Forum Topic - ifconfig command does not show all the interface after adding new interface: (6 Items)
I am using panda board for adding new network driver.
for showing example I used Sample Driver (sam.c) provided by qnx.
But following result can be reproduce with other drivers too.
here is the excerpts of the command i ran  and  text added between /*  */ are my comments.
As you see below, en0 interface disappears as soon as another new driver is added.
Is there anything 'ifconfig' looking for? Why it is not showing all the interfaces?
# io-pkt-v4-hc -dsmsc9500 mac=5e2404007ede          /* Loading the ethernet driver */
# ifconfig
en0: flags=80008802<BROADCAST,SIMPLEX,MULTICAST,SHIM> mtu 1500
        address: 5e:24:04:00:7e:de
        media: Ethernet 100baseTX full-duplex
        status: active
# ifconfig en0 10.10.70.189
# ifconfig        /* ifconfig correctly shows the two
interfaces lo0 and en0)
en0: flags=80008843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST,SHIM> mtu 1500
        address: 5e:24:04:00:7e:dd
        status: active
        inet 10.10.70.189 netmask 0xff000000 broadcast 10.255.255.255
# io-pkt-v6-hc -i1 -dsam                                                  /* loading the second driver (sample driver) *
# ifconfig        /* it shows sam0 correctly but en0
disappeard !!!! */
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
sam0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 1500
        address: 00:01:02:03:04:05
Re: ifconfig command does not show all the interface after adding new interface
Hi Rajesh
By calling io-pkt-v6-hc you are starting a new network stack with no interfaces except lo0.
To add a new network interface to a running stack you must use the mount command:
mount -T io-pkt devnp-sam.so
My goal is to start two network stacks io-pkt-v4-hc (habdling ipv4 only) and io-pkt-v6-hc (for ipv6)
and make sure that it is shown in ifconfig.
in the above command sequence, even if I run "mount -T io-pkt devnp-sam.so"
ifconfig does not show en0 interface at all.
See command/output below below
(1) Why ifconfig not showing en0? pidin shows both stacks running.
(2) I want make two separate interfaces one for ipv4 (exclusively for ipv4) and other ipv6. What are the correct steps.
# ifconfig
        status: active
# io-pkt-v6-hc
# mount -T io-pkt devnp-sam.so
# ifconfig
# pidin arg
     pid Arguments
   49170 io-pkt-v4-hc -dsmsc9500 mac=5e2404007edd
   69651 io-pkt-v6-hc
  102420 pidin arg
There are some important parameters missing in the startup of the 2nd io-pkt that are causing it to clobber the 1st
invocation of io-pkt.
1st stack (instance 0) startup is fine:
# io-pkt-v4-hc -dsmsc9500 mac=5e2404007edd
# ifconfig
        status: active
2nd stack needs both an instance and a prefix so it does not clobber the 1st (instance 0) stack:
# io-pkt-v6-hc -i1 -dsam -p tcpip prefix=/alt
# SOCK=/alt ifconfig
For all commands referencing the 1st stack (instance 0), issue them directly without a SOCK environment variable.
For all commands referencing the 2nd stack (instance 1 at prefix /alt), the SOCK=/alt environment variable is needed.
Prefixes other than '/alt' can be used -- reference the io-pkt documentation for use of the prefix parameter.
for some reason I do not see newly added interface even if I provide the prefix
# ifconfig
        status: active
        inet 10.10.70.189 netmask 0xfffffe00 broadcast 10.10.71.255
        inet6 fe80::5c24:4ff:fe00:7edd%en0 prefixlen 64 scopeid 0x2
# ls -l /alt/dev/socket/
total 0
srw-rw-rw-  1 root      root              0 Jan 07 22:04 1
srw-rw-rw-  1 root      root              0 Jan 07 22:04 17
Is your sam driver actually successfully creating an interface?
