Forum Topic - devnp interrupt handler for driver: (2 Items)
I have an ethernet driver for a new arm Cortex A8 part and without the interrupts, the driver works pretty well. I added
 a callout function to "poll" for the received buffers. With this, I can use qconn to download and debug a program, turn
 on kernel instrumentation and upload the data etc. It seems to work like it is supposed to.
If I turn on interrupts, I lose everything. The serial port completely locks up and I have to reboot the system. I am
assuming the interrupt handler is doing something it is not supposed but it is just a guess.
I modeled my driver after the source for a devnp driver for a different part. I tried to keep the qnx things the same
but I probably missed something.
The interrupt driver does not do much but I am wondering what the significance of all the entries in nicinfo_t are. Is
this explained in any documentation? In particular, what is the use of io_windows and mem_windows? The driver I used as
a template used io_windows but did not use mem_windows. Maybe I need to but a manual would be nice.
Is there any documentation for the calls like interrupt_queue?
Thanks.
Re: devnp interrupt handler for driver
There are 2 levels of interrupt service routine. The first is the actual
interrupt service routine that must turn off the reason for the interrupt.
This routine then calls interrupt_queue to queue the interrupt to io-pkt.
io-pkt then calls your second level interrupt service routine which handles
the interrupt processing eg. receive a message. This routine must then
return a positive value to io-pkt to indicate that the interrupt has been
handled.
> interrupts, the driver works pretty well. I added a callout function to "poll"
> program, turn on kernel instrumentation and upload the data etc. It seems to
> up and I have to reboot the system. I am assuming the interrupt handler is
> I tried to keep the qnx things the same but I probably missed something.
> of all the entries in nicinfo_t are. Is this explained in any documentation?
> used as a template used io_windows but did not use mem_windows. Maybe I need
> Thanks.
> Networking Drivers
> http://community.qnx.com/sf/go/post83667
Kanata, Ontario, Canada.
K2M 1W8
