Forum Topic - WLAN among qnx with Orinoco 802.11b pc card: (16 Items)
i configured the wlan with 3 qnx6.3.2 machines, the problem was that the machine could not ping thru one another, i
think the driver add on should be okay, here is my script:
io-net -d orinoco channel=11,network=mywork,mode=adhoc -p tcpip
ifconfig en0 192.168.1.1
and the nicinfo output:
ORiNOCO 802.11 Wireless Ethernet Controller
Physical Node ID ........................... 00022D 01B57F
Current Physical Node ID ................... 00022D 01B57F
Current Operation Rate ..................... 11.00 Mb/s half-duplex
Active Interface Type ...................... Unknown
Maximum Transmittable data Unit ............ 1514
Maximum Receivable data Unit ............... 1514
Hardware Interrupt ......................... 0x3
I/O Aperture ............................... 0x300 - 0x33f
Station Name ...............................
Network Name (SSID) ........................
Channel: ................................... 4294967295
BSS Type ................................... Unknown
Packets Transmitted OK ..................... 5
Bytes Transmitted OK ....................... 210
Packets Received OK ........................ 3
Bytes Received OK .......................... 0
Hope anybody could figure out this problem, thx.
Eric
RE: WLAN among qnx with Orinoco 802.11b pc card
You should maybe add a "sleep 3" or a "waitfor /dev/io-net/en0" in your
script before performing the ifconfig. It also appears that the nicinfo
you have in incompatible with the network driver, as the SSID and
channel are not being displayed correctly. Also, IRQ 3 is normally used
for serial ports, so this could also be a problem. If you are using
devp-pccard, try starting it with a different IRQ with the '-i' command
line option.
Sent: Tuesday, June 24, 2008 4:38 AM
To: drivers-networking
Subject: WLAN among qnx with Orinoco 802.11b pc card
machine could not ping thru one another, i think the driver add on
Eric
Networking Drivers
http://community.qnx.com/sf/go/post9546
Re: RE: WLAN among qnx with Orinoco 802.11b pc card
thx, actually i typed the above commands in the terminal after its boot up, so no need to wait
yes, i am also confused about this, but the orinoco 802.11b pc card only goes with this driver, and in ap mode, it also
displayed like this, but could work very fine.
> line option.
the "pin" output gave me the IRQ for this network pc card, so 3 should be okay? thx
> From: Eric Dong [mailto:eric.dongxx@gmail.com]
> Eric
> Networking Drivers
RE: RE: WLAN among qnx with Orinoco 802.11b pc card
Are you saying that the wireless card worked OK in ap mode with IRQ 3?
If so, then IRQ 3 should be fine. Are you starting all adhoc machines
with the same SSID and channel?
Sent: Tuesday, June 24, 2008 11:11 AM
Subject: Re: RE: WLAN among qnx with Orinoco 802.11b pc card
your
goes with this driver, and in ap mode, it also displayed like this, but
command
> line option.
be okay? thx
the
> Eric
> Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post9590
Re: RE: RE: WLAN among qnx with Orinoco 802.11b pc card
yes, AP mode works fine, and previously i was able to make the adhoc work, but i just have no ideas why it could not
work now.
i started all the orinoco cards on the 3 machines with "io-net -d orinoco channel=11,network=mywork,mode=adhoc -p tcpip"
. so they should have the same ssid and channel. anything else i can check? thx
RE: RE: RE: WLAN among qnx with Orinoco 802.11b pc card
I have setup 2 laptops here with an Orinoco wireless card in one and a
Prism in the other, and set them both up in adhoc mode without any
problems. The Orinoco is also on I/O port 0x300 and IRQ 3 and is working
fine.
One thing that you can try is to slay devp-pccard and start it as
"devp-pccard ss -m", then restart io-net and see if that works.
