Forum Topic - io-pkt leak data section - ppc8260 ethernet driver: Page 1 of 2 (34 Items)
we do see on our system that io-pkt while running shows in different scenarios a memory leak. The memory in the data
section grows until the system has no resources (RAM) left and crashes!
QNX Version used:
QNX6.5 SP2 - PPC Platform
NIC Driver uses:
from BSP 8260 pq2fads (QNX      PQ2FADS BSP V1.0.2 (File revision: 1.43))
Start sequence of drivers (extract from a start up script):
mount -T io-pkt -o channel=1,mac=$MAC1 devn-ppc8260-nxa.so
mount -T io-pkt -o channel=2,mac=$MAC2 devn-ppc8260-nxa.so
mount -T io-pkt -o channel=3,mac=$MAC3 devn-ppc8260-nxa.so
netmanager -r all -f $NETCONFIG
mount -T io-pkt -o bind=ip0,resolve=dns,resolve=autoresolve /usr/lib/lsm-qnet.so
Other embedded sysetm are also connected on the network. If we now perform ls /net/$NODENAME the new node do appear.
By simple performing the "df -h" we can reproduce the leak.
The issue is, that our application does not execute this command - but we can see that ~4.5 hours the data section
(pidin -mem) of io-pkt do increase by 4kBytes.
Any help is welcome, also if more information is needed - please let me know
Kind Regards
Thomas L.
Attachment: Text pidin_mem_log.txt 1.04 MB
Re: io-pkt leak data section - ppc8260 ethernet driver
This is most probably a driver issue, but this driver wasn¹t written by
QNX and we don¹t have the source code.
On 2016-11-15, 3:58 AM, "Thomas Luetzel" <community-noreply@qnx.com> wrote:
>Hello,
>scenarios a memory leak. The memory in the data section grows until the
>QNX Version used:
>NIC Driver uses:
>can see that ~4.5 hours the data section (pidin -mem) of io-pkt do
>know
>Kind Regards
>Thomas L.
>Networking Drivers
>http://community.qnx.com/sf/go/post117111
if needed, wanted or allowed from QNX point of view - I can attach the driver code.
Kind Regards
If you don¹t have a support contract with QNX, you will have to speak to
your sales rep to sort something out.
On 2016-11-16, 8:43 AM, "Thomas Luetzel" <community-noreply@qnx.com> wrote:
>Hi,
>driver code.
>Kind Regards
>Networking Drivers
>http://community.qnx.com/sf/go/post117123
Some more test results,
I just started the OS and killed all Ethernet related things.
I started io-pkt-v4 again and kept a script in the background running:
while [ 0 -lt 1 ]
do
        df >> /mnt/flash.log
        sleep 1
done
RESULT after 30 minutes:
COMMAND: pidin -l -d 100 io-pkt-v4 mem
     pid tid name               prio STATE            code  data        stack
208330770   1 usr/bin/io-pkt-v4   21r SIGWAITINFO      572K  308K  4096(516K)*
208330770   2 usr/bin/io-pkt-v4   21r RECEIVE          572K  308K  8192(132K)
            libc.so.3          @fe300000             512K   12K
... CUT ...
208330770   1 usr/bin/io-pkt-v4   21r SIGWAITINFO      572K  312K  4096(516K)*
208330770   2 usr/bin/io-pkt-v4   21r RECEIVE          572K  312K  8192(132K)
... CUT ...
208330770   1 usr/bin/io-pkt-v4   21r SIGWAITINFO      572K  316K  4096(516K)*
208330770   2 usr/bin/io-pkt-v4   21r RECEIVE          572K  316K  8192(132K)
... CUT ...
208330770   1 usr/bin/io-pkt-v4   21r SIGWAITINFO      572K  320K  4096(516K)*
208330770   2 usr/bin/io-pkt-v4   21r RECEIVE          572K  320K  8192(132K)
... CUT ...
208330770   1 usr/bin/io-pkt-v4   21r SIGWAITINFO      572K  324K  4096(516K)*
208330770   2 usr/bin/io-pkt-v4   21r RECEIVE          572K  324K  8192(132K)
... CUT ...
208330770   1 usr/bin/io-pkt-v4   21r SIGWAITINFO      572K  328K  4096(516K)*
208330770   2 usr/bin/io-pkt-v4   21r RECEIVE          572K  328K  8192(132K)
... CUT ...
