Forum Topic - WI-FI setup: (3 Items)
WI-FI setup
I have Linksys WUSB54GSC dongle which have bcm4320 chipset.
I tried usb it shows dongle is deteced by QNX.
when i run command usb it shows,
Device Address:4
Upstream Host Controller :1
Upstream Device Address:1
Upstream Port:7
Upstream Port Speed:High
Vendor:0x13b1(Broadcom)
Product:0x0026(Compact wireless-G USB Network Adapter with SpeedBooster)
Class:0x02(Communication)
Subclass:0x00
Protocol:0x00
Max PacketSize0:64
Configuration:1
Configuration:1
Attributes:0x00(Bus-Powered)
Max-Power:500mA
I want to setup and to connect it with network/internet.
Re: WI-FI setup
Hi Ankur,
Unfortunately that chipset is not currently supported. I'd suggest either
using a supported chipset or porting a driver for BCM4320.
Mark
Re: WI-FI setup
Thanks, MARK
I found solution  of it. I am usng Airlink101 AWLH3026 PCI card,Which is supported by QNX!
Can you suggest me to send simulation data in Real time over network?
