Forum Topic - Writing a network driver: Page 1 of 2 (41 Items)
Hello all,
I hope I'm not making a mistake by asking some help here...
I'm currently working on a Qnx 6.5.0 system and I need to use a Wi-Fi client device (RedPine RS 9110-N-11-02 ) ...so I
need to develop a driver so to be abble to make it work...
Except that I don't have any example or sample code to have a basis to develop my driver (it is the first time I have to
 develop such a thing so it's kind of intimidating !)
Is there anyone who can enlighten me ...please ?
Paul
Re: Writing a network driver
I have attached a sample outline of an io-pkt network driver.
Hugh Brown
QNX Software Systems Limited
175 Terence Matthews Crescent,
Ottawa. ON. K2M 1W8.
Telephone: 613-591-0931
On 11-09-27 12:00 PM, "Thilloy Paul" <community-noreply@qnx.com> wrote:
>Hello all,
>client device (RedPine RS 9110-N-11-02 ) ...so I need to develop a driver
>develop my driver (it is the first time I have to develop such a thing so
>Regards,
>Paul
>Networking Drivers
>http://community.qnx.com/sf/go/post89096
Attachment: Text sample.tar.gz 20.61 KB
Hi Hugh,
Thanks a lot for your answer !
I'm reading the sample... and sorry to ask more but...do you have a documentation going with the code please ?
I'm not sure to understand every line in the code and what I should modify/implement to make my own driver.
And if this is for io-pkt...I assume this code is for Qnx 6.5.0 ?
Again thanks for your help and thanks in advance for any further help !
Paul
Here is all we have as far as documentation is concerned. Yes, io-pkt is
6.5.0.
Hugh.
Hugh Brown
On 11-09-28 10:34 AM, "Thilloy Paul" <community-noreply@qnx.com> wrote:
>Hi Hugh,
>Regards,
>Paul
>Networking Drivers
>http://community.qnx.com/sf/go/post89116
Attachment: Text native_drvr.txt 15.51 KB
So the doc covering how to write a native drive mentionned in the Momentics Help (part " Network Drivers" ) : /trunk/lib
/io-pkt/sys/dev_qnx/doc is not available ?
That is what I sent you.
Hugh Brown
>/trunk/lib/io-pkt/sys/dev_qnx/doc is not available ?
>Networking Drivers
>http://community.qnx.com/sf/go/post89119
Oh ok...Thank you.
I was missleaded in the Momentics Help by :
A tech note covering how to write a native driver is available in the source tree under /trunk/lib/io-pkt/sys/dev_qnx/
doc. Sample driver code is also available under the /trunk/lib/io-pkt/sys/dev_qnx/sample directory.
Sorry if I bothered you.
Other question... if I want to compile sam.c in order to make my own .so... I should then compile the whole project ? Do
 you know where I can find the source code ?
Paul
Does a "make" from the sample directory not work?
Hugh Brown
On 11-09-28 11:16 AM, "Thilloy Paul" <community-noreply@qnx.com> wrote:
>Oh ok...Thank you.
>source tree under /trunk/lib/io-pkt/sys/dev_qnx/doc. Sample driver code
>directory.
>.so... I should then compile the whole project ? Do you know where I can
>Regards,
>Paul
>Networking Drivers
>http://community.qnx.com/sf/go/post89121
Actually I have several errors...
- Momentics cannot find definition of IRUPT_PRIO_DEFAULT ...I searched but nothing so far...
- same problem on ieee80211com
- As well as other functions are marked as not implemented ( IFQ_SET_READY ; if_attach ; ether_ifattach ...)
>>>ieee80211com
Remember, io-pkt is a netBSD stack - not original with QNX.  You will find this definition (an probably others you
require) in...
http://ftp.riken.jp/NetBSD/NetBSD-release-5-0/src/sys/net80211/
IRUPT_PRIO_DEFAULT is defined as -1.
Look in /usr/include. IRUPT_PRIO_DEFAULT is defined in nw_intr.h. Do a
search for the other missing definitions.
Hugh Brown
>Networking Drivers
>http://community.qnx.com/sf/go/post89142
I've just started the process of trying to port a driver for a Redpine radio module to QNX, so I've found this thread to
 be very useful. I've been reading thru the guide and comparing it to what's in the sam.c file, and I've come up with
the first of what will probably be several questions.
