Forum Topic - Intel 82576 ping doesn't work: (6 Items)
Hi I have a Intel 82576 dual port GB ethernet adapter on my card. I installed QNXv6.4.1 on my board. After installation
i boot and in the network configuration i see two devices wm0 and wm1. I assign IP address and try pinging from my
laptop but the ping doesn't work (request timed out).
I have connected the wm1 interface to my laptop.
the IP address are as follows:
wm1:192.168.0.10 netmask 255.255.255.0
laptop:192.168.0.12 netmask 255.255.255.0
The ping from both sides do not work. The same problem is there with wm0 also. Please find attached the driver logs
which seems to be fine and also the pci dump.
I need to solve this ASAP. If anybody has faced similar issue please provide inpts to solve the issue.
Nagaraj
Attachment: Compressed file debug.zip 5.55 KB
Re: Intel 82576 ping doesn't work
We have a problem with the 82576 right now. I am busy working on updating
the driver.
Hugh.
> QNXv6.4.1 on my board. After installation i boot and in the network
> pinging from my laptop but the ping doesn't work (request timed out).
> Please find attached the driver logs which seems to be fine and also the pci
> dump.
> Regards,
> Nagaraj
> Networking Drivers
> http://community.qnx.com/sf/go/post49258
Kanata, Ontario, Canada.
K2M 1W8
Hi Hugh,
Thanks for the reply. Could you please let us know as to when can we expect an updated driver.
Nagaraj.
Here is an experimental version of the driver to test.
On 10-03-11 9:16 AM, "Nagaraj Salotagi" <community-noreply@qnx.com> wrote:
> Hi Hugh,
> updated driver.
> Regards,
> Nagaraj.
> Networking Drivers
> http://community.qnx.com/sf/go/post49272
K2M 1W8
Attachment: Text devnp-e1000.so 232.16 KB
Hi Hugh,
Thank you for the driver. The driver which you have given works in our boxes.
Nagaraj.
Hi Nagaraj,
Good news!
Thanks, Hugh.
On 10-03-17 2:20 AM, "Nagaraj Salotagi" <community-noreply@qnx.com> wrote:
> Hi Hugh,
> Regards,
> Nagaraj.
> Networking Drivers
> http://community.qnx.com/sf/go/post49694
K2M 1W8
