Forum Topic - QNX 4.2 Realtek 8019 not working: (2 Items)
I bought a realtek 8019 ISA card to replace a faulty EN2000 as i know they work with the same driver.
I also used its DOS configuration utility to setup the same IRQ/IO/MAC as the faulty card so i don't need to replace any
 configuration.
The machine loads with no errors, driver loads fine and the TX light on the card starts to blink as it receives data
from the other nodes. (it's a thinnet bus network)
The problem is that this node does not connect to the QNX network. I will give you some troubleshooting command results:
sin net -> shows only itself
netmap -> is correct and same with the other nodes but in the "Last Fail TX Time" it seems to fail every 10 seconds
netinfo -l -> the card configuration data is correct but all the TX and RX fields are 0 as though it doesnt transmit or
receive anything
netinfo -> every few lines i see errors 33 and 7 with a message "lan hang during TX"
The only thing that differs from the other nodes is that this one carries 2 more unused licenses, but those where
installed by someone else and the license disks don't exist any more.
Is the Lan card faulty or is there a license mismatch? If it's a license problem can i remove those 2 licenses by just
deleting the license files or is there more to it?
I really appreciate all your help!
Re: QNX 4.2 Realtek 8019 not working
This is the wrong conference. You should post this on the QNX4 conference.
>the faulty card so i don't need to replace any configuration.
>the card starts to blink as it receives data from the other nodes. (it's
>RX fields are 0 as though it doesnt transmit or receive anything
>during TX"
>2 more unused licenses, but those where installed by someone else and the
>problem can i remove those 2 licenses by just deleting the license files
>Networking Drivers
>http://community.qnx.com/sf/go/post110869
