Francisco Barros(deleted)
Intel I210 and I217 Gigabit ethernet support in devnp-e1000.so (qnx 6.5)?
07/26/2017 11:14 AM
post117916
Hi all
I'm trying to play with a new pc card mounting an embedded Intel I210 and I217
Gigabit ethernet device:
Device ID = 1533h, Unknown Unknown (I210)
Device ID = 153ah, Unknown Unknown (I217)
but devnp-e1000.so (qnx 6.5) cannot recognize it.
Anyone knows if is there version of devnp-e1000 for supporting that devices (I210, I217)?
thanks a lot
Francisco
Hugh Brown
Re: Intel I210 and I217 Gigabit ethernet support in devnp-e1000.so (qnx 6.5)?
Hugh Brown
07/27/2017 8:48 AM
post117919
We will have to post an updated driver to our web site. I will let you
know when this has been done.
On 2017-07-26, 11:14 AM, "Francisco Barros" <community-noreply@qnx.com>
wrote:
>Hi all
>I217
>thanks a lot
>Francisco
>Networking Drivers
>http://community.qnx.com/sf/go/post117916
07/27/2017 10:58 AM
post117920
Ok Hugh, I'll be watching your post reply,
thank you so much!!!
Hugh Brown
Hugh Brown
07/27/2017 2:21 PM
post117921
You can get the latest driver here
http://community.qnx.com/sf/frs/do/viewRelease/projects.bsp/frs.network_dri
ver_updates.latest_io_pkt_network_drivers_0?_message=1501179473726
This driver should work with both your device Ids
On 2017-07-27, 10:58 AM, "Francisco Barros" <community-noreply@qnx.com>
>Networking Drivers
>http://community.qnx.com/sf/go/post117920
07/28/2017 9:53 AM
post117922
Thank you Hugh, but I can´t view the page.
The following message appear after to link.
"The page you requested cannot be found.
If you feel you have received this message in error, please contact the TeamForge administrator."
Hugh Brown
Hugh Brown
07/28/2017 9:58 AM
post117923
OK, I have attached the driver to this email.
On 2017-07-28, 9:53 AM, "Francisco Barros" <community-noreply@qnx.com>
>Networking Drivers
>http://community.qnx.com/sf/go/post117922
Mario Charest
Mario Charest
08/11/2017 5:05 PM
post117958
Note : This driver needs the lastest x86 BSP otherwise you get :
ldd : FATAL : Unresolved symbol "nic_delay" called from devnp-e1000.so
Serkan Basaran
Serkan Basaran
11/27/2017 8:39 AM
post118243
Could you give the link of appropriate BSP's link? We could not run this library, yet.
Hugh Brown
Hugh Brown
11/27/2017 9:20 AM
post118245
The latest e1000 driver can be found here
http://community.qnx.com/sf/go/projects.bsp/frs.network_driver_updates.latest_io_pkt_network_drivers_0
Networking Drivers
http://community.qnx.com/sf/go/post118243
To cancel your subscription to this discussion, please e-mail drivers-networking-unsubscribe@community.qnx.com
Santosh Patil(deleted)
07/09/2018 8:44 AM
post118919
I'm trying devnp-e1000.so.
I copied that particular file into home folder and ran
/sbin/io-pkt-v4-hc
mount -T io-pkt /home/devnp-e1000.so
after running this I can see interfaces in
nicinfo and also in gui-network-interface.
But soon after running this command I'm getting following error and /sbin/io-pkt-v4-hc process gets halted
"ldd:FATAL: Unresolved symbol "stk_context_callback_2" called from devnp-e1000.so"
AM I missing to load another library which is required ?
Hugh Brown
Hugh Brown
07/09/2018 8:47 AM
post118920
You will need the latest io-pkt-v4-hc to resolve this symbol. I'll have to see where you can find it and get back to you
/sbin/io-pkt-v4-hc
Networking Drivers
http://community.qnx.com/sf/go/post118919
Hugh Brown
Hugh Brown
07/09/2018 9:35 AM
post118922
I have attached the latest io-pkt-v4-hc.
/sbin/io-pkt-v4-hc
Networking Drivers
07/16/2018 7:17 AM
post118956
Hello Hugh,
Thanks a lot for your help. They did actually work.
Just one thing, they could not start on start-up, I had to run the script manually to get divers up and running. Which I
can put into some boot-up script.
Hugh Brown
Hugh Brown
07/16/2018 8:35 AM
post118957
Please post your build file, so that I can see what you are doing.
Thanks, Hugh.
On 2018-07-16, 6:59 AM, "Santosh Patil" <community-noreply@qnx.com> wrote:
Hello Hugh,
Which I can put into some boot-up script.
Networking Drivers
http://community.qnx.com/sf/go/post118956
07/16/2018 8:38 AM
post118958
It's full fledged OS, installed. From QNX 6.5 NTO ISO.
I just replaced your provided files.
Hugh Brown
Hugh Brown
07/16/2018 8:44 AM
post118959
The enumeration files are out of date, so you will have to do the following:
Edit the /etc/rc.d/rc.local file and add the following
slay -f io-pkt-v4 io-pkt-v4-hc io-pkt-v6-hc dhcp.client
sleep 2
io-pkt-v4-hc -de1000
if_up -p wm0
dhcp.client -iwm0
You can modify the above to suite your needs.
Hugh.
Networking Drivers
http://community.qnx.com/sf/go/post118958
