ( when
both WPA and WPA2 presents)
it seems like only have one place for wpa_ie -- could you shed some lights here?
Thanks a lot,
Shannon
Re: memcpy()
> and WPA2, the scan results received from ieee80211 driver showed only WPA,
>  sure if it can handle mixed mode ( when both WPA and WPA2 presents)
> here?
> Thanks a lot,
> Regards,
> Shannon
I think that is a bug of netbsd and even head of it. I debugged stack for another problem and found: in the scan
structure there is only one scan.wpa so it caused if in a beacon there are more than one ELEMID_VENDOR(if not wme) or
ELEMID_RSN then it will only save the last one. Perhaps most likely RSN is not the last:( so you will only see WPA not
WPA2. Of course I don't know whether there is standard for this?
and Linux seems working well with this case:(
it is not memcpy problem anyway:)
Re: memcpy()
Frame 11 (166 bytes on wire, 166 bytes captured)
    Arrival Time: Apr  8, 2009 22:04:17.420002000
    [Time delta from previous captured frame: 0.021305000 seconds]
    [Time delta from previous displayed frame: 0.021305000 seconds]
    [Time since reference or first frame: 0.425976000 seconds]
    Frame Number: 11
    Frame Length: 166 bytes
    Capture Length: 166 bytes
    [Frame is marked: False]
    [Protocols in frame: radiotap:wlan]
Radiotap Header v0, Length 25
    Header revision: 0
    Header pad: 0
    Header length: 25
    Present flags: 0x0000086f
        .... .... .... .... .... .... .... ...1 = TSFT: True
        .... .... .... .... .... .... .... ..1. = Flags: True
        .... .... .... .... .... .... .... .1.. = Rate: True
        .... .... .... .... .... .... .... 1... = Channel: True
        .... .... .... .... .... .... ...0 .... = FHSS: False
        .... .... .... .... .... .... ..1. .... = DBM Antenna Signal: True
        .... .... .... .... .... .... .1.. .... = DBM Antenna Noise: True
        .... .... .... .... .... .... 0... .... = Lock Quality: False
        .... .... .... .... .... ...0 .... .... = TX Attenuation: False
        .... .... .... .... .... ..0. .... .... = DB TX Attenuation: False
        .... .... .... .... .... .0.. .... .... = DBM TX Attenuation: False
        .... .... .... .... .... 1... .... .... = Antenna: True
        .... .... .... .... ...0 .... .... .... = DB Antenna Signal: False
        .... .... .... .... ..0. .... .... .... = DB Antenna Noise: False
        .... .... .... .... .0.. .... .... .... = FCS in header: False
        .... .... .... .0.. .... .... .... .... = Channel+: False
        0... .... .... .... .... .... .... .... = Ext: False
    MAC timestamp: 0
    Flags: 0x00
        .... ...0 = CFP: False
        .... ..0. = Preamble: Long
        .... .0.. = WEP: False
        .... 0... = Fragmentation: False
       ...0 .... = FCS at end: False
        ..0. .... = Data Pad: False
        .0.. .... = Bad FCS: False
        0... .... = Short GI: False
    Data Rate: 1.0 Mb/s
    Channel frequency: 2457 [BG 10]
    Channel type: 802.11b (0x00a0)
        .... .... ...0 .... = Turbo: False
        .... .... ..1. .... = Complementary Code Keying (CCK): True
        .... .... .0.. .... = Orthogonal Frequency-Division Multiplexing (OFDM): False
        .... .... 1... .... = 2 GHz spectrum: True
        .... ...0 .... .... = 5 GHz spectrum: False
        .... ..0. .... .... = Passive: False
        .... .0.. .... .... = Dynamic CCK-OFDM: False
        .... 0... .... .... = Gaussian Frequency Shift Keying (GFSK): False
        ...0 .... .... .... = GSM (900MHz): False
        ..0. .... .... .... = Static Turbo: False
        .0.. .... .... .... = Half Rate Channel (10MHz Channel Width): False
        0... .... .... .... = Quarter Rate Channel (5MHz Channel Width): False
    SSI Signal: -35 dBm
    SSI Noise: 0 dBm
    Antenna: 1
IEEE 802.11 Beacon frame, Flags: ........
    Type/Subtype: Beacon frame (0x08)
    Frame Control: 0x0080 (Normal)
        Version: 0
        Type: Management frame (0)
        Subtype: 8
        Flags: 0x0
            DS status: Not leaving DS or network is operating in AD-HOC mode (To DS: 0 From DS: 0) (0x00)
            .... .0.. = More Fragments: This is the last fragment
            .... 0... = Retry: Frame is not being retransmitted
            ...0 .... = PWR MGT: STA will stay up
            ..0. .... = More Data: No data buffered
            .0.. .... = Protected flag: Data is not protected
            0... .... = Order flag: Not strictly ordered
    Duration: 0
   Destination address: Broadcast (ff:ff:ff:ff:ff:ff)
    Source address: Cisco-Li_a1:83:64 (00:21:29:a1:83:64)
    BSS Id: Cisco-Li_a1:83:64 (00:21:29:a1:83:64)
    Fragment number: 0
    Sequence number: 30
IEEE 802.11 wireless LAN management frame
    Fixed parameters (12 bytes)
        Timestamp:...
RE: memcpy()
Definitely.  This might be one of those bugs that we can report back to
the NetBSD folks as well.
  R.
Sent: Wednesday, April 08, 2009 10:08 PM
    Frame Number: 11
    Header revision: 0
    Header pad: 0
    Header length: 25
True
True
False
False
False
False
    MAC timestamp: 0
    Flags: 0x00
    Data Rate: 1.0 Mb/s
(OFDM): False
False
False
False
    SSI Signal: -35 dBm
    SSI Noise: 0 dBm
    Antenna: 1
        Version: 0
        Subtype: 8
        Flags: 0x0
    Duration: 0
   Destination...
RE: memcpy()
> probably I need to file a bug for this.
Yes, please create a PR for this
(and add aboyd and seanb as cc).
Good work!
aboyd
