Eli Kozikaro
devn-asix.so and devnp-axe.so are not working with AX88772B
Eli Kozikaro
02/09/2011 2:06 PM
post83048
AX88772B is the latest offering from ASIX for a usb to 10/100 ethernet chip.
This chip is smaller and has extended temperature range. We would like to incorporate it in our product that is based
on QNX 6.5.0
QNX has two drivers that support asix chips but I tried both with an AX88772B dongle and none work.
Are there any command line options what will make this work?
Here is what I have now:
io-pkt was run with -ptcpip option
After I insert the dongle I issue
mount -Tio-pkt /lib/dll/devn-asix.so
Here is what usb -v shows
USB 1 (EHCI) v1.10, v1.01 DDK, v1.01 HCD
Control, Interrupt, Bulk(SG), Isoch(Stream), High speed
Device Address : 1
Upstream Host Controller : 1
Upstream Device Address : 0
Upstream Port : 0
Upstream Port Speed : High
Vendor : 0x0b95 (ASIX Elec. Corp.)
Product : 0x772b (AX88772B)
Device Release : r0.01
Class : 0xff (Vendor-specific)
Subclass : 0xff
Protocol : 0x00
Max PacketSize0 : 64
Configurations : 1
Configuration : 1 (0)
Attributes : 0xa0 (Bus-powered, Remote-wakeup)
Max Power : 200 mA
