Forum Topic - i82544: (15 Items)
i82544
Hello back again on the i82544 and Intel Pro 1000 PCIe.
Seems to work better when using transmit and receive descriptor at 1024 and the thread priority at 100.
However I still have some issue with what I think is the negotiation speed.  And can't quite put my finger on it but
here is what I found so far; two computers connected to a cisco switch, there is nothing else on the switch.
Performance is bad, a pidin -n takes up to 5 seconds.  nicinfo show not error and it report 1000m/bits full duplex so is
 the switch.  Then I try to plug the computers with a crossed cable, that doesn't work at all.
After rebooting the computers now I get the performance I'm expecting.  I then connect the comptuers back to the switch
and now negotiation works ( those switch takes 30 to "negotiate"), but then the performance drops again.
Tried many switches/computers/network card ;-)
RE: i82544
When I get some free time, I work on this driver to update it, but
unfortunately there is not much free time right now. If this is a
priority for you, then I suggest that you contact your sales rep to
escalate this problem.
From: Mario Charest [mailto:mcharest@zinformatic.com]
Sent: Wednesday, June 11, 2008 9:22 AM
To: drivers-networking
Subject: i82544
speed.  And can't quite put my finger on it but here is what I found so
the switch.  Performance is bad, a pidin -n takes up to 5 seconds.
nicinfo show not error and it report 1000m/bits full duplex so is the
I then connect the comptuers back to the switch and now negotiation
drops again.
Networking Drivers
http://community.qnx.com/sf/go/post8973
Re: RE: i82544
Thanks Hugh,
I was hoping that the negotiation part could be taken out of the context of a major rework of the driver ;)
Cheers,
Mario
RE: i82544
If you can try out io-pkt with the NetBSD wm driver and compare it to
the native devnp-i82544 driver, that might also give us some ideas as to
what to look for (although I'm not sure how right now :>)
	Robert.
Sent: Wednesday, June 11, 2008 9:35 AM
Subject: RE: i82544
Subject: i82544
drops again.
Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post8975
Re: RE: i82544
I'm on it.
> 	Robert.
> From: Hugh Brown [mailto:hsbrown@qnx.com]
> Subject: RE: i82544
> Subject: i82544
> drops again.
> Networking Drivers
> Networking Drivers
Re: RE: i82544
I tried with  the wm driver.  This one I could switch to cross cable then back to the switch or force the switch to
100Mbits and it works fine.  As for the performance it looks ok but within 2-3 minutes of light network activity ( pidin
 -n ) io-pkt will sigsegv or it will display the "Out of interrupt event message"
I haven't tried devnp-i82544 yet.
- Mario
Re: RE: i82544
I tried with both wm and devnp-i82544, both detect speed/duplex setting just fine.
devnp-i82544 is slow, even at 100Mbits ( so it's not timing issues with 1000Mbits )
with wm it seems fast as expected but hard to say because it crashes before I have time to run enough test.
I will try 6.3.2 devn-i82544 which is a pain because we have to specify the MAC addresses and device/vendor id, but
maybe it will give you guys some clues where to look.
Meanwhile I'll talk to our management  to get them to talk with QSS sales rep to try to escalate this ( even send you
hardware )
RE: RE: i82544
Try adding and irq_thresh=8000 as an option to the devnp-i82544 driver
and see if that changes the behaviour.  This is the maximum number of
interrupts per second that the card will generate and it can make quite
a change to the performance characteristics.  I'm surprised that the wm
driver is crashing. Is there anything from sloginfo that might point to
a problem?
	Robert.
Sent: Wednesday, June 11, 2008 4:39 PM
Subject: Re: RE: i82544
to
just fine.
1000Mbits )
the MAC addresses and device/vendor id, but maybe it will give you guys
sales rep to try to escalate this ( even send you hardware )
Networking Drivers
http://community.qnx.com/sf/go/post9028
Re: RE: RE: i82544
use devnp-wm.so doesn't describe any option.  There must be some ?
> a problem?
> 	Robert.
> to
> just fine.
> 1000Mbits )
> Networking Drivers
RE: i82544
Right now, the ported netbsd drivers have no options.  In the BSD world,
you can't pass in command line options since the drivers come up when
the kernel does.  We're in the process of updating some of the
infrastructure to support some options generically and fully ported
drivers will have other options available.
	Robert.
Sent: Wednesday, June 11, 2008 5:23 PM
Subject: Re: RE: RE: i82544
quite
wm
to
> a problem?
> 	Robert.
to
as
> to
setting
> just fine.
with
> 1000Mbits )
specify
guys
> Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post9032
Re: RE: RE: i82544
> a problem?
Check the attached file:
> 	Robert.
Attachment: Text sloginfo.txt 19.09 KB
RE: RE: RE: i82544
I see a culprit:
Jun 11 21:31:14    7    15     0 qnet(L4): l4_rx():
qos_verify_rx_conn_seq() failed: nd 37 conn 2
Jun 11 21:31:16    2    14     0 WARNING: mclpool limit reached;
increase NMBCLUSTERS
Jun 11 21:31:16    7    15     0 qnet(L4): en_iopkt_alloc_tx_pkt():
can't allocate mcluster for ifp 80deb40 (Not enough memory)
Now all we need to do is figure out why....
	Robert.
Sent: Wednesday, June 11, 2008 5:51 PM
to
> a problem?
> 	Robert.
Networking Drivers
http://community.qnx.com/sf/go/post9035
Re: RE: RE: RE: i82544
I found a work around. We also use a dual port version of that card ( VID 8086, DID = 105e ).  Out of desperation I
tried it out and so far everything looks good ( with devn-i82544).
If you would like me to run some test for the devnp-wm and the single port card I'd be happy to contribute ;-)
javascript:if%20(validateCreatePost(document.createPost))%20{%20submitForm(document.createPost,%20'submit');%20}%20else%
20{%20void(0)%20}
> I see a culprit:
> 	Robert.
> to
> > a problem?
> > 	Robert.
> Networking Drivers
RE: RE: RE: RE: i82544
Hi Mario,
Please will you give the attached early experimental driver a test and
let me know how it works. I have changed the name to devn-e1000.so, as
this is a port of the Intel driver. This driver will also work with the
i82544.
Thanks, Hugh.
Sent: Thursday, June 12, 2008 9:44 AM
Subject: Re: RE: RE: RE: i82544
VID 8086, DID = 105e ).  Out of desperation I tried it out and so far
rm(document.createPost,%20'submit');%20}%20else%20{%20void(0)%20}
> I see a culprit:
> 	Robert.
> to
> > a problem?
> > 	Robert.
> Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post9044
Attachment: Text devn-e1000.so 175.14 KB
RE: RE: i82544
Hi Mario:
	Can you try out the attached io-pkt driver (x86) and see if the
performance is better?  Don't forget the irq_thresh=8000 option.
	Robert.
to
just fine.
1000Mbits )
Networking Drivers
Attachment: Text devnp-i82544.so 50.21 KB
