Forum Topic - [atheros] status is always no carrier: (6 Items)
hello,drivers-networking engineer:
    My Development Environment
      Host: Ubuntu 14.       Qnx: SDP 7.0      Target: iMx6q Sabre Auto/AI
I face a strange problem when i am debugging  phy(atheros ar8095) driver on imx6q board,  when i have started the io-pkt
 service and configed ip, the nicinfo changes below:
  --> nicinfo
    fec0:
  i.MX6 Ethernet Controller
  Link is DOWN
  Physical Node ID ........................... 000012 345678
  Current Physical Node ID ................... 000012 345678
  Current Operation Rate ..................... Unknown
  Active Interface Type ...................... MII
    Active PHY address ....................... 0
  Maximum Transmittable data Unit ............ 1500
  Maximum Receivable data Unit ............... 1500
  Hardware Interrupt ......................... 0x96
  Hardware Interrupt ......................... 0x97
  Memory Aperture ............................ 0x2188000 - 0x2188fff
  Memory Aperture ............................ 0x2098000 - 0x2098fff
and the network port status is :
  -->ifconfig
fec0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
	address: 00:00:12:34:56:78
	media: Ethernet 10baseT full-duplex (none)
	status: no carrier
	inet 192.168.1.11 netmask 0xffffff00 broadcast 192.168.1.255
	inet6 fe80::200:12ff:fe34:5678%fec0 prefixlen 64 scopeid 0x11
whatever the configuration of the phy has made,the  fec0's status is always no carrier. by the way, cable is connected
to my win10 computer.
do you have any suggestions to my problem? thank u!
Attachment: HTML sf-attachment-mime35413 3.54 KB
Re: [atheros] status is always no carrier
Are you using a crossover cable to connect to your win10 machine? Have you tried plugging the cable into a switch?
-pkt service and configed ip, the nicinfo changes below:
      --> nicinfo
        fec0:
      Link is DOWN
      -->ifconfig
    	status: no carrier
connected to my win10 computer.
    Networking Drivers
    http://community.qnx.com/sf/go/post118034
    To cancel your subscription to this discussion, please e-mail drivers-networking-unsubscribe@community.qnx.com
回复: [atheros] status is always no carrier
maybe the problem i described is not clear,  i have already pluggled  the cable into my board. the detail operations
list as below:
1.plugged the cable into my embeded board, and another port connect to my computer(win10).
2.power on the board without starting the network service in the bulid configeration file.  etc,
    #display_msg Starting Networking
    #io-pkt-v6-hc -dmx6x
    #if_up -p fec0
    #ifconfig fec0 up
    #dhclient -nw fec0
3. the led of the net port in board and computer is on and blinking, at this time  the phy is not init because i do not
start the service.
4. when i input io-pkt-v6-hc -d mx6x in the command line, the led is off, and the link becomes down, the nicinfo and
ifconfig info in the last email
the key point of this problem is why the status of ifconfig info is always  no carrier,  not  active. Have you ever
encountered such problems before?
another question is  the Current Operation Rate of nicinfo is always unknown, what does this means ? which register is
this read?
thank you very much!
------------------ 原始邮件 ------------------
发件人: "Hugh Brown";<community-noreply@qnx.com>;
发送时间: 2017年9月15日(星期五) 晚上8:26
收件人: "drivers-networking@community.qnx.com"<drivers-networking@community.qnx.com>;
主题: Re: [atheros] status is always no carrier
      --> nicinfo
        fec0:
      Link is DOWN
      -->ifconfig
    	status: no carrier
    Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post118038
Attachment: HTML sf-attachment-mime35420 5.92 KB
Re: 回复: [atheros] status is always no carrier
Starting the mx6x driver will turn the PHY off, but when you run “ifconfig fec0 up” the PHY should initialize and the
link should come up. It sounds as though you have a configuration problem with the PHY.
The nicinfo state of “unknown” is because the link isn’t up. Then link state is normally read from the PHY status
register.
 list as below:
        #if_up -p fec0
        #ifconfig fec0 up
        #dhclient -nw fec0
not start the service.
is this read?
the io-pkt service and configed ip, the nicinfo changes below:
          --> nicinfo
            fec0:
          Link is DOWN
          -->ifconfig
        	status: no carrier
        whatever the configuration of...
回复: Re: 回复: [atheros] status is always no carrier
ok, i will examine the configuration on  the phy , maybe there is a difference  between ar8035 and ar8031, but i do not
 aware of it now.
thank you for helping me , thanks!
发送时间: 2017年9月18日(星期一) 晚上8:18
主题:  Re: 回复: [atheros] status is always no carrier
register.
 list as below:
        #if_up -p fec0
        #ifconfig fec0 up
        #dhclient -nw fec0
is this read?
          --> nicinfo
            fec0:
          Link is DOWN
        and the...
Attachment: HTML sf-attachment-mime35432 9.67 KB
hello,Hugh Brown:
   the question that i emailed to you have been sovled, the reason is PHY needs to reset by hardware. however, the
ar8035 datasheet and qnx bsp do not execute this step. when i add this step, PHY can work properly.
register.
 list as below:
        #if_up -p fec0
        #ifconfig fec0 up
        #dhclient -nw fec0
is this read?
          --> nicinfo
            fec0:
          Link is DOWN
Attachment: HTML sf-attachment-mime35475 9.86 KB