208330770   1 usr/bin/io-pkt-v4   21r SIGWAITINFO      572K  332K  4096(516K)*
208330770   2 usr/bin/io-pkt-v4   21r RECEIVE          572K  332K  8192(132K)
... CUT ...
208330770   1 usr/bin/io-pkt-v4   21r SIGWAITINFO      572K  336K  4096(516K)*
208330770   2 usr/bin/io-pkt-v4   21r RECEIVE          572K  336K  8192(132K)
What make io-pkt-v4 to allocate memory ????
Thanks in advance for any help
Thomas L.
io-pkt will allocate memory as it is needed, so the data size will carry
on increasing, but should stabilize after a while.
On 2016-11-16, 10:44 AM, "Thomas Luetzel" <community-noreply@qnx.com>
>while [ 0 -lt 1 ]
>do
>        sleep 1
>done
>stack
>4096(516K)*
>8192(132K)
>... CUT ...
>stack
>4096(516K)*
>8192(132K)
>... CUT ...
>4096(516K)*
>8192(132K)
>... CUT ...
>4096(516K)*
>8192(132K)
>... CUT ...
>stack
>4096(516K)*
>8192(132K)
>... CUT ...
>stack
>4096(516K)*
>8192(132K)
>... CUT ...
>stack
>4096(516K)*
>8192(132K)
>... CUT ...
>stack
>4096(516K)*
>8192(132K)
>Thomas L.
>Networking Drivers
>http://community.qnx.com/sf/go/post117125
Understood,
I will keep the system/test running over night and will let you know if the memory stabalized.
If yes - good, then I have to look into another direction, BUT IF NOT?
Again no network driver is mounted as you can see in the pidin log, so for me the original request/answer that there is
a bug in the driver itself can be crossed out - as it is not mounted/loaded/started....
Thanks for the replies
Kind Regards
Thomas
kept on running the test.
io-pkt.-v4 data section of the memory is NOT settling down!
# pidin -l -d 100 -p io-pkt-v4 mem
208330770   1 usr/bin/io-pkt-v4   21r SIGWAITINFO      572K 4184K  4096(516K)*
208330770   2 usr/bin/io-pkt-v4   21r RECEIVE          572K 4184K  8192(132K)
script code:
while [ 0 -lt 1 ]
do
	df -h > /dev/null
done
what can cause the system/io-pkt to eat up memory while executing this script. If we find out the reason, then I can
have a look into our application what might cause the same issue.
Thanks in advance
Thomas L.
What version of the O/S are you running, and what is the command line you
are using to start io-pkt? The output from pidin would also be useful.
On 2016-11-18, 5:31 AM, "Thomas Luetzel" <community-noreply@qnx.com> wrote:
>Hello,
>stack
>4096(516K)*
>8192(132K)
>script code:
>while [ 0 -lt 1 ]
>do
>	df -h > /dev/null
>done
>script. If we find out the reason, then I can have a look into our
>Thanks in advance
>Thomas L.
>Networking Drivers
>http://community.qnx.com/sf/go/post117141
we do have two system running
1. QNX 6.5.0 2010/07/09-14:35:59EDT
# use -i io-pkt-v4-hc
NAME=io-pkt-v4-hc
DESCRIPTION=TCP/IP protocol module.
DATE=2010/07/09-13:43:56-EDT
STATE=stable
HOST=mainbuild
USER=builder
VERSION=6.5.0
TAGID=89
2. QNX 6.5.0 2012/06/20-13:49:31EDT
# use -i io-pkt-v4
NAME=io-pkt-v4
DATE=2014/10/15-11:25:52-EDT
STATE=stable
HOST=pspbuildvm
USER=pspbuild
VERSION=650SP1-4004
TAGID=5664
on both systems we start io-pkt-v4 the following way:
io-pkt-v4
Both systems showing the same leak behavior.
