gary anderson
12/17/2010 5:55 PM
post79284
I have a system with two (or more) CPUs. The first (master) CPU is on our building network and the second (slave) CPU is
on a private network implemented over PCI express. I can telnet from the master to the slave and visa-versa where
telnet is invoked from RS-232 console connections to each CPU.
Now I'd like to access the slave CPU from an external computer on the network that the master CPU is connected to. I've
enabled packet filtering on the master by:
mount -Tio-pkt /proc/boot/lsm-pf-v4.so
sysctl -w net.inet.ip.forwarding=1
pfctl -f pf.conf -e
where pf.conf contains:
rdr on wm0 proto tcp from any to \
141.121.191.201 port 2308 -> 10.1.8.108 port 23
141.121.191.201 is the ethernet IP address of the master CPU and 10.1.8.108 is the IP address of the slave CPU.
Now from a PC I can 'telnet 141.121.201 2308' and I get the login prompt for a telnet session on the slave CPU (via the
port redirection). Works fine. Now in the session I execute 'ls' and get the correct directory output.
But, if I execute 'ls -R' I only get one line of output back to the PC. I don't get all the data and I never get the
next telnet console prompt.
If I telnet from the PC to the master CPU and do the same I get all the data so it seems like the packet filtering is
somehow getting hung up.
If I execute 'netstat -a' on the slave CPU I get:
# netstat -a
Active Internet connections (including servers)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 2835 10.1.8.108.telnet 141.121.191.243.63483 ESTABLISHED
which seems to indicate that the data is somehow still in slave CPU buffers.
Any ideas on how to fix or debug this problem? Note that I'm running 6.4.1 code.
Gary
