Forum Topic - USB Ethernet Dongle with ASIX chipset - traffic goes to localhost: (8 Items)
I'm using a NovPek i.mx6x board and trying to get ethernet working with a Plugable USB2-E1000 USB to Ethernet adapter.
The behavior is really strange.  I've tried this with the stock devn-asix driver for armle-v7 as well as the driver from
 this thread (http://community.qnx.com/sf/go/topc22380).  I've also tried using a powered hub as mentioned in another
thread.
Here are the results of various investigation attempts:
** USB finds device **
# usb -v
USB 0 (EHCI) v1.10, v1.01 DDK, v1.01 HCD
    Control, Interrupt, Bulk(SG), Isoch(Stream), Low speed, High speed
USB 1 (EHCI) v1.10, v1.01 DDK, v1.01 HCD
Device Address             : 1
Upstream Host Controller   : 1
Upstream Device Address    : 0
Upstream Port              : 0
Upstream Port Speed        : High
Vendor                     : 0x0409 (NEC)
Product                    : 0x005a
Device Release             : r1.00
Class                      : 0x09 (Hub)
Subclass                   : 0x00
Protocol                   : 0x01
Max PacketSize0            : 64
Hub Number Ports           : 4
Hub Characteristics        : 0x00a9 (Individual power, Individual over-current)
Hub Power On->Good         : 100 ms
Hub Power Requirements     : 100 mA
Configurations             : 1
  Configuration            : 1
    Attributes             : 0xe0 (Self-powered, Remote-wakeup)
    Max Power              : 100 mA
Device Address             : 2
Upstream Device Address    : 1
Upstream Port              : 4
Vendor                     : 0x0b95 (ASIX Elec. Corp.)
Product                    : 0x1780 (AX88178 )
Device Release             : r0.01
Class                      : 0xff (Vendor-specific)
Subclass                   : 0xff
Protocol                   : 0x00
Configurations             : 1
  Configuration            : 1 (0)
    Attributes             : 0xa0 (Bus-powered, Remote-wakeup)
    Max Power              : 450 mA
** start networking **
# io-pkt-v4 -d asix -ptcpip
# sloginfo
Jan 01 00:00:18    5    14     0 tcpip starting
Jan 01 00:00:18    3    14     0 Unable to attach to pci server: No such file or directory
Jan 01 00:00:18    3    14     0 Using pseudo random generator.  See "random" option
Jan 01 00:00:18    6    10     0 Chipset 88178
Jan 01 00:00:18    5    14     0 ax_enable_88178: eeprom index 0x17 is 0x1b
Jan 01 00:00:18    5    14     0 GPIO Setting 0x33133383
** use dhcp.client  - returns immediately only gives 0.0.0.0  **
# ifconfig
en0: flags=80008802<BROADCAST,SIMPLEX,MULTICAST,SHIM> mtu 1500
        address: 80:3f:d5:08:3d:ba
        media: Ethernet 100baseTX full-duplex
        status: active
# dhcp.client &
[1] 40974
# ifconfig
ifconfig
en0: flags=80008a43<UP,BROADCAST,RUNNING,ALLMULTI,SIMPLEX,MULTICAST,SHIM> mtu 1500
        status: active
        inet 0.0.0.0 netmask 0xff000000 broadcast 255.255.255.255
[1] + Done                 dhcp.client
** nicinfo - device seems to send and receive something **
# nicinfo
en0:
  Asix Ethernet Controller
  Physical Node ID ........................... 803FD5 083DBA
  Current Physical Node ID ................... 803FD5 083DBA
  Current Operation Rate ..................... 100.00 Mb/s full-duplex
  Active Interface Type ...................... MII
    Active PHY address ....................... 2
  Maximum Transmittable data Unit ............ 1514
  Maximum Receivable data Unit ............... 1514
  Promiscuous Mode...
Re: USB Ethernet Dongle with ASIX chipset - traffic goes to localhost
You can try the attached driver.
>Plugable USB2-E1000 USB to Ethernet adapter.  The behavior is really
>well as the driver from this thread
>powered hub as mentioned in another thread.
># usb -v
>Device Address             : 1
>Upstream Port              : 0
>Product                    : 0x005a
>Class                      : 0x09 (Hub)
>Subclass                   : 0x00
>Protocol                   : 0x01
>over-current)
>Configurations             : 1
>  Configuration            : 1
>    Max Power              : 100 mA
>Device Address             : 2
>Upstream Port              : 4
>Subclass                   : 0xff
>Protocol                   : 0x00
>Configurations             : 1
>    Max Power              : 450 mA
># sloginfo
>file or directory
>"random" option
>0x1b
># ifconfig
>        status: active
># dhcp.client &
>[1] 40974
># ifconfig
>ifconfig
>mtu 1500
>        status: active
>** nicinfo - device seems to send and receive something...
Attachment: Text devn-asix.so 92.63 KB
RE: USB Ethernet Dongle with ASIX chipset - traffic goes to localhost
Hugh,
Thanks for sending the new driver, but I'm wondering if I did something
wrong.  I'm getting a huge number or unknown relocation type errors when I
try to run io-pkt-v4 (list is attached).  It looks like this driver is not
detecting libc.so.3.  I have no idea why.
Rob
Attachment: Text Asix driver log.txt 8.27 KB
It would help if I sent you the correct driver! I sent you the x86
version, so here is the armv7 version.
Hugh.
On 2012-10-11 10:09 AM, "Rob Coker" <community-noreply@qnx.com> wrote:
>Hugh,
>Rob
>Networking Drivers
>http://community.qnx.com/sf/go/post96238
Attachment: Text devn-asix.so.armv7 90.32 KB
That loaded a lot better!  I'm still having the same problem - can't get
ping to work.  When I do verbose, it says destination host unreachable and
seems to be sending through 127.0.0.1.  Is there a way to determine whether
this is a driver problem or whether the problem is somewhere else?
I'm puzzled that nicinfo reports packets transmitted & received.  I'm also
puzzled that "route show" shows correct MAC addresses for the hosts on my
network.  So, the device is obviously getting some data through it.
Rob
From: Hugh Brown [mailto:community-noreply@qnx.com]
Sent: Thursday, October 11, 2012 9:19 AM
To: drivers-networking@community.qnx.com
Subject: Re: USB Ethernet Dongle with ASIX chipset - traffic goes to
localhost
It would help if I sent you the correct driver! I sent you the x86 version,
Hugh.
I'll have to try the driver on ARM. The driver runs fine on x86.
>whether
hosts on my
>Rob
>-----Original Message-----
>localhost
>version,
>Hugh.
>Networking Drivers
>http://community.qnx.com/sf/go/post96245
I have run the driver on armv7 and it works just fine with the same device
that you have (0xb95 0x1780).
Hugh.
>whether
hosts on my
>Rob
>localhost
>version,
>Hugh.
>Networking Drivers
I guess that leaves a few options:
1. My dongle is bad
2. There are board differences (like in the USB system) that is breaking
something
3. There is something wrong with my overall QNX installation.
I'll check the dongle on a windows box to see if it works there.
Thanks for the help,
Rob
Sent: Thursday, October 11, 2012 11:52 AM
localhost
Hugh.
>get ping to work.  When I do verbose, it says destination host
>unreachable and seems to be sending through 127.0.0.1.  Is there a way
>to determine whether this is a driver problem or whether the problem is
>somewhere else?
>also puzzled that "route show" shows correct MAC addresses for
the
>hosts on my network.  So, the device is obviously getting some data through
it.
>Rob
>localhost
>Hugh.
>Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post96253
