Forum Topic - WPA and WPA-2 client for io-net for Broadcomm wifi chips: (13 Items)
I know that io-net drivers for the BCM43xx have support for WPA, but where is the wpa client? wpa-2?
Unfortunately, this is needed for io-net for the time being, at least until io-pkt is officially released.
Rich
RE: WPA and WPA-2 client for io-net for Broadcomm wifi chips
Hi Rich:
	Unfortunately, there is no support for WPA / WPA2 in io-net. It's
WEP only exactly for the reason that there is no io-net WPA supplicant.
	Robert.
Sent: Tuesday, February 12, 2008 12:11 PM
To: drivers-networking
Subject: WPA and WPA-2 client for io-net for Broadcomm wifi chips
Rich
Networking Drivers
http://community.qnx.com/sf/go/post4939
Re: RE: WPA and WPA-2 client for io-net for Broadcomm wifi chips
Robert -
The QNX 6.3.2 release notes indicate WPA is supported with Broadcom - is this an error?
<http://www.qnx.org/developers/docs/6.3.2/momentics/release_notes/rel_6.3
.2.html>
- Dan
RE: RE: WPA and WPA-2 client for io-net for Broadcomm wifi chips
The Broadcom driver has a built-in WPA supplicant.
Hugh.
Sent: Tuesday, February 12, 2008 1:00 PM
Subject: Re: RE: WPA and WPA-2 client for io-net for Broadcomm wifi chips
Robert -
this an error?
.2.html>
- Dan
Networking Drivers
http://community.qnx.com/sf/go/post4945
I stand (well... sit) corrected.  That's what I get for not double checking
first :>.
	Thanks Hugh,
		Robert.
Sent: Tuesday, February 12, 2008 1:10 PM
Subject: RE: RE: WPA and WPA-2 client for io-net for Broadcomm wifi chips
Hugh.
Robert -
this an error?
.2.html>
- Dan
Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post4946
Re: RE: RE: WPA and WPA-2 client for io-net for Broadcomm wifi chips
How can I configure the builtin WPA supplicant?  I don't see it referenced in the devn docs.
<http://www.qnx.org/developers/docs/6.3.2/neutrino/utilities/d/devn-bcm43xx.so.html>;
Dan
RE: RE: RE: WPA and WPA-2 client for io-net for Broadcomm wifi ch ips
All the parameters for the WPA supplicant are passed on the command line.
What exactly do you want to configure?
Sent: Tuesday, February 12, 2008 1:29 PM
Subject: Re: RE: RE: WPA and WPA-2 client for io-net for Broadcomm wifi
chips
in the devn docs.
so.html>
Dan
Networking Drivers
http://community.qnx.com/sf/go/post4948
Re: RE: RE: RE: WPA and WPA-2 client for io-net for Broadcomm wifi ch ips
1. the driver needs to be configured and compiled with WPA turned on;
2. I think QNX has ported the BCM wireless interface wlu and can be accessed by running bcm_wlu from command line; (by
running it without any parameters, you got the help menu);
-Shannon
Rich Moore started this thread on my behalf - let me restate what I'm trying to do and maybe that will clear things up.
We are using QNX 6.3.2 with io-net (not io-pkt).  We want to use a Broadcomm WiFi card. WPA is required for the customer
 application.
So, my questions are:
Is WPA compiled into the devn-bcm43xx binary distributed with QNX 6.3.2?
If so, where can I find documentation on how to turn on WPA and config it?
RE: RE: RE: RE: WPA and WPA-2 client for io-net for Broadcomm wif i ch
Yes, the driver is compiled with WPA. If you do a 'use
/lib/dll/devn-bcm43xx.so', it will give you the necessary information to
configure WPA.
Sent: Tuesday, February 12, 2008 3:33 PM
Subject: Re: RE: RE: RE: WPA and WPA-2 client for io-net for Broadcomm wifi
ch
WiFi card. WPA is required for the customer application.
Networking Drivers
http://community.qnx.com/sf/go/post4972
Re: RE: RE: RE: RE: WPA and WPA-2 client for io-net for Broadcomm wif
Thanks Hugh - that's exactly what I was looking for
- Dan
Just out of curious -- does the BCM driver wpa support WPA enterprise mode?
As far as I know it only support up to PSK mode...
Shannon
RE: RE: RE: RE: RE: WPA and WPA-2 client for io-net for Broadcomm wif
No, the Broadcom driver doesn't support enterprise mode.
Sent: Tuesday, February 12, 2008 4:38 PM
Subject: Re: RE: RE: RE: RE: WPA and WPA-2 client for io-net for Broadcomm
wif
Shannon
Networking Drivers
http://community.qnx.com/sf/go/post4980
