Forum Topic - Should an io-pkt driver call its _start function in transmission complete interrupt?: (10 Items)
Dear forum,
altq(9) [1] manual says: "A driver is supposed to call if_start() from transmission complete interrupts in order to
trigger the next dequeue."
In our driver (or any driver), there's a possibility TX can not be done right now (no buffer descriptors etc.) and then
the networking stack will call us again sometime to retry.
Should a driver call its own start() function on receiving a transmission complete interrupt to dequeue and process the
next available packet, or should it wait for the stack to decide when to call the driver's start() the next time?
Max
[1] http://www.openbsd.org/cgi-bin/man.cgi?query=altq
Re: Should an io-pkt driver call its _start function in transmission complete interrupt?
As a rule, we don¹t enable transmit complete interrupts in our drivers.
There are 2 ways to reap transmitted packets from the driver, by either
reaping completed packets on the next transmit operation or by scheduling a
1 second timer that calls the transmit reap routine.
On 11-02-27 9:16 AM, "Max Timchenko" <community-noreply@qnx.com> wrote:
> Dear forum,
> transmission complete interrupts in order to trigger the next dequeue."
> now (no buffer descriptors etc.) and then the networking stack will call us
> complete interrupt to dequeue and process the next available packet, or should
> time?
> Thanks,
> Max
> Networking Drivers
> http://community.qnx.com/sf/go/post83559
Kanata, Ontario, Canada.
K2M 1W8
Hi Hugh,
My reason for the question is not to reap transmitted packets, but to retry a previous transmit that failed due to lack
of buffers for example - I've noticed that the stack seems to not call the driver back on its own until another packet
is transmitted to the stack.
In case of low-rate UDP packets, for example, if one packet was not transmitted because of lack of buffers it will not
get retried until the next packet is sent to the stack, which can be a while.
I’m no TCP expert, but AFAIK it is up to the application sending the UDP
packets that must implement re-transmission. I don’t know of any way to
“kick” the stack to make it re-transmit a packet. Maybe somebody with more
TCP/UDP experience can answer this.
On 11-03-06 3:14 AM, "Max Timchenko" <community-noreply@qnx.com> wrote:
> Hi Hugh,
> previous transmit that failed due to lack of buffers for example - I've
> another packet is transmitted to the stack.
> transmitted because of lack of buffers it will not get retried until the next
> Networking Drivers
> http://community.qnx.com/sf/go/post83777
K2M 1W8
The discussion is on the io-pkt level, below TCP/IP - we're dealing with Ethernet frames stored in mbufs and queued for
transmission. If a stack calls the driver's start() handler and the driver does not dequeue a mbuf, what happens to the
mbuf?
Your reply can be understood to mean the network stack will discard the mbuf if the driver does not accept it, thus
dropping the frame with the UDP/TCP packet contained in it - is that correct, or will the network stack keep the mbuf in
 the interface's queue and try to give it to the driver on the next call to its start() handler?
And, if the mbuf is saved, what is the event that causes the io-pkt to call the driver's start() handler again? My
current guess is there's no timer and only a transmission of another packet by the application will cause the stack to
call the driver's start() handler.
Thanks for your patience,
Max
Which network driver are you using?
On 11-03-07 9:41 AM, "Max Timchenko" <community-noreply@qnx.com> wrote:
>> > I¹m no TCP expert, but AFAIK it is up to the application sending the UDP
>> > packets that must implement re-transmission. I don¹t know of any way to
>> > ³kick² the stack to make it re-transmit a packet. Maybe somebody with more
> Ethernet frames stored in mbufs and queued for transmission. If a stack calls
> happens to the mbuf?
> if the driver does not accept it, thus dropping the frame with the UDP/TCP
> mbuf in the interface's queue and try to give it to the driver on the next
> the driver's start() handler again? My current guess is there's no timer and
> to call the driver's start() handler.
> Max
> Networking Drivers
> http://community.qnx.com/sf/go/post83785
K2M 1W8
I'm writing a new one. This question could be of interest to anyone adding a new network driver to QNX...
(if you want to know about the specific project, ask Fred Plante)
Max
HereŒs the response I got from our stack expert.
There's two levels here: the if_snd Q and then the driver.
If the if_start() callout returns without emptying the Q,
presumably the driver is out of resources.  What happens
next depends on the driver.  If it does nothing, then
yes we will only call the if_start() callout on next packet.
If it looks for a tx done interrupt or something it may
poke itself into action.  This is what the ifp->if_flags_tx
IFF_OACTIVE flag is a hint for.  It's supposed to mean the
driver is waiting for a tx done interrupt (or something
to wake it up when it will retry tx).  While that's set
the stack won't recall the if_start() callout.
> Thanks,
> Max
> Networking Drivers
> http://community.qnx.com/sf/go/post83792
K2M 1W8
RE: Should an io-pkt driver call its _start function in transmission complete interrupt?
Frame re-transmit is the responsibility of the communication protocol, such as FTP, and not part of the device driver.
If you start to implement re-transmit in the device driver, you may mess up the protocol.
From: Hugh Brown [mailto:community-noreply@qnx.com]
Sent: March-07-11 11:04 AM
To: drivers-networking
Subject: Re: Should an io-pkt driver call its _start function in transmission complete interrupt?
> Thanks,
> Max
> Networking Drivers
K2M 1W8
Networking Drivers
http://community.qnx.com/sf/go/post83793
This is the means by which the driver flushes out its
tx queue, not a retransmit.  Retransmit will happen
as it normally would if the tx queue overflows and a
packet is actually dropped.
> > Thanks,
> > Max
> > Networking Drivers
> K2M 1W8
> Networking Drivers
> Networking Drivers
> http://community.qnx.com/sf/go/post83837