# pidin -pio-pkt-v4
     pid tid name               prio STATE       Blocked
  393246   1 usr/bin/io-pkt-v4   21r SIGWAITINFO
  393246   2 usr/bin/io-pkt-v4   10r RECEIVE     1
  393246   3 usr/bin/io-pkt-v4   21r RECEIVE     24
  393246   4 usr/bin/io-pkt-v4   10r RECEIVE     28
  393246   5 usr/bin/io-pkt-v4   10r RECEIVE     32
  393246   6 usr/bin/io-pkt-v4   21r RECEIVE     39
  393246   7 usr/bin/io-pkt-v4   10r CONDVAR     (0xfe3cd6a4)
  393246   8 usr/bin/io-pkt-v4   20r RECEIVE     44
  393246   9 usr/bin/io-pkt-v4   10r RECEIVE     36
  393246  10 usr/bin/io-pkt-v4   10r CONDVAR     (0xfe3cc96c)
# pidin -p io-pkt-v4 mem
  393246   1 usr/bin/io-pkt-v4   21r SIGWAITINFO      660K 1172K  8192(516K)*
  393246   2 usr/bin/io-pkt-v4   10r RECEIVE          660K 1172K  8192(132K)
  393246   3 usr/bin/io-pkt-v4   21r RECEIVE          660K 1172K  4096(132K)
  393246   4 usr/bin/io-pkt-v4   10r RECEIVE          660K 1172K  4096(132K)
  393246   5 usr/bin/io-pkt-v4   10r RECEIVE          660K 1172K  4096(132K)
  393246   6 usr/bin/io-pkt-v4   21r RECEIVE          660K 1172K  4096(132K)
  393246   7 usr/bin/io-pkt-v4   10r CONDVAR          660K 1172K  4096(132K)
  393246   8 usr/bin/io-pkt-v4   20r RECEIVE          660K 1172K  4096(132K)
  393246   9 usr/bin/io-pkt-v4   10r RECEIVE          660K 1172K  4096(132K)
  393246  10 usr/bin/io-pkt-v4   10r CONDVAR          660K 1172K  4096(132K)
            devnp-shim.so      @fe386000              36K  4096
            evn-ppc8260-nxa.so @fe390000              48K  4096
            lsm-qnet.so        @fe39d000             188K   44K
            libsocket.so.3     @fe3d7000             184K   24K
            /dev/mem           @80100000 (30000000)        128K
            /dev/mem           @80120000 (30000000)        128K
            /dev/mem           @80140000 (30000000)        128K
Thomas
Unfortunately there is nothing we can do about this without getting access
to your BSP as well as the source to the io-pkt driver. We cannot give you
the latest io-pkt, as it will require the network driver to be re-compiled
with the latest libc and libsocket. Your best bet is to contact your sales
rep and make a formal request to have this work done.
On 2016-11-21, 10:21 AM, "Thomas Luetzel" <community-noreply@qnx.com>
wrote:
>Hi,
>NAME=io-pkt-v4-hc
>STATE=stable
>HOST=mainbuild
>USER=builder
>VERSION=6.5.0
>TAGID=89
># use -i io-pkt-v4
>NAME=io-pkt-v4
>STATE=stable
>HOST=pspbuildvm
>USER=pspbuild
>VERSION=650SP1-4004
>TAGID=5664
>io-pkt-v4
># pidin -pio-pkt-v4
>stack
>8192(516K)*
>8192(132K)
>4096(132K)
>4096(132K)
>4096(132K)
>4096(132K)
>4096(132K)
>4096(132K)
>4096(132K)
>4096(132K)
>Thanks
>Thomas
>Networking Drivers
>http://community.qnx.com/sf/go/post117154
>To...
Hi all,
I just proofed that this issue is also present on an X86 machine!
If downloaded the vmware image from (http://www.qnx.com/download/feature.html?programid=23665) and executed the same
scripte
while [ 0 - lt 1 ]
do
   df >> /dev/null
done
While monitoring via pidin the io-pkt module (pidin -l -d 100 -p io-pkt-v4-hc mem) I can see the memory is increasing,
increasing, increasing, increasing, ...
See attached screenshot.
I think it is now prooven it has nothing todo with my BSP or modified network driver. It is a general issue!
Need help to identify which is causing this memory leak - relation of DF command and io-pkt?
Then I would know what we are doing WRONG in our application which shows the same behavior.
Thank in advance
If needed - how can I file this defect directly to the QNX development team?
