Forum Topic - parse error before `::' on PPC build: (4 Items)
When my program includes this file:
ppc8260.h
which in turn includes the file:
/../qnx630/target/qnx6/usr/include/ppc/cache.h
The compiler gives me an error on this line:
   __asm__ __volatile__( "dcbf 0,%0;" :: "r" (__dst));
The error is:
/.../qnx630/target/qnx6/usr/include/ppc/cache.h:25: parse error before ‘::’
1) What is this error about? And
2) When I build the ethernet driver through the QNX supplied makefile this same file is included in all the modules, yet
 it doesn’t produce an error. Only when my program includes this file do I get the error. I’ve use all the same
compiler options that the make file does. So why just for my file?
Re: parse error before `::' on PPC build
> ppc8260.h
> The error is:
> /.../qnx630/target/qnx6/usr/include/ppc/cache.h:25: parse error before ???::???
yet it doesn???t produce an error. Only when my program includes this file do I get the error. I???ve use all the same
> Thanks
I can't think of anything off hand.  You might making the .i
(preprocessed file) in both instances and compare the difference.
This has been fixed in our trunk lib/cache
The C++ compiler was getting confused by the :: - add a space in between the two colons, wherever you seen them in that
file.
In future it's a good idea to note that you are using C++ - most people here will assume you are using C.
Cheers,
Colin
>> ppc8260.h
>> The error is:
>> Thanks
> -seanb
> Networking Drivers
> http://community.qnx.com/sf/go/post11196
cburgess@qnx.com
Thanks. Actually I was using C. The problem was I inadvertently invoked the C++ compiler ('QCC' vs. 'qcc'). Good to know
 about the double colon thing though.