At about line 45 of sam.c is the declaration of the sam_syms array of type nw_dll_syms. The comment just before this
declaration in sam.c says "This is what gets specified in the stack's dl.c". Does this mean I have to add this
declaration to the dl.c file in the io-pkt source code, and rebuild the io-pkt stack?
Thanks for any clarification you can provide!
Greg Ludewig
No, you don't have to re-compile the io-pkt stack. This entry is used by
io-pkt when it loads you driver as a dll.
Hugh Brown
1001 Farrar Rd.,
Ottawa. ON. K2K 0B3.
>radio module to QNX, so I've found this thread to be very useful. I've
>and I've come up with the first of what will probably be several
>questions.
>type nw_dll_syms. The comment just before this declaration in sam.c says
>to add this declaration to the dl.c file in the io-pkt source code, and
>Greg Ludewig
>Networking Drivers
>http://community.qnx.com/sf/go/post91398
OK, thanks. I was hoping it worked something like that.
So, I'm trying to compile the example project (sam.c) and I'm running into a few problems. I've been adding additional
header files (such as the nw_intr.h as mentioned above) and that takes care of some of them. I had to remove the '#ifdef
 _KERNEL' around the definition of ieee80211com in ieee80211_var.h in order for the compiler to find it. Currently I'm
stuck on the CFATTACH_DECL code at around line 75 in sam.c.
CFATTACH_DECL(sam,
	sizeof(struct sam_dev),
	NULL,
	sam_attach,
	sam_detach,
	NULL);
The compiler generates an error that says: 'error: 'sam' undeclared here (not in a function)' as well as a warning about
 implicit declaration of function '__STRING'. I can see that CFATTACH_DECL is defined in the device.h header in usr/
include/io-pkt/sys, and that header is being included, but I can't figure out how to make the error about 'sam' being
undeclared go away.
You need __STRING; should be in <sys/cdefs.h>.
And you should have _KERNEL defined for a driver
that gets loaded in io-pkt.
ifdef _KERNEL' around the definition of ieee80211com in ieee80211_var.h in order for the compiler to find it. Currently
I'm stuck on the CFATTACH_DECL code at around line 75 in sam.c.
> CFATTACH_DECL(sam,
> 	NULL,
> 	sam_attach,
> 	sam_detach,
> 	NULL);
about implicit declaration of function '__STRING'. I can see that CFATTACH_DECL is defined in the device.h header in usr
/include/io-pkt/sys, and that header is being included, but I can't figure out how to make the error about 'sam' being
undeclared go away.
> Networking Drivers
> http://community.qnx.com/sf/go/post91415
Hugh Brown
1001 Farrar Rd.,
>into a few problems. I've been adding additional header files (such as
>had to remove the '#ifdef _KERNEL' around the definition of ieee80211com
>CFATTACH_DECL(sam,
>	NULL,
>	sam_attach,
>	sam_detach,
>	NULL);
>(not in a function)' as well as a warning about implicit declaration of
>device.h header in usr/include/io-pkt/sys, and that header is being
>undeclared go away.
>Networking Drivers
Again, thanks for the help, I really appreciate it.
I've tried including sys/cdefs.h. I still get the warning about __STRING, and the error about 'sam' being undeclared
still exists.
I had previously tried adding -D_KERNEL to the command line (by adding it to the Definitions line on the Compiler tab of
 the project properties). When I do this, I get dozens, if not hundreds, of compile errors in system include files, such
 as ieee80211_var.h.
Is this example driver not meant to built in the IDE for QNX 6.5.0?
Also, I have one other question. Around the sam_syms definition I've included below is a #ifdef VARIANT_a. The compiler
automatically defines VARIANT_a if a set the project to be a static library. But I thought the driver was supposed to be
 a DLL. I assume that means it should be a .so type. Why isn't this a #ifdef VARIANT_so instead?
#ifdef VARIANT_a
#include <io-pkt/nw_dl.h>
/* This is what gets specified in the stack's dl.c */
struct nw_dll_syms sam_syms[] = {
        {"iopkt_drvr_entry", &IOPKT_DRVR_ENTRY_SYM(sam)},
        {NULL, NULL}
#endif
Greg
still exists.
It's there.  You'll have to look at the preprocessed file to see
why you're not seeing it.
of the project properties). When I do this, I get dozens, if not hundreds, of compile errors in system include files,
such as ieee80211_var.h.
compiler automatically defines VARIANT_a if a set the project to be a static library. But I thought the driver was
supposed to be a DLL. I assume that means it should be a .so type. Why isn't this a #ifdef VARIANT_so instead?
