Forum Topic - Need to understand mbuf w/respect to io-pkt drivers better: (2 Items)
I've been having a very serious problem doing an optimization of a driver and it leads me to believe that I really don't
 understand mbuf's very well, ate least with respect to how io-pkt is using them.
The driver works if I copy data into on transmit and out of on receipt using the m_copydata() and m_copyback() routines.
   I've been trying to switch over to having the hardware move the data directly from the mbuf data buffer (m->m_data).
This always fails.
I was under the (possibly misguided impression) that io-pkt was providing a contiguous buffer the size of MCLBYTES each
time I got an mbuf to transmit.
In particular, I find in the source for the e1000 driver transmit.c code a routine called i82544_defrag() which seems to
 be trying to defragment a packet.   If the data is delivered in a contiguous buffer, why would it ever need to be
defragmented?    If the packet can be fragmented, then my problem is solved, because I will have no option other than
copying it.
Help please.
Re: Need to understand mbuf w/respect to io-pkt drivers better
The transmit routine can be entered with multiple mbufs with mbuf->m_next
chaining the mbufs. The defrag routine is there to copy multiple mbufs
into a single buffer if the driver doesn¹t have sufficient buffers
available to transmit all the fragments.
On 2014/1/17, 1:44 AM, "Mitchell Schoenbrun" <community-noreply@qnx.com>
>and it leads me to believe that I really don't understand mbuf's very
>using the m_copydata() and m_copyback() routines.   I've been trying to
>This always fails.
>a contiguous buffer the size of MCLBYTES each time I got an mbuf to
>transmit.
>a routine called i82544_defrag() which seems to be trying to defragment a
>ever need to be defragmented?    If the packet can be fragmented, then my
>problem is solved, because I will have no option other than copying it.
>Help please.
>Networking Drivers
>http://community.qnx.com/sf/go/post108005
