Networking
Forum Topic - Network throughput test: (8 Items)
I am working on WLAN driver. How do i test the throughput of network card in QNX?
Is there anything similar to iperf(in Linux)?
Also if there are any test suites available to test the driver please let me know.
Thanks & Regards
Arun L Hegde
RE: Network throughput test
If it's a straight socket application, then you should just be able to grab
the source and re-compile under Neutrino (add the -lsocket option to the
compile).  We typically use ttcp, netperf and netio internally.
    Robert.
From: Arun Hegde [mailto:arun.hegde@globaledgesoft.com]
Sent: Monday, April 14, 2008 11:43 AM
To: drivers-networking
Subject: Network throughput test
QNX?
know.
Thanks & Regards
Arun L Hegde
Networking Drivers
http://community.qnx.com/sf/go/post6731
Re: RE: Network throughput test
Hi  Robert,
Can you please provide me those test suites or can i download those suites from QNX site?
Please let me know.
Thanks & Regards
Arun Hegde
I suggest you to download iperf and port it
dast.nlanr.net/Projects/Iperf/
It hardly takes 1-2 days if you are well familiar with QNX.
Avinash.
Hi Robert.
We are testing WLAN performance with QNX
We have the problem that QNX is about 10 times slower than Linux !
Any idea ?
Configuration:
- Ralink WLAN controller
- connected via USB
- MPC5121
- Packet Size 1000 Bytes
Best regards
Lutz
RE: RE: Network throughput test
The ralink driver is a compiled USB driver - we
did not write it, and the source is certainly
publicly available.
A test I might try would be to measure the throughput
of a wired ethernet USB dongle, to try to remove the
wifi variable.
aboyd
clarification: "compiled BSD driver"
aboyd
Re: RE: RE: Network throughput test
My recollection of the BSD based USB drivers was that they weren't the best for speed.  They have a low number of rx and
 tx descriptors (believe it or not, the default is 1 (yup, ONE) of each).  I seem to remember that it's pretty easy to
up the Rx descriptor types, but the Tx required a little bit of extra work (you can take a look at the axe driver source
 to see what was done to increase the descriptors for 6.4.1).  For the URAL driver, these are defined in sys/dev/usb/
if_uralvar.h.
  That being said, the BSD drivers also go through a BSD - QNX conversion layer and that layer definitely introduces a
performance penalty.  A native driver will run faster.  You can take a look at the devnp-axe (BSD) driver versus devn-
asix to get an idea of what a BSD ported USB driver is like when compared to a QNX written driver (and note that devn-
asix is an old-style io-net driver and not a native io-pkt style driver).
    R.
