Forum Topic - ioctl_socket copyout not working: (4 Items)
Hi All,
I'd like to use ioctl operation to read data from the network driver. ioctl_socket() function returns success, but no
data is copied back from the driver - looks like copyout() function doesn't work as expected. I use network driver 'as
is' - I haven't modified its source code.
Here's sample code from the application:
memcpy(ifd.ifd_name, "dm0", 4);
ifd.ifd_len = sizeof(time);
ifd.ifd_data = &time;
ifd.ifd_cmd = PTP_GET_TIME;
ret = ioctl_socket(sk, SIOCGDRVSPEC, &ifd);
printf("sec=%d, nsec=%d\n", time.sec, time.nsec);
And driver code:
case PTP_GET_TIME:
	if (ifd->ifd_len != sizeof(time)) {
		return EINVAL;
	ti814x_get_time(ti814x,&time);
	if (ISSTACK) {
		return (copyout(&time, (((uint8_t *)ifd) + sizeof(*ifd)),
				sizeof(time)));
	} else {
		memcpy((((uint8_t *)ifd) + sizeof(*ifd)), &time, sizeof(time));
		return EOK;
	break;
copyout() function copies data 'just after' ifd struct. I believe it's some kind of QNX magic to make embedded pointers
work across virtual address spaces. However, from the application side, no data is actually copied to the time structure
. Any ideas why copyout might not work?
regards,
Marcin
Re: ioctl_socket copyout not working
Hi Marcin,
Several points here.
1) We already have a PTP implementation including 802.1AS support. That may be easier than writing your own.
2) ioctl_socket() isn't necessary in 6.5.0 and later, ioctl() handles everything.
3) This ioctl is a fixed length with variable length data afterwards. From the client side (i.e. PTP application) it's
best to use MsgSendv with some IOVs e.g.:
static int imx6x_ioctl( int fd, struct ifdrv *ifd) {
	#define IMX6X_IOCTL_ARRAY_SZ 3
	iov_t siov[IMX6X_IOCTL_ARRAY_SZ];
	io_devctl_t msg;
	msg.i.type        = _IO_DEVCTL;
	msg.i.combine_len = sizeof msg.i;
	msg.i.dcmd        = PTP_IMX6X_INTERNAL_COMMAND;
	msg.i.nbytes      = IOCPARM_LEN((unsigned)PTP_IMX6X_INTERNAL_COMMAND);
	msg.i.zero        = 0;
	SETIOV(&siov[0], &msg, sizeof(io_devctl_t));
	SETIOV(&siov[1], ifd, sizeof(struct ifdrv));
	SETIOV(&siov[2], ifd->ifd_data, ifd->ifd_len);
	return MsgSendv_r(fd, siov, IMX6X_IOCTL_ARRAY_SZ,
					siov, IMX6X_IOCTL_ARRAY_SZ);
The fd is still the same one that you would use for an ioctl() call.
Nick.
Hi Nick,
Thank you for your reply, it works like a charm now.
At the moment I am only interested in this particular ioctl, but I will keep that in mind.
I already knew that, i just copied last version which happened to use ioctl_socket.
To clear things up - is it common that ioctl doesn't handle nested/embedded pointers and I shall always use my own ioctl
 implementation (like in your example)?
Marcin
It's really only SIOCGDRVSPEC and SIOCSDRVSPEC that need this. Most of the time ioctl() will handle the embedded pointer
 fine.