Don't use a static library project.
> #ifdef VARIANT_a
>         {NULL, NULL}
> #endif
> Greg
> Networking Drivers
> http://community.qnx.com/sf/go/post91444
See the comments in-line.
Hugh Brown
1001 Farrar Rd.,
>and the error about 'sam' being undeclared still exists.
HB: It's there.  You'll have to look at the preprocessed file to see why
>to the Definitions line on the Compiler tab of the project properties).
>system include files, such as ieee80211_var.h.
>included below is a #ifdef VARIANT_a. The compiler automatically defines
>driver was supposed to be a DLL. I assume that means it should be a .so
HB: Don't use a static library project.
>#ifdef VARIANT_a
>        {NULL, NULL}
>#endif
>Greg
>Networking Drivers
Thanks again for all the help on this.
I've managed to get sam.c to compile, although I had to pull some definitions out of system include files and put them
in a separate file to make it work. Like I said before, if I define _KERNEL, I get lots of compile errors. Do you have
any idea what I'm doing wrong that's causing this? If I collect the definitions I need in a separate file, I get around
the errors, but I am wondering if there are any other flags I should have defined (such as QNXNTO or ALTQ, for example)
for a network driver.
I also have another basic question. The driver I'm trying to port is a Linux driver, and it references the Linux
net_device struct alot. I'm assuming the closest thing to the Linux net_device struct in QNX is the device struct in the
 io-pkt/sys/device.h include file. Does anyone know if that's the correct structure I should be using?
If you have the source presumably you have the makefiles?
A straight 'make' should build it; otherwise, this works
for me on 6.5
# qcc -shared -Wl,-Bsymbolic -o devnp-sample.so -I /usr/include/io-pkt/ -D_KERNEL sam.c
No idea on that one.  Try starting with a BSD based driver
if possible.
Please see comments below.
Hugh Brown
1001 Farrar Rd.,
>definitions out of system include files and put them in a separate file
>compile errors. Do you have any idea what I'm doing wrong that's causing
>around the errors, but I am wondering if there are any other flags I
>should have defined (such as QNXNTO or ALTQ, for example) for a network
>driver.
for me on 6.5
-D_KERNEL sam.c
>Linux driver, and it references the Linux net_device struct alot. I'm
>device struct in the io-pkt/sys/device.h include file. Does anyone know
if possible.
Networking Drivers
http://community.qnx.com/sf/go/post91676
If I unzip the tar file and then do a 'make' I get the following error:
C:\QNXDriver\sample>make
make -j 1 -Carm -fMakefile
make[1]: Entering directory 'C:/QNXDriver/sample/arm'
make -j 1 -Cdll.le -fMakefile
make[2]: Entering directory 'C:/QNXDriver/sample/arm/dll.le'
../../common.mk:18: C:/QNXDriver/prodroot_pkt.mk: No such file or directory
make[2]: *** No rule to make target 'C:/QNXDriver/prodroot_pkt.mk'. Stop.
make[2]: Leaving directory 'C:/QNXDriver/sample/arm/dll.le'
make[1]: *** [all] Error 2
make[1]: Leaving directory 'C:/QNXDriver/sample/arm'
make *** [all] Error 2
If I call qcc directly using the command line you suggest, I get lots of errors in system include files, which is the
same thing I get if I try to build in the IDE with _KERNEL defined.
Like I said, if I copy all of the defines I need from the system headers into a separate file, I can get it to compile
without defining _KERNEL. Do you know if there are other things that don't get included if I don't define _KERNEL that
will result in the driver not working?
Unfortunately, there is no NetBSD based driver for the radio module we're using that I can start my port from.
Thanks again.
Greg
Unfortunately, I don't know what tar file you were given.
Attached is your missing prodroot_pkt.mk.  Not sure if you'll
see other issues.
> Thanks again.
> Greg
> Networking Drivers
> http://community.qnx.com/sf/go/post91734
Attachment: Text prodroot_pkt.mk 704 bytes
Have you tried the following link?
http://www.qnx.com/download/feature.html?programid=9404
Hugh Brown
1001 Farrar Rd.,
>directory
>errors in system include files, which is the same thing I get if I try to
>into a separate file, I can get it to compile without defining _KERNEL.
>define _KERNEL that will result in the driver not working?
>Thanks again.
>Greg
>Networking Drivers
