Forum Topic - Unable to load packet filter lsm: (7 Items)
I'm trying to compile and load the simple packet filter from documentation (http://www.qnx.com/developers/docs/7.0.0/
index.html#com.qnx.doc.core_networking/topic/filtering_PF.html)
I use SDP 7.0 and RTOS vm on vmware also 7.0 version.
the code compiles successfully:
qcc -Wl,-E -Vgcc_ntox86 -c -Wp,-MMD,build/x86-release/src/filter_1.d,-MT,build/x86-release/src/filter_1.o -o build/x86-
release/src/filter_1.o -I /home/alexandr/qnx700/target/qnx7/usr/include/io-pkt/ -Wall -fmessage-length=0 -O2 -fPIC  src/
filter_1.c
src/filter_1.c: In function 'deinit_module':
src/filter_1.c:67:16: warning: implicit declaration of function 'pfil_head_get' [-Wimplicit-function-declaration]
     pfh_inet = pfil_head_get(PFIL_TYPE_AF, AF_INET);
src/filter_1.c:67:14: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
src/filter_1.c:71:5: warning: implicit declaration of function 'pfil_remove_hook' [-Wimplicit-function-declaration]
     pfil_remove_hook(input_hook, NULL, PFIL_IN | PFIL_WAITOK,
src/filter_1.c:75:14: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
     pfh_inet = pfil_head_get(PFIL_TYPE_IFNET, 0);
src/filter_1.c: In function 'pfil_entry':
src/filter_1.c:95:14: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
src/filter_1.c:99:5: warning: implicit declaration of function 'pfil_add_hook' [-Wimplicit-function-declaration]
     pfil_add_hook(input_hook, NULL, PFIL_IN | PFIL_WAITOK,
src/filter_1.c:104:14: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
     pfh_inet = pfil_head_get(PFIL_TYPE_IFNET,0);
qcc -Wl,-E -Vgcc_ntox86 -shared -o build/x86-release/libfilter_1.so   build/x86-release/src/filter_1.o
but when I try to load my lsm:
# mount -vvv -Tio-pkt /root/lsm-filter.so
Parsed: mount from [/root/lsm-filter.so] mount on [NULL] type [io-pkt]
exec: mount_io-pkt -o rw -o implied -o nostat /root/lsm-filter.so /
Using internal mount (mount_io-pkt not found)
Type    [io-pkt] Flags 0x80080000
Device  [/root/lsm-filter.so] Directory [/]
Options [NULL]
mount: Can't mount / (type io-pkt)
mount: Possible reason: No such device or address
and in slog I can see only such line:
Feb 12 13:48:15.543                    iopkt.81934          main_buffer      0  Unable to load /root/lsm-filter.so:
(null)
did anybody face such problem? could anybody help me with this?
Re: Unable to load packet filter lsm
Take a look at net/pfil.h and you will find all those warnings you are getting are because you are building without
_KERNEL and QNX_MFIB defined. If you define those then that should clean up your warnings and the symbols should then
correspond to those in io-pkt and your code should work.
I added those defines and warnings gone. But I still have the same error by lsm mount.
io-pkt will call the entry function in the lsm so add some debugging prints to that to determine what is going wrong.
I added extra logs, but it looks like lsm loading failed before my code execution. Maybe I do something wrong, but I
didn't find any more information about packet filter development in official documentation.
I just want to intercept network traffic from/to my network device.
Either the dlopen() isn't able to open your library (bad path to it, bad permissions, built for the wrong processor type
 etc) or the dlsym() isn't finding the "iopkt_lsm_entry" symbol that is generated by the line at the end of the file:
struct _iopkt_lsm_entry IOPKT_LSM_ENTRY_SYM(pfil) =
  IOPKT_LSM_ENTRY_SYM_INIT(pfil_entry);
My vm is x86 architecture:
# uname -m
x86pc
and my lsm library has the same permissions as lsm-pf-v4.so does:
# ls -l /lib/dll/lsm-libfilter.so
-rwxrwxr-x   1 root      root           7384 Feb 13 14:43 /lib/dll/lsm-libfilter.so
# ls -l /lib/dll/lsm-pf-v4.so
-rwxrwxr-x   1 root      root         239208 Feb 28  2017 /lib/dll/lsm-pf-v4.so
my code:
#include <sys/types.h>
#include <errno.h>
#include <sys/param.h>
#include <sys/conf.h>
#include <sys/socket.h>
#include <sys/mbuf.h>
#include <net/if.h>
#include <net/pfil.h>
#include <netinet/in.h>
#include <netinet/ip.h>
#include <stdio.h>
#include <unistd.h>
#include <fcntl.h>
#include <sys/slog.h>
#include <sys/slogcodes.h>
#include "sys/io-pkt.h"
#include "nw_datastruct.h"
static int input_hook(void *arg, struct mbuf **m,
                      struct ifnet *ifp, int dir, int fib)
    slogf(_SLOG_SETCODE(_SLOGC_TEST, 2),
                      _SLOG_ERROR, "input");
    return 0;
static int output_hook(void *arg, struct mbuf **m,
                      _SLOG_ERROR, "output");
    return 0;
static int deinit_module(void);
static int iface_hook(void *arg, struct mbuf **m,
	                  _SLOG_ERROR,"Iface hook called ... ");
    if (m == (struct mbuf **)PFIL_IFNET_ATTACH) {
    	                  _SLOG_ERROR,"Interface attached\n");
    } else if (m == (struct mbuf **)PFIL_IFNET_DETACH) {
    	                  _SLOG_ERROR,"Interface detached\n");
        deinit_module();
    return 0;
static int ifacecfg_hook(void *arg, struct mbuf **m,
	                  _SLOG_ERROR,"Iface cfg hook called with 0x%p\n", m);
    return 0;
    struct pfil_head *pfh_inet;
    if (pfh_inet == NULL) {
        return ESRCH;
                     pfh_inet);
    pfil_remove_hook(output_hook, NULL, PFIL_OUT | PFIL_WAITOK,
                     pfh_inet);
            return ESRCH;
    pfil_remove_hook(ifacecfg_hook, NULL, PFIL_IFNET, pfh_inet);
    pfil_remove_hook(iface_hook, NULL, PFIL_IFNET | PFIL_WAITOK,
                         pfh_inet);
                  _SLOG_ERROR,
				  "Unloaded pfil hook\n");
    return 0;
int pfil_entry(void *dll_hdl, struct _iopkt_self *iopkt,
               char *options)
	printf("pfil_entry+++++++++ enter\n");
        return ESRCH;
                  pfh_inet);
    pfil_add_hook(output_hook, NULL, PFIL_OUT | PFIL_WAITOK,
                  pfh_inet);
            return ESRCH;
    pfil_add_hook(iface_hook, NULL, PFIL_IFNET, pfh_inet);
    pfil_add_hook(ifacecfg_hook, NULL, PFIL_IFADDR, pfh_inet);
                      _SLOG_ERROR, "Loaded pfil hook\n");
    return 0;
and Makefile:
ARTIFACT = libfilter_1.so
#Build architecture/variant string, possible...
