Forum Topic - BCM5755 driver not starting?: (5 Items)
I have an HP dual core system, and am having trouble with the bge
driver.
The Broadcom Ethernet is part of the 975X chipset on the motherboard.  I
am trying to use the bge driver with io-pkt-v4.
Pci -v shows the BCM5755 driver:
VID=0x14e4, DID 0x167b
This is apparently started as part of the PCI enumeration.
But, when I run ifconfig, I only get an entry for lo0, none for en0.
What is wrong?
Keith
RE: BCM5755 driver not starting?
Looking at the source, I don't think that did is
in the bge_products[] array in if_bge.c so the
driver will not automatically detect and run on
it.
However, I believe Rob recently added support
for cmd line options for the bsd drivers.  Have
you tried specifying "did=0x167b" to the bge
driver, started with the verbose option, and
slogger running?
aboyd
The enumerators also don't yet use the devnp drivers while we're trying
to sort out what appears to be some sort of compatibility issue between
qnet and the BSD ported drivers.
The BCM driver that's in use by the enumerators in 6.4 today is the
io-net tigon3 driver which looks like it should work with that DID.
   Robert.
From: Andrew Boyd [mailto:community-noreply@qnx.com]
Sent: Monday, August 11, 2008 3:18 PM
To: drivers-networking
Subject: RE: BCM5755 driver not starting?
it.
slogger running?
aboyd
Networking Drivers
http://community.qnx.com/sf/go/post11653
If you want to use the BSD driver you can start it by hand:
- slay off io-net* / io-pkt*
# io-pkt -dbge ...
From: Robert Craig [mailto:community-noreply@qnx.com]
Sent: Mon 8/11/2008 5:02 PM
   Robert.
it.
slogger running?
aboyd
Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post11657
Comparing our source to the latest bge driver source it
appears support for the 5755 was added post NetBSD 4.0
which is what our devnp-bge driver is based on.
Sent: Mon 8/11/2008 3:18 PM
it.
slogger running?
aboyd
Networking Drivers
Attachment: Text winmail.dat 2.81 KB
