Forum Topic - devn-e1000: (10 Items)
devn-e1000
Can't find the original post, but Hugh posted an experimental devn-e1000.so for me to try.  It's been over a month, just
 got time to try it now.
It doesn't detect network connection. The status as reported by nicinfo says "Unknown". Once after a reboot I got it to
indicated "0 Mb/s half-duplex".
The same hardware is handled fine by devn-i82544.so
Mario
RE: devn-e1000
Please try this updated version and let me know if it resolves the
problem.
From: Mario Charest [mailto:mcharest@zinformatic.com]
Sent: Monday, July 21, 2008 4:54 PM
To: drivers-networking
Subject: devn-e1000
devn-e1000.so for me to try.  It's been over a month, just got time to
try it now.
says "Unknown". Once after a reboot I got it to indicated "0 Mb/s
half-duplex".
Mario
Networking Drivers
http://community.qnx.com/sf/go/post10831
Attachment: Text devn-e1000.so 146.49 KB
Re: RE: devn-e1000
> problem.
No go.   If I force the speed and duplex setting it works though.
I have attached the sloginfo info.
Attachment: Text sloginfo.txt.txt 23.43 KB
RE: RE: devn-e1000
Mario,
Please try the attached driver. I have tested this one on the same
hardware device ID that you have and it works fine for me.
Thanks, Hugh.
Sent: Tuesday, August 12, 2008 9:25 AM
Subject: Re: RE: devn-e1000
> problem.
Networking Drivers
http://community.qnx.com/sf/go/post11675
Attachment: Text devn-e1000.so 146.46 KB
Re: RE: RE: devn-e1000
> Mario,
All the test I did so far was on a 100Mbit Switch. Given you said it was working for you I assumed there had to be
something else different in our respective setup.  I tried connecting to a 1Gig port on that switch ( it as 1 1Gig port)
 and what do you know it worked.
I then tried going back to 100Mbit and same results, no connection.
With 100MBits the status leds on both the switch and card stay off, as if the cable was never connected.
RE: RE: RE: devn-e1000
That's strange, as I specifically tested it on both 100Mb and Gigabit
and it worked fine. What type of 100Mb switch do you have?
Sent: Tuesday, August 12, 2008 11:31 AM
Subject: Re: RE: RE: devn-e1000
> Mario,
working for you I assumed there had to be something else different in
( it as 1 1Gig port) and what do you know it worked.
Networking Drivers
http://community.qnx.com/sf/go/post11689
Re: RE: RE: RE: devn-e1000
Cisco Catalist 3350.  I will try with other models.
Tried with a Cisco 2940 and a old 10Mbit hub.  Refuses to autodetect but 1G. Tried 2 cards and 2 cables.
> > Mario,
> Networking Drivers
RE: RE: RE: RE: devn-e1000
I don't know why we always seem to have problems with Cisco switches. I
don't have one here, so I will have to see what I can do. It won't be
right away, as I have other priorities right now.
Sent: Tuesday, August 12, 2008 1:49 PM
Subject: Re: RE: RE: RE: devn-e1000
> > Mario,
was
switch
> Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post11698
Re: RE: RE: RE: RE: devn-e1000
Thanks.  Meanwhile I'll keep on testing at 1Gig to see if it resolves our other problem.
