Forum Topic - i82554 on AMD-Board: (5 Items)
i82554 on AMD-Board
According to QNX 6.3.0 Service Pack 3 Network Drivers Patch (Patch ID 685) Release Notes the following Ethernet-
Controller is supported by
devn-i82544.so
NAME=devn-i82544.so
DATE=2007/08/30-14:47:03-EDT
VERSION=630SP3-685
#pci -v
Class = Network (Ethernet)
Vendor ID = 8086h, Intel Corporation
Device ID = 10b9h, Unknown Unknown
This  PCI-Express-Adapter doesn't work on an AMD-Motherboard (Gigabyte GA-M61P-S3).
io-net can be started with devn-i82554.so and a ip-address is configurable:
io-net -di82544 verbose=4 -ptcpip &
ifconfig en0 172.16.205.4
# ifconfig
en0: flags=8c43<UP,BROADCAST,RUNNING,OACTIVE,SIMPLEX,MULTICAST> mtu 1500
capabilities=7<IP4CSUM,TCP4CSUM,UDP4CSUM>
enabled=0<>
address: 00:1b:21:05:2b:2c
inet 172.16.205.4 netmask 0xff000000 broadcast 172.255.255.255
But I can't get a connection (Link up missing):
#sloginfo
Feb 01 11:42:45 5 10 0 devn-i82544: *not* running in PCI-X mode
Feb 01 11:42:45 5 10 0 devn-i82544: found internal Copper PHY at address 1
Feb 01 11:42:45 5 14 0 tcpip starting
Feb 01 11:42:45 3 14 0 Using pseudo random generator. See "random" option
Feb 01 11:42:47 5 10 0 INTEL 82544 Gigabit (Copper)
Feb 01 11:42:47 5 10 0 Vendor .............. 0x8086
Feb 01 11:42:47 5 10 0 Device .............. 0x10b9
Feb 01 11:42:47 5 10 0 Revision ............ 0x0
Feb 01 11:42:47 5 10 0 Memory base ......... 0xf3020000
Feb 01 11:42:47 5 10 0 Interrupt ........... 0xa
Feb 01 11:42:47 5 10 0 MAC address ......... 001b21 052b2c
Feb 01 11:42:47 5 14 0 tcpip starting
Feb 01 11:42:47 3 14 0 Using pseudo random generator. See "random" option
#nicinfo
INTEL 82544 Gigabit (Copper) Ethernet Controller
Physical Node ID ........................... 001B21 052B2C
Current Physical Node ID ................... 001B21 052B2C
Current Operation Rate ..................... Unknown
Active Interface Type ...................... MII
Active PHY address ....................... 0
Maximum Transmittable data Unit ............ 1514
Maximum Receivable data Unit ............... 0
Hardware Interrupt ......................... 0xa
Memory Aperture ............................ 0xf3020000 - 0xf303ffff
Packets Transmitted OK ..................... 1
Bytes Transmitted OK ....................... 64
Broadcast Packets Transmitted OK ........... 1
Multicast Packets Transmitted OK ........... 0
Memory Allocation Failures on Transmit ..... 0
Packets Received OK ........................ 438
Bytes Received OK .......................... 37380
Broadcast Packets Received OK .............. 428
Multicast Packets Received OK .............. 10
Memory Allocation Failures on Receive ...... 0
Single Collisions on Transmit .............. 0
Deferred Transmits ......................... 0
Late Collision on Transmit errors .......... 0
Transmits aborted (excessive collisions) ... 0
No Carrier on Transmit ..................... 0
Receive Alignment errors ................... 0
Received packets with CRC errors ........... 0
Packets Dropped on receive ................. 46232
Could it be that the  Nvidia-Chip (MCP61) isn't supported ?
Some other AMD board with a Nvidia-Chip (CK804) works.
#pci -v
Class = Bridge (PCI/PCI)
Vendor ID = 10deh, nVidia Corporation
Device ID = 3e9h, Unknown Unknown
Jeevan
RE: i82554 on AMD-Board
The fact that the adapter is recognized means that the device ID is in the
driver, but for some reason the driver doesn't seem to be working with this
chipset. We don't have this device ID here. I just added it to the driver,
assuming that it would work. Obviously not! Is this a separate adapter or is
it on the motherboard? If it is a separate adapter, please let me have the
exact model number.
Thanks, Hugh.
Sent: Tuesday, February 12, 2008 5:03 AM
To: drivers-networking
Subject: i82554 on AMD-Board
Release Notes the following Ethernet- Controller is supported by
devn-i82544.so
NAME=devn-i82544.so
VERSION=630SP3-685
#pci -v
GA-M61P-S3).
# ifconfig
enabled=0<>
#sloginfo
#nicinfo
#pci -v
Class = Bridge (PCI/PCI)...
Re: RE: i82554 on AMD-Board
> The fact that the adapter is recognized means that the device ID is in >the driver, but for some reason the driver
doesn't seem to be working >with this chipset. We don't have this device ID here. I just added it to >the driver,
assuming that it would work. Obviously not! Is this a >separate adapter or is it on the motherboard? If it is a separate
 >adapter, please let me have  the exact model number.
Thank You Hugh.
It is Onboard. Gigabyte Motherboard ga-m61p-s3 .
Jeevan
RE: RE: i82554 on AMD-Board
Is this a customer's board or does it belong to QNX? Would it be possible to
send me this board?
Thanks, Hugh.
Sent: Tuesday, February 12, 2008 9:47 AM
Subject: Re: RE: i82554 on AMD-Board
>the driver, but for some reason the driver doesn't seem to be working >with
driver,  assuming that it would work. Obviously not! Is this a >separate
adapter or is it on the motherboard? If it is a separate >adapter, please
Thank You Hugh.
Jeevan
Networking Drivers
http://community.qnx.com/sf/go/post4928
My apologies! I do have one of these adapters and the driver works just
fine.
Hugh.
devn-i82544.so
NAME=devn-i82544.so
VERSION=630SP3-685
#pci -v
GA-M61P-S3).
# ifconfig
enabled=0<>
#sloginfo
#nicinfo
#pci -v
Jeevan
Networking Drivers
http://community.qnx.com/sf/go/post4915
