Chris Richter(deleted)
09/04/2008 7:47 AM
post12805
Hi all,
I have the following problem:
I want to send a file from a windows pc (standard dos ftp client)
to a QNX Board, using xtemac IP core and devn-xtemac.so
If I send a file, it is almost completely received by the ftpd QNX.
In 50% of all FTP transfers the last TCP package is not received.
If the last TCP package in the FTP transfer has a special size
(e.g. 687 bytes), then the problem happens. It depend not
on the content of the package (I overwrote the content to
prove that). It depends only on the size of the last TCP package
of the FTP file transfer.
I'm using
- xtemac Xilinx IP core
- devn-xtemac.so
(calling /sbin/io-net -d xtemac ioport=0x80400000,irq=1,mac=00ee998283 -ptcpip)
- QNX 6.3.0 SP3
Does anyone has a suggestion what the problem could be?
Thank you and best regards,
Chris
Robert Craig
RE: FTP Problems with xtemac
Robert Craig
09/04/2008 10:29 AM
post12820
This sound awfully familiar... I'll do some digging around but I seem
to remember that the last time that I saw something like this, it turned
out to be a problem with the driver occasionally losing a receive
interrupt. The packets get left in the hardware buffers and are
retrieved when the next packet comes in when the driver drops into a
polling loop. Depending upon the traffic patterns, this would result in
the last packet getting stuck in the hardware.
One thing that would be worthwhile trying is to ping the board
from the windows PC as soon as the FTP session gets stuck. If the pings
go through, does your FTP session all of a sudden complete?
Robert.
From: Chris Richter [mailto:community-noreply@qnx.com]
Sent: Thursday, September 04, 2008 7:48 AM
To: drivers-networking
Subject: FTP Problems with xtemac
Hi all,
I'm using
- devn-xtemac.so
-ptcpip)
- QNX 6.3.0 SP3
Chris
Networking Drivers
http://community.qnx.com/sf/go/post12805
Re: RE: FTP Problems with xtemac
09/04/2008 10:57 AM
post12821
No, if the FTP session gets stuck, and I try a ping, nothing happens
to the FTP transfer.
The ping itself works.
The only thing, which is missing, is the "226 Transfer Complete" message
from the QNX board.
But it seems, that the ftpd does not get the last package, although it
is sent by the ftp client (I sniffed the data traffic with ethereal).
The file in the shared memory has exactly the size = file_size - size_last_tcp_package.
But back to your interrupt assumption:
Is it possible that there is a register etc., which is
used by the driver to decide whats the interrupt reason (e.g.
by using a bit), and this check fails?
If the last package is not received from the ftpd, then there is
a retransmit of the FTP client. Sometimes, this retransmit helps,
sometimes not.
Thank you,
Christian Richter
Robert Craig
RE: RE: FTP Problems with xtemac
Robert Craig
09/04/2008 12:15 PM
post12837
Hi Christian:
We're in the process of getting you a copy of the driver source
for you to build and try out.
Robert.
Sent: Thursday, September 04, 2008 10:58 AM
Subject: Re: RE: FTP Problems with xtemac
pings
from the QNX board.
sometimes not.
Thank you,
Christian Richter
Networking Drivers
http://community.qnx.com/sf/go/post12821
Re: RE: RE: FTP Problems with xtemac
09/10/2008 3:50 AM
post13133
thank you, with the source code this problem was solved.
All I had to do was to compile the source code using
the correct device id.
[The error was that in 50% of all testcases the ftp transfer fails, if the
last TCP packet size modulo 4 is equal to 0.]
But: I have found a new bug (which was already existing
in the previous version of the xtemac driver, I checked this):
- The network cable is unplugged, reboot of the board
- Calling "io-net xtemac ...", works, io-net process is running in the background
- ifconfig en0 193.168.0.127, fails, "ifconfig: socket: Address family not supported by protocol family", /dev/socket
not existing ...
So it is not possible to start the board without network connection,
plug in the cable during runtime, and get the network working during
runtime of the board.
- However, if I redo the ifconfig two times:
- ifconfig en0 193.168.0.192 => works
- ifconfig en0 193.168.0.127 => works
Remark:
Current version:
CvsId[] UNUSED = "$RCSfile: receive.c,v $ $Revision: 156645 $ $Date: 2007-10-24 16:48:07 +0200 (Wed, 24 Oct 2007) $";
Previous version:
CvsId[] UNUSED = "$RCSfile: receive.c,v $ $Revision: 150010 $ $Date: 2007-07-20 17:24:35 -0400 (Fri, 20 Jul 2007) $";
Which of the source code of the xtemac files are responsible/related to
the network configuration?
Best regards,
Christian Richter
Robert Craig
RE: RE: RE: FTP Problems with xtemac
Robert Craig
09/10/2008 7:49 AM
post13142
Hi Christian:
The "Address family not supported" means that the IP stack hasn't been started, so what must be happening is that
the driver is "waiting" somewhere during initialization and this prevents io-net from initializing the IP stack.
Normally during bootup we add a "waitfor /dev/en0" "waitfor /dev/socket" in the startup script after starting io-net,
but if the driver doesn't initialize without a cable being plugged in, then this will obviously be a problem.
With the cable plugged in at the beginning, does everything initialize as expected?
Without the cable plugged in, will ifconfig eventually show an interface or does it always return with an error? What
does pidin report in this case?
Robert.
Sent: Wed 9/10/2008 3:50 AM
Subject: Re: RE: RE: FTP Problems with xtemac
not existing ...
Remark:
Current version:
Previous version:
Best regards,
Christian Richter
Networking Drivers
http://community.qnx.com/sf/go/post13133
Re: RE: RE: RE: FTP Problems with xtemac
09/10/2008 9:59 AM
post13149
Hi Robert,
> the startup script after starting io-net, but if the driver doesn't initialize
Yes, because the board reboots again and again.
> expected?
Yes, in this case, everything works fine.
> does it always return with an error? What does pidin report in this case?
If I call ifconfig without configuration parameter, it fails, if the network cable is unplugged.
But then, if I call the ifconfig with configuration parameter, sometimes it works, sometimes not.
Pidin reports:
1155081 1 sbin/io-net 10r SIGWAITINFO
1155081 2 sbin/io-net 21r RECEIVE 5
1155081 3 sbin/io-net 10r RECEIVE 1
1155081 4 sbin/io-net 10r RECEIVE 1
1155081 5 sbin/io-net 20r RECEIVE 9
So far, I can not determine the "special" condition.
How can I continue?
Best regards,
Christian
Robert Craig
Robert Craig
09/10/2008 3:32 PM
post13201
Hi Christian:
I've created a PR to (PR60894) that you can use to get
information on how the debugging is going.
Robert.
Sent: Wednesday, September 10, 2008 3:50 AM
the
background
not supported by protocol family", /dev/socket not existing ...
Remark:
Current version:
Previous version:
Best regards,
Christian Richter
Networking Drivers
