Forum Topic - Intel 82579LM : Page 1 of 4 (83 Items)
Intel 82579LM
Does Intel 82579LM ethernet controller work with QNX 6.5.0?
Best regards,
Steffen
Re: Intel 82579LM
From what I can tell, the 82579 is a PHY. What is the PCI device ID?
> Best regards,
> Steffen
> Networking Drivers
> http://community.qnx.com/sf/go/post82679
Kanata, Ontario, Canada.
K2M 1W8
Re: Intel 82579LM
Vendor ID: 0x8086
Device ID: 0x1502
Re: Intel 82579LM
No, this device ID is not currently in our driver. I will have to add it
some time and send you an update.
On 11-01-28 4:09 AM, "Steffen Brühl" <community-noreply@qnx.com> wrote:
> Vendor ID: 0x8086
> Device ID: 0x1502
> Networking Drivers
> http://community.qnx.com/sf/go/post82708
K2M 1W8
Re: Intel 82579LM
What do you think about the time schedule to add this?
Re: Intel 82579LM
I¹ll try for today, but I can¹t promise anything. You will have to do the
testing, as I don¹t have that chipset here.
> Networking Drivers
> http://community.qnx.com/sf/go/post82715
K2M 1W8
Re: Intel 82579LM
Here is an experimental driver for you to test. Please let me know how it
goes.
Thanks, Hugh.
> Networking Drivers
K2M 1W8
Attachment: Text devnp-e1000.so 231.49 KB
Re: Intel 82579LM
Have you had a chance to test this driver? Please let me know.
Thanks, Hugh.
> Networking Drivers
K2M 1W8
Re: Intel 82579LM
Thank you very much for the driver. As soon I have the new mainboard I will test the driver and update you.
Steffen
Re: Intel 82579LM
Hello Hugh,
got an SlotCPU with a Q67 Chipset and a vid=0x8086,did=0x1502 Network Interface (Intel 82579 PHY) and tested your posted
 driver. Unfortunately it does not work )-:
here are the steps I tried, to get it working:
Renamed it to devnp_e1000_2.so and put it into /lib/dll
sloginfo -c
io-pkt-v4-hc -i2 -ptcpip prefix=/alt -de1000_2 verbose=10,pci=0,did=0x1502
sloginfo
May 17 19:07:06    5    14     0 tcpip starting
May 17 19:07:06    3    14     0 Using pseudo random generator.  See "random" option
May 17 19:07:06    5    14     0 initializing IPsec... done
May 17 19:07:06    5    14     0 IPsec: Initialized Security Association Processing.
May 17 19:07:06    6    10     0 e1000_set_mac_type
May 17 19:07:06    6    10     0 e1000_init_mac_ops_generic
May 17 19:07:06    6    10     0 e1000_init_phy_ops_generic
May 17 19:07:06    6    10     0 e1000_init_nvm_ops_generic
May 17 19:07:06    6    10     0 ERROR: Flash registers not mapped
May 17 19:07:06    6    10     0 NVM Initialization Error
May 17 19:07:06    6    10     0 Hardware Initialization Failure
May 17 19:07:06    2    14     0 Unable to init devnp-e1000_2.so: No such device
as far as pci -vv tells me, the parameter should be ok:
Class          = Network (Ethernet)
Device ID      = 1502h, Unknown Unknown
PCI index      = 0h
Class Codes    = 020000h
Revision ID    = 5h
Bus number     = 0
Device number  = 25
Function num   = 0
Status Reg     = 10h
Command Reg    = 7h
        I/O space access enabled
        Memory space access enabled
        Bus Master enabled
        Special Cycle operations ignored
        Memory Write and Invalidate disabled
        Palette Snooping disabled
        Parity Error Response disabled
        Data/Address stepping disabled
        SERR# driver disabled
        Fast back-to-back transactions to different agents disabled
        PCI INTx enabled
BIST           = 0h Build-in-self-test not supported
Latency Timer  = 0h
Cache Line Size= 0h
BAR - 0 [Mem]  = fe600000h 32bit length 131072 enabled
BAR - 1 [Mem]  = fe624000h 32bit length 4096 enabled
BAR - 2 [I/O]  = f080h length 32 enabled
Max Lat        = 0ns
Min Gnt        = 0ns
PCI Int Pin    = INT A
Interrupt line = 10
CPU Interrupt  = ah
Capabilities Pointer = c8h
Capability ID        = 1h - Power Management
Capabilities         = c822h - 7002000h
Capability ID        = 5h - Message Signaled Interrupts
Capabilities         = 80h - 0h
Capability ID        = 13h - Unknown
Capabilities         = 306h - 0h
Device Dependent Registers:
0x040:  0000 0000 0000 0000   0000 0000 0000 0000
0x0c0:  0000 0000 0000 0000   01d0 22c8 0020 0007
0x0d0:  05e0 8000 0000 0000   0000 0000 0000 0000
0x0e0:  1300 0603 0000 0000   0000 0000 0000 0000
0x0f0:  0000 0000 0000 0000   0000 0000 0000 0000
Is there something wrong with the io-pkt call?
