Forum Topic - QNX 6.5.1 together with Intel i210iT: (4 Items)
we have problems with QNX 6.5.1 and ethernet controller Intel i210iT, driver is e1000. Currently 2 controller are activ
as seen in the attachment pci_i210.txt (Vid=8086, Did=1533) .
Both active controllers are attached via the 2 pci-switches.
The command:
io-pkt-v4 -i2 -d e1000 verbose=4,vid=0x8086,did=0x1533,pci=0 –ptcpip
causes this message in syslog:
Feb 26 19:35:12Â Â Â  2Â Â Â  17Â Â Â Â  0 Bus 5 device 0 - No routing found
Feb 26 19:35:12Â Â Â  5Â Â Â  17Â Â Â Â  0 last_chance on B5:D0:F0 irq 10
Feb 26 19:35:12Â Â Â  2Â Â Â  10Â Â Â Â  0 pci_attach_device failed
Feb 26 19:35:12Â Â Â  2Â Â Â  14Â Â Â Â  0 Unable to init devnp-e1000.so: No such device
The command:
io-pkt-v4 -i3 -d e1000 verbose=4,vid=0x8086,did=0x1533,pci=1 –ptcpip
Feb 26 19:35:48Â Â Â  2Â Â Â  17Â Â Â Â  0 Bus 8 device 0 - No routing found
Feb 26 19:35:48Â Â Â  5Â Â Â  17Â Â Â Â  0 last_chance on B8:D0:F0 irq 11
Feb 26 19:35:48Â Â Â  2Â Â Â  10Â Â Â Â  0 pci_attach_device failed
Feb 26 19:35:48Â Â Â  2Â Â Â  14Â Â Â Â  0 Unable to init devnp-e1000.so: No such device
Using Windows 7 - we can talk to the parts !
What do we make wrong ? We use the latest experimental driver from 2013 since we have not found any more up to date
driver supporting the i210iT.
Do we have to configure anything within the switches ? We only have access to the PEX 8609 part in the controllers,
working in the transparent mode (which is the default configuration). Or do we need a more specific pci driver.
Kind regards
Rainer
Attachment: Text pci_i210.txt 62.83 KB
Re: QNX 6.5.1 together with Intel i210iT
I presume that you are using startup-apic and pci-bios-v2. If this is the
case, then you will have to experiment with IRQs 16 thru 23 on each device
to see which IRQ works. The PCI server is unable to determine the IRQ
routing, so that is why you get the sloginfo messages.
On 2015/2/27, 4:33 AM, "Rainer Faulstich" <community-noreply@qnx.com>
>driver is e1000. Currently 2 controller are activ as seen in the
>The command:
>found
>No such device
>The command:
>found
>No such device
>since we have not found any more up to date driver supporting the i210iT.
>access to the PEX 8609 part in the controllers, working in the
>Kind regards
>Rainer
>Networking Drivers
>http://community.qnx.com/sf/go/post113402
How can we determine which IRQ works and how can we configure the routing ?
Kind regards Rainer
Start the driver with an IRQ, then ifconfig the interface and see if you
ping another machine. If not, try another IRQ and repeat the process.
There is no way to configure the routing, you will just have to start the
driver specifying an IRQ on the command line.
>Kind regards Rainer
>Networking Drivers
>http://community.qnx.com/sf/go/post113490
