Forum Topic - nfm-nraw: (4 Items)
nfm-nraw
I am looking for nfm-nraw in order to be able to write on an ethernet port. I am able to do this with io-pkt but,
unfortunately, it is not compatible with the API I use. So I'd like to know where I can find, nfm-nraw
RE: nfm-nraw
Nfm-nraw uses a filter interface which is no longer supported in io-pkt.
Nfm-nraw isn't one of the source code pieces that have been released on the
foundry given that it's only for io-net.
	Robert.
Sent: Monday, April 21, 2008 11:00 AM
To: drivers-networking
Subject: nfm-nraw
I am able to do this with io-pkt but, unfortunately, it is not compatible
Networking Drivers
http://community.qnx.com/sf/go/post7119
Re: RE: nfm-nraw
I know that nfm-nraw is for  io-net only, but I need io-net because after some tests I discovered that io-pkt did not
support all the functionalities of my API.
Therefore, I want to switch back to io-net.
Maybe It's not the good place to ask, but the question is :where can I find nfm-nraw.so source code or file ?
Or, if not possible, where can I find nfm-bpf.so source code ?
Regards
RE: RE: nfm-nraw
	Unfortunately, io-net is in maintenance mode only so neither
nfm-nraw nor nfm-bpf are code that we intend to generally release at this
point in time.  The best way to get it would be to go through the regular
commercial support channels.  Sorry about that!
	Robert.
Sent: Monday, April 21, 2008 11:18 AM
Subject: Re: RE: nfm-nraw
some tests I discovered that io-pkt did not support all the functionalities
of my API.
Regards
Networking Drivers
http://community.qnx.com/sf/go/post7121