Kind Regards
Attachment: Image QNX6.5_vmware_io-pkt.png 78.45 KB
Well then there must be something strange going on on your systems, as I
have a 6.5.0 SP1 x86 machine and have no problem with the data segment
increasing.
On 2016-11-22, 9:29 AM, "Thomas Luetzel" <community-noreply@qnx.com> wrote:
>Hi all,
>the same scripte
>while [ 0 - lt 1 ]
>do
>   df >> /dev/null
>done
>io-pkt-v4-hc mem) I can see the memory is increasing, increasing,
>command and io-pkt?
>the same behavior.
>Thank in advance
>team?
>Kind Regards
>Networking Drivers
>http://community.qnx.com/sf/go/post117158
... ???? it the vmware X86  provided by QNX, downloaded - started. Nothing else done?
I don't really know what I do wrong here?
here some screen recordings what I'm doing.
No magic!
Thanks Hugh for all your help so far
Attachment: Text QNX2.avi 522 KB Text QNX.avi 646.5 KB
Does the x86 data segment on the x86 machine stabilize after a while?
On 2016-11-22, 10:01 AM, "Thomas Luetzel" <community-noreply@qnx.com>
>No magic!
>Networking Drivers
>http://community.qnx.com/sf/go/post117161
No. I just kept it running and it eating up already 5MB
I'm just about to test the same on QNX6.6.0 and let you know
Just used the QNX SDP 6.6.0 runtime ISO for VMware [or virtual machine] to install a virtual machine.
If I do the same test in here
io-pkt-v4-hc is stable! 504K and stable!
But as we have a PPC architecture on or target I can't switch I have to stick with 6.5
Your issue does not reproduce for me on 6.5 VMware image.  Are you sure the number of processes stays constant?  Copies
of sh are being left in memory?
I use the vmware QNX 6.5.0 2012/06/20-13:50:50EDT x86pc x86
Number of processes is constant ~40 (39-40)
Number of threads (pidin info) constant
O.k with every call of "df" it does get a new process ID but the calling shell stays the same.
Of all processes only io-pkt-v4-hc do increase
Kind Regards
What is your "df" output?  I  can't see any relationship of df to network UNLESS there is a sharepoint mounted...
see attached screen shot
Attachment: Image df_QNX_6.5.0.png 136.94 KB
My io-pkt-v4-hc is exactly the same.  Has to be something with the network - but I don't see how it is related to the "
df" call you are making.
What is you replace "df >>/dev/null" with "ls >>/dev/null"... does it have to be "df" to see the leak?
RE: io-pkt leak data section - ppc8260 ethernet driver
A capture with tracelogger should answer all these questions?  Assuming the VM is using the instrumented kernel ?
-----Message d'origine-----
De : Dennis Kellly [mailto:community-noreply@qnx.com]
Envoyé : 22 novembre 2016 11:01
À : drivers-networking <drivers-networking@community.qnx.com>
Objet : Re: io-pkt leak data section - ppc8260 ethernet driver
Networking Drivers
http://community.qnx.com/sf/go/post117170
To cancel your subscription to this discussion, please e-mail drivers-networking-unsubscribe@community.qnx.com
Here is the output from my x86 PC running just io-pkt-v4-hc. I also ran df
-h several times as well, with no difference to the output.
(root) /usr/qnx650/target/qnx6/x86/sbin-> pidin -pio-pkt-v4-hc mem
stack
127537170   1 ./io-pkt-v4-hc      21r SIGWAITINFO      948K  344K
4096(516K)*
127537170   2 ./io-pkt-v4-hc      21r RECEIVE          948K  344K
8192(132K)
            libc.so.3          @b0300000             488K   16K
stack
4096(516K)*
127537170   2 ./io-pkt-v4-hc      10r RECEIVE          948K  344K
8192(132K)
stack
4096(516K)*
8192(132K)
stack
4096(516K)*
8192(132K)
stack
4096(516K)*
8192(132K)
stack
4096(516K)*
8192(132K)
NAME=io-pkt-v4-hc
DATE=2012/06/20-13:36:58-EDT
STATE=stable
HOST=gusbuild4
USER=builder
VERSION=6.5.0
TAGID=650SP1-166
On 2016-11-22, 10:47 AM, "Thomas Luetzel" <community-noreply@qnx.com>
>Networking Drivers
>http://community.qnx.com/sf/go/post117168
