Forum Topic - How to load devnp-ncm.so in QNX (650SP1) OS?: (3 Items)
I am running QNX OS (650SP1) in VMplayer. I would like to load devnp-ncm.so driver.
I have tried following things -
1) # io-pkt-v4-hc -d /lib/dll/devnp-ncm.so path=/dev/io-usb/io-usb -ptcpip verbose &
2) # io-pkt-v4-hc &
    # mount -T io-pkt devnp-ncm.so
Please give me some suggestion how to load it.
Re: How to load devnp-ncm.so in QNX (650SP1) OS?
You can use either method, but regarding method 1, check the usage
messages for the ncm driver as it provides instructions on how to load
it when you start io-pkt:
# use /lib/dll/devnp-ncm.so
Also check the output of sloginfo after you try to load the driver as it
will indicate initialization errors.
I used following command and it worked -
# io-pkt-v4-hc -d ncm pnp verbose &
or you can specify path i.e. #io-pkt-v4-hc -d ncm pnp path=/lib/dll/devnp-ncm.so verbose &
But make sure the sequence. It matters.
If you give "pnp" after "path" then it will not work.
