Forum Topic - micrel ksz 8841-pmqli driver hangs at high data rates: (4 Items)
Our QNX (Version 6.3.0 SP2) Driver hangs up in an application running a micrel ksz 8841-pmqli
in 10MBit simplex mode when much traffic is done.
Operating system:	QNX 6.3.0 SP2
Driver:			NAME=devn-micrel8841.so
			        DESCRIPTION=micrel8841 ethernet driver
			        DATE=2007/08/30-14:47:26-EDT
			       STATE=stable
			       HOST=worldbuild
			       USER=pspbuild
			       Version=630SP3-685
			       TAGID=1602
Opreating mode:     10MBit half duplex
Problem description: The data transfer stops at high data rates (for example at continuous text output
			          in a terminal window). Then Phindows closes the the socket.
			          If this problem occurs, no more ping is possible on this interface.
Observations:		The hardware produces still interupts and these interrupts are also still
			         received by the kernel !
			         But the driver cannot resume the data transfer
			         An umount of the driver followed by a mount of the driver fixes the problem !
			         In other words: it is NO HARDWARE PROBLEM, but a driver problem.
			         If we start the driver using a verbose level < 0xA (less than 0xA), a singular output
                                 is  recorded
                                 in  the  syslog.
			         If we start the driver using verbose level 0xA, also a singular output is recorded
                                 in the syslog, but data rate becomes much reduced, and the drivers does
                                 not hang up.
The board architectural structure is as follows:
   =+===Cpu=============+=    ____ devn-e1000.so (en1)       ___
  \___ io-net (default)
    |                   |                                           __ devn-micrel8841.so  (en0) ___/
   =+=MEPME2============+=    _/                                                       ___ io-net (prefix /GMLRS)
        \__ devn-micrel8841.so  (en0) ___/
(The board MEPME2 contains two controllers of type micrell8841.)
Attachment: Text problem_description.txt 1.74 KB
Re: micrel ksz 8841-pmqli driver hangs at high data rates
Here is the latest version of the driver for you to try.
>			       STATE=stable
>			       HOST=worldbuild
>			       USER=pspbuild
>			       Version=630SP3-685
>			       TAGID=1602
>interface.
>are also still
>fixes the problem !
>problem.
>                                 is  recorded
>                                 in  the  syslog.
>                                 not hang up.
>    |                   |                                           __
>        \__
>Networking Drivers
>http://community.qnx.com/sf/go/post93992
Attachment: Text devn-micrel8841.so 58.36 KB
Unfortunately also this driver you sent us behaves like that one we have in use. If we we login with a phindows window
and move a window around the screen - and so produced a lot of traffic - after some time moving it the driver on the QNX
 target dies.
> >			       STATE=stable
> >			       HOST=worldbuild
> >			       USER=pspbuild
> >			       Version=630SP3-685
> >			       TAGID=1602
> >interface.
> >are also still
> >fixes the problem !
> >problem.
> >0xA), a singular
> output
> >                                 is  recorded
> >                                 in  the  syslog.
> >                                 not hang up.
> >    |                   |                                           __
> >        \__
> >Networking Drivers
I'll take a look at this when I have a chance.
>in use. If we we login with a phindows window and move a window around
>the driver on the QNX target dies.
>> >			       STATE=stable
>> >			       HOST=worldbuild
>> >			       USER=pspbuild
>> >			       Version=630SP3-685
>> >			       TAGID=1602
>>socket.
>> >interface.
>>interrupts
>> >are also still
>> >fixes the problem !
>> >problem.
>>than
>> >0xA), a singular
>> output
>> >                                 is  recorded
>> >                                 in  the  syslog.
>> >                                 not hang up.
>> >    |                   |                                           __
>> >        \__
>> >Networking Drivers