Matthias
Re: Intel 82579LM
Please try the attached driver and let me know if it solves the problem.
Thanks, Hugh.
On 11-05-17 11:12 AM, "Matthias Ecker" <community-noreply@qnx.com> wrote:
> Hello Hugh,
> Interface (Intel 82579 PHY) and tested your posted driver. Unfortunately it
> does not work )-:
> sloginfo -c
> sloginfo
> option
> Processing.
> device
> PCI index      = 0h
> Revision ID    = 5h
> Bus number     = 0
> Device number  = 25
> Function num   = 0
> Status Reg     = 10h
> Command Reg    = 7h
>         Bus Master enabled
>         PCI INTx enabled
> Latency Timer  = 0h
> Cache Line Size= 0h
> Max Lat        = 0ns
> Min Gnt        = 0ns
> PCI Int Pin    = INT A
> Interrupt line = 10
> CPU Interrupt  = ah
> Thanks,
> Matthias
> Networking...
Attachment: Text devnp-e1000.so 237.57 KB
Re: Intel 82579LM
this one is better, though not perfect. There is a wm0 device and sloginfo shows, that it is the device with did 0x1502.
But there seems to be a problem with the link detection. I connected a cable, did SOCK=/alt ifconfig wm0 up and ...
ifconfig wm0 ip.
SOCK=/alt ifconfig
wm0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
        capabilities rx=1f<IP4CSUM,TCP4CSUM,UDP4CSUM,TCP6CSUM,UDP6CSUM>
        capabilities tx=7f<IP4CSUM,TCP4CSUM,UDP4CSUM,TCP6CSUM,UDP6CSUM,TSO4,TSO6>
        enabled=0
        address: 88:88:88:88:87:88
        media: Ethernet none
        inet 192.168.70.20 netmask 0xffffff00 broadcast 192.168.70.255
SOCK=/alt nicinfo
wm0:
  INTEL PRO/1000 Gigabit (Copper) Ethernet Controller
  Link is DOWN
  Physical Node ID ........................... 888888 888788
  Current Physical Node ID ................... 888888 888788
  Current Operation Rate ..................... 0 kb/s half-duplex
  Active Interface Type ...................... MII
    Active PHY address ....................... 2
  Maximum Transmittable data Unit ............ 1500
  Maximum Receivable data Unit ............... 1500
  Hardware Interrupt ......................... 0xa
  Memory Aperture ............................ 0xfe600000 - 0xfe61ffff
  Packets Transmitted OK ..................... 0
  Bytes Transmitted OK ....................... 0
  Broadcast Packets Transmitted OK ........... 0
  Multicast Packets Transmitted OK ........... 0
  Memory Allocation Failures on Transmit ..... 0
  Packets Received OK ........................ 0
  Bytes Received OK .......................... 0
  Broadcast Packets Received OK .............. 0
  Multicast Packets Received OK .............. 0
  Memory Allocation Failures on Receive ...... 0
  Single Collisions on Transmit .............. 0
  Multiple Collisions on Transmit ............ 0
  Deferred Transmits ......................... 0
  Late Collision on Transmit errors .......... 0
  Transmits aborted (excessive collisions) ... 0
  Jabber detected ............................ 0
  Receive Alignment errors ................... 0
  Received packets with CRC errors ........... 0
  Packets Dropped on receive ................. 0
  Oversized Packets received ................. 0
  Short packets .............................. 0
  Squelch Test errors ........................ 0
  Invalid Symbol Errors ...................... 0
Matthias
Attachment: Text sloginfo.out 37.06 KB
Re: Intel 82579LM
Please will you run the attached driver as before and send me the sloginfo
output. I have added some debug code.
Thanks, Hugh.
> did SOCK=/alt ifconfig wm0 up and ... ifconfig wm0 ip.
> SOCK=/alt ifconfig
>         capabilities
>         enabled=0
> SOCK=/alt nicinfo
> wm0:
>   Link is DOWN
> Regards,
> Matthias
> Networking Drivers
> http://community.qnx.com/sf/go/post85794
K2M 1W8
Attachment: Text devnp-e1000.so 237.91 KB
Re: Intel 82579LM
no worries... I've attached the sloginfo output.