Sent: Tuesday, June 24, 2008 11:08 PM
Subject: Re: RE: RE: WLAN among qnx with Orinoco 802.11b pc card
work, but i just have no ideas why it could not work now.
orinoco channel=11,network=mywork,mode=adhoc -p tcpip". so they should
Networking Drivers
http://community.qnx.com/sf/go/post9640
Re: RE: RE: RE: WLAN among qnx with Orinoco 802.11b pc card
thx. when i used "devp-pccard ss -m", the pin output gave me the irq 11 instead of the previous 3, and then i tried to
add the driver and ping the other machine, when i checked the nicinfo, it showed that it didnot transmit any packets.
but in the previous case with irq=3, the number of transmitted packets would increase when it tried to ping the other
machine. so i think "devp-pccard ss -m" didnot work for me.
another problem i detected today: after several ping pkts sent out, from the nicinfo output, the number of transmitted
packets increased which should be right, however on the other qnx machine, in nicinfo, the number of received packets
did not increase correspondingly, so any other configurations or check can i make here?
And could you please paste the "nicinfo" output, "pin" of your orinoco machine? thx
Eric
> fine.
> Networking Drivers
RE: RE: RE: RE: WLAN among qnx with Orinoco 802.11b pc card
I have attached the output of nicinfo and pin to this e-mail.
Have you tried different channels for the adhoc problem?
Sent: Thursday, June 26, 2008 2:16 AM
Subject: Re: RE: RE: RE: WLAN among qnx with Orinoco 802.11b pc card
instead of the previous 3, and then i tried to add the driver and ping
transmit any packets. but in the previous case with irq=3, the number of
the nicinfo output, the number of transmitted packets increased which
number of received packets did not increase correspondingly, so any
machine? thx
Eric
working
> fine.
> Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post9694
Attachment: Text orinoco.nicinfo 1.03 KB Text orinoco.pin 265 bytes
Re: RE: RE: RE: RE: WLAN among qnx with Orinoco 802.11b pc card
thx, Hugh.
today i mounted the orinoco card in my xp lattop, second orinoco card on another laptop with qnx 6.3.2, and third
orinoco card on the pc104 computer stack with qnx 6.3.2 image. the situation was like this:
winxp and qnx laptop could ping thru each other in the adhoc mode, while the pc104 sent out ping packets to winxp, the
packet sniffer on winxp could only see the packets pc104 sent to it, and meanwhile winxp should have replied back, but
the pc 104 had no response. in fact, nicinfo on pc104 told me that the number of received packets didnot increase
accordingly. so what may be the reasons here? thx
Eric
RE: RE: RE: RE: RE: WLAN among qnx with Orinoco 802.11b pc card
It sounds as though you might have an interrupt problem on the PC104.
Sent: Friday, June 27, 2008 5:54 AM
Subject: Re: RE: RE: RE: RE: WLAN among qnx with Orinoco 802.11b pc card
thx, Hugh.
another laptop with qnx 6.3.2, and third orinoco card on the pc104
the pc104 sent out ping packets to winxp, the packet sniffer on winxp
have replied back, but the pc 104 had no response. in fact, nicinfo on
Eric
Networking Drivers
http://community.qnx.com/sf/go/post9764
Re: WLAN among qnx with Orinoco 802.11b pc card
what kind of interrupt problem?  thx
Maybe the interrupt is not working. Have you tried another interrupt?
Sent: Friday, June 27, 2008 9:01 AM
Subject: Re: WLAN among qnx with Orinoco 802.11b pc card
Networking Drivers
http://community.qnx.com/sf/go/post9771
> Networking Drivers
yepp, adhoc finally worked after i tried "devp-pccard ss -m", and changed the irq number, huh? thx so much. how can the
problem of irq come out?
Eric
The "ss -m" option to devp-pccard routes ISA interrupts to PCI, which
changes the interrupt line. Obviously the previous interrupt wasn't
working.
Sent: Friday, June 27, 2008 10:46 AM
> Networking Drivers
changed the irq number, huh? thx so much. how can the problem of irq
come out?
Eric
Networking Drivers
http://community.qnx.com/sf/go/post9782
sorry, pops up another problem.
after the two network cards started, the orinoco wifi card could only work for quite a short while, then i could not
ping thru it from my host.
then i "slay io-net" and started only the orinoco wifi card, then the wifi worked very well. what might be the reasons
here? thx
Eric
Do you slay dhcp.client before running your network script?
Sent: Tuesday, July 01, 2008 9:55 AM
work for quite a short while, then i could not ping thru it from my
host.
wifi worked very well. what might be the reasons here? thx
Eric
Networking Drivers
http://community.qnx.com/sf/go/post9883
