gao yuan(deleted)
io-pkt mount double rtl839 is failure.
gao yuan(deleted)
01/31/2012 2:22 AM
post91237
Hi:
there are two rtl8139 net card in my board.
I can call io-pkt-hc mount frist card, but when mount second card, the calling is block at there.
when i run QNX6.5 direct on CD, everything is OK.
anybody can help me?
thanks.
dylan.
gao yuan(deleted)
Re: io-pkt mount double rtl839 is failure.
gao yuan(deleted)
01/31/2012 2:23 AM
post91238
In my custom image , Net card init script is :
io-pkt-v4-hc -d rtl pci=0,vid=0x10ec,did=0x8139,irq=0xc
io-pkt-v4-hc -d rtl pci=1,vid=0x10ec,did=0x8139,irq=0xA
After call frist statement , use ifconfig set en0 ip address , spawn qconn ,I can connect target from host IDE .
after second call , target shell is blocking . I can ping target from host , but qconn is disconnected .
Please check attach picture . it is init process when booting by QNX CD.
thanks .
gaoyuan
gao yuan(deleted)
gao yuan(deleted)
01/31/2012 2:23 AM
post91239
I try again.
like this:
io-pkt-hc-v4 -ptcpip
mount -Tio-pkt -o pci=0,vid=0x10ec,did=0x8139,irq=0xf devn-rtl.so
//afer this call , en0 is ready and net connection is OK
mount -Tio-pkt -o pci=1,vid=0x10ec,did=0x8139,irq=0xb devn-rtl.so
same as befor ,system is Pending.
I am desperated.
Gervais Mulongoy
Gervais Mulongoy
01/31/2012 8:30 AM
post91247
Have you tried using two instances of the networking stack as a
temporary workaround?
See the following documentation:
http://www.qnx.com/developers/docs/6.5.0/index.jsp?topic=/com.qnx.doc.neutrino_utilities/i/io-pkt.html
You are looking for option -i. You basically run two io-pkts one for
each driver.
Armin Steinhoff
Armin Steinhoff
01/31/2012 8:46 AM
post91248
how long is "temporary" ??
--Armin
> each driver.
> Networking Drivers
> http://community.qnx.com/sf/go/post91247
gao yuan(deleted)
gao yuan(deleted)
01/31/2012 8:09 PM
post91269
when I need two instances of io-pkt?
every net card need a instance?
dylan
> each driver.
Armin Steinhoff
Armin Steinhoff
01/31/2012 3:23 AM
post91241
when you run QNX6.5 directly from the CD it will start with "pci-bios"
and w/o APIC/MSI support.
You have to expect esoteric problems when you use an SMP image which
includes pci-bios-v2, APIC and MSI support.
This stuff is really in an ALPHA state !
We see this problem again and again together with frustrated customers.
Regards
--Armin
> Hi:
> thanks.
> dylan.
> Networking Drivers
> http://community.qnx.com/sf/go/post91237
gao yuan(deleted)
gao yuan(deleted)
01/31/2012 3:31 AM
post91242
Now How can I do?
dylan
> Regards
> --Armin
> > Hi:
> > thanks.
> > dylan.
> > Networking Drivers
Armin Steinhoff
Armin Steinhoff
01/31/2012 8:29 AM
post91246
Dylan,
if you don't need to support many PCI devices create a boot image with
the old pc-bios server and without APIC/MSI support.
--Armin
Now How can I doï¼
dylan
> Regards
> --Armin
> > Hi:
> > thanks.
> > dylan.
> > Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post91242
gao yuan(deleted)
gao yuan(deleted)
01/31/2012 8:04 PM
post91267
when i use startup-apci and pci-bios-v2
I can mount two devn-rtl.so, create en0 and en1, ifconfig both of them.
but unfortunately, net connection is disconnect ,qconn and ping is failure.
> Dylan,
> --Armin
> Now How can I doï¼
> dylan
> > Hi,
> > Regards
> > --Armin
> > > Hi:
> > > thanks.
> > > dylan.
> > > Networking Drivers
> Networking Drivers
Hugh Brown
Hugh Brown
02/01/2012 7:37 AM
post91276
Are you trying to assign both interfaces on the same subnet? What IP
addresses are you assigning to each interface?
Hugh Brown
QNX Software Systems Limited
1001 Farrar Rd.,
Ottawa. ON. K2K 0B3.
Telephone: 613-591-0931
>failure.
>> Dylan,
>> --Armin
>> Now How can I doï¼
>> dylan
>> > Hi,
>>customers.
>> > Regards
>> > --Armin
>> > > Hi:
>>the
>> > > thanks.
>> > > dylan.
>> > > Networking Drivers
>> Networking Drivers
>Networking Drivers
>http://community.qnx.com/sf/go/post91267
gao yuan(deleted)
gao yuan(deleted)
01/31/2012 8:08 PM
post91268
my system will have three net card with pci interface,and a pci-pci-e bridge,and a pci slave device in FPGA.
> Dylan,
> --Armin
Armin Steinhoff
Armin Steinhoff
02/01/2012 1:47 AM
post91273
OK ... then check which PCI devices are sharing its interrupt with other
devices.
The PCI device which needs a minimum of interrupt latency shouln't share
its interrupt.
--Armin
>> Dylan,
>> --Armin
> Networking Drivers
> http://community.qnx.com/sf/go/post91268
gao yuan(deleted)
gao yuan(deleted)
02/06/2012 8:54 PM
post91366
Can you explain detaily?
thanks.
gao yuan(deleted)
gao yuan(deleted)
02/06/2012 9:07 PM
post91367
I try mount two 8139 like this:
1. io-pkt-v4-hc -ptcpip
2. mount -Tio-pkt -opci=0,vid=0x10ec,did=0x8139 devn-rtl.so
3. ifconfig en0 192.168.3.60
4. qconn
5. mount -Tio-pkt -opci=1,vid=0x10ec,did=0x8139 devn-rtl.so
now the shell is almost hang. when i type keyboard, i get severl input on screen shell.
I connect target from development host by qconn.
I can get io-pkt process information, the pic attached.
I can ping target .
From target filesystem navigation windows ,I can see en0 and en1 device in /dev/io-net/ directionary.
anybody can tell me the reason.
Hugh Brown
Hugh Brown
02/07/2012 7:45 AM
post91380
Please try the following:
slay io-pkt-v4-hc dhcp.client inetd
io-pkt-v4-hc -drtl
ifconfig en0 .........
Does that work? If not, please post the output of 'pidin' and 'pidin irq'.
Hugh Brown
1001 Farrar Rd.,
>4. qconn
>screen shell.
>I can ping target .
>Networking Drivers
>http://community.qnx.com/sf/go/post91367
gao yuan(deleted)
gao yuan(deleted)
02/06/2012 9:09 PM
post91368
can you explain detaily.
thanks.
> Regards
> --Armin
> > Hi:
> > thanks.
> > dylan.
> > Networking Drivers
gao yuan(deleted)
gao yuan(deleted)
02/06/2012 9:11 PM
post91369
thanks.
> Regards
> --Armin
> > Hi:
> > thanks.
> > dylan.
> > Networking Drivers