Matthias
Attachment: Text sloginfo.out2 37.2 KB
Re: Intel 82579LM
Matthias,
Have you tried another O/S on this board and if so, does the Ethernet
interface work correctly with a valid MAC address?
Thanks, Hugh.
> Regards,
> Matthias
> Networking Drivers
> http://community.qnx.com/sf/go/post85828
K2M 1W8
Re: Intel 82579LM
Dear Hugh,
tested ubuntu 11.04 and both network interfaces are ok. Even the one, that qnx doesn't support "out of the box" is
working (ifconfig, ping, telnet)
Matthias
Re: Intel 82579LM
OK, I¹ll have to investigate further. Does Ubuntu get a valid MAC address
from the 1502 interface?
Thanks, Hugh.
On 11-05-18 11:04 AM, "Matthias Ecker" <community-noreply@qnx.com> wrote:
> Dear Hugh,
> doesn't support "out of the box" is working (ifconfig, ping, telnet)
> Regards,
> Matthias
> Networking Drivers
> http://community.qnx.com/sf/go/post85857
K2M 1W8
Re: Intel 82579LM
cant't tell.
is 88:88:88:88:87:88 a valid mac? didn't expect such a continuity...
Re: Intel 82579LM
No, that MAC address is invalid, so if Ubuntu is getting the same MAC
address, then there is a problem with the flash on that board.
On 11-05-18 11:14 AM, "Matthias Ecker" <community-noreply@qnx.com> wrote:
> cant't tell.
> Networking Drivers
> http://community.qnx.com/sf/go/post85860
K2M 1W8
Re: Intel 82579LM
Matthias,
Please will you try the attached driver and see if it makes any difference.
Please send me the sloginfo output once you have tried it.
Many thanks, Hugh.
> cant't tell.
> Networking Drivers
K2M 1W8
Attachment: Text devnp-e1000.so 242.59 KB
Re: Intel 82579LM
Dear Hugh,
no worries! tried it, but it does not make any difference (at least for me): no link detection and no way to ping the
outside.
Thank you for your effort!!
Matthias
Attachment: Text sloginfo.out3 46.87 KB
Re: Intel 82579LM
Matthias,
I didn¹t get the full sloginfo output. Please can you start Œslogger ­s128k¹
and then restart the driver and send me the sloginfo output? Please can you
also attach the full Œpci ­vv¹ output?
Many thanks, Hugh.
On 11-05-19 2:36 AM, "Matthias Ecker" <community-noreply@qnx.com> wrote:
> Dear Hugh,
> no link detection and no way to ping the outside.
> Regards,
> Matthias
> Networking Drivers
> http://community.qnx.com/sf/go/post85907
K2M 1W8
Re: Intel 82579LM
Dear Hugh,
you'll find the requested information attached to this reply. Please let me know if you need any further information.
Matthias
  196  slay slogger
  197  use slogger
  198  slogger -s 1024
  199  io-pkt-v4-hc -i2 -ptcpip prefix=/alt -de1000_5 verbose=10,pci=0,did=0x1502
  200  SOCK=/alt ifconfig wm0 up
  201  SOCK=/alt ifconfig wm0 192.168.70.20
  202  SOCK=/alt ifconfig
  203  sloginfo > sloginfo.out4
  204  pci -vv > pcivv.txt
  205  tar -cvf info.tar sloginfo.out4 pcivv.txt
  206  history
Attachment: Compressed file info.tar 240 KB
Re: Intel 82579LM
I have found a Sandy Bridge board, so will let you know when I have the
network driver working.
Hugh.
On 11-05-19 9:09 AM, "Matthias Ecker" <community-noreply@qnx.com> wrote:
> Dear Hugh,
> Regards,
> Matthias
>   196  slay slogger
>   197  use slogger
>   198  slogger -s 1024
>   206  history
> Networking Drivers
> http://community.qnx.com/sf/go/post85931
K2M 1W8
Re: Intel 82579LM
Matthias,
You will have to speak to Kontron about re-programming the EEPROM on your
board with a correct MAC address. I have been in contact with Intel and the
MAC address that you have on your machine is the default address if no MAC
address is programmed.
I should have an experimental driver ready for you to test either later
today or on Monday.
Thanks, Hugh.
> Dear Hugh,
> Regards,
> Matthias
>   196  slay slogger
>   197  use slogger
>   198  slogger -s 1024
>   206  history
> Networking Drivers
K2M 1W8
