Forum Topic - How to get network /wifi to work on a Asus EEE1000H: (8 Items)
I've installed QNX 6.4.1 on a Asus EEE1000H, but sound, wired network card and the wireless card (BroadCom BCM 94321MC)
does not work "out of the box".
Is there anybody that have sucessfully installed QNX on a netbook and can give me som hint about how / where to get the
"drivers"
It would be "cool" to have QNX fully working on my netbook
RE: How to get network /wifi to work on a Asus EEE1000H
Can you post the text output of the command
  # pci -v
aboyd
Re: RE: How to get network /wifi to work on a Asus EEE1000H
This is the result of #pci - v
PCI version    = 3.00
Class          = Bridge (Host/PCI)
Device ID      = 27ach,  Mobile 945GME Express Memory Controller Hub
PCI index      = 0h
Class Codes    = 060000h
Revision ID    = 3h
Bus number     = 0
Device number  = 0
Function num   = 0
Status Reg     = 2090h
Command Reg    = 6h
BIST           = 0h Build-in-self-test not supported
Latency Timer  = 0h
Cache Line Size= 0h
Subsystem Vendor ID = 1043h
Subsystem ID        = 8340h
Max Lat        = 0ns
Min Gnt        = 0ns
PCI Int Pin    = NC
Interrupt line = 0
CPU Interrupt  = 0h
Capabilities Pointer = e0h
Capability ID        = 9h - Vendor Specific
Capabilities         = 7109h - a14a2523h
Device ID      = 27aeh,  Mobile 945GME Express Integrated Graphics Controller
PCI index      = 0h
Class Codes    = 030000h
Revision ID    = 3h
Bus number     = 0
Device number  = 2
Function num   = 0
Status Reg     = 90h
Command Reg    = 7h
Header type    = 0h Multi-function
Latency Timer  = 0h
Cache Line Size= 0h
PCI Mem Address = f7f00000h 32bit length 524288 enabled
PCI IO Address  = dc00h length 8 enabled
PCI Mem Address = d0000000h prefetchable 32bit length 268435456 enabled
PCI Mem Address = f7ec0000h 32bit length 262144 enabled
Max Lat        = 0ns
Min Gnt        = 0ns
PCI Int Pin    = INT A
Interrupt line = 5
CPU Interrupt  = 5h
Capabilities Pointer = 90h
Capability ID        = 5h - Message Signaled Interrupts
Capabilities         = 0h - 0h
Capability ID        = 1h - Power Management
Capabilities         = 22h - 0h
Class          = Display (Other)
Device ID      = 27a6h,  Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller
PCI index      = 0h
Class Codes    = 038000h
Revision ID    = 3h
Bus number     = 0
Device number  = 2
Function num   = 1
Status Reg     = 90h
Command Reg    = 7h
Latency Timer  = 0h
Cache Line Size= 0h
PCI Mem Address = f7f80000h 32bit length 524288 enabled
Max Lat        = 0ns
Min Gnt        = 0ns
PCI Int Pin    = NC
Interrupt line = 0
CPU Interrupt  = 0h
Capabilities Pointer = d0h
Class          = Multimedia (RAM)
Device ID      = 27d8h,  82801G (ICH7 Family) High Definition Audio Controller
PCI index      = 0h
Class Codes    = 040300h
Revision ID    = 2h
Bus number     = 0
Device number  = 27
Function num   = 0
Status Reg     = 10h
Command Reg    = 6h
Latency Timer  = 0h
Cache Line Size= 8h un-cacheable
PCI Mem Address = f7eb8000h 64bit length 16384 enabled
Subsystem ID        = 831ah
Max Lat        = 0ns
Min Gnt        = 0ns
PCI Int Pin    = INT A
Interrupt line = 5
CPU Interrupt  = 5h
Capabilities Pointer = 50h
Capabilities         = c842h - 0h
Capabilities         = 80h - 0h
Capability ID        = 10h - PCI Express
Capabilities         = 91h - 0h
Class          = Bridge (PCI/PCI)
Device ID      = 27d0h,  82801G (ICH7 Family) PCI Express Port 1
PCI index      = 0h
Class Codes    = 060400h
Revision ID    = 2h
Bus number     = 0
Device number  = 28
Function num   = 0
Status Reg     = 10h
Command Reg    = 104h
Header type    = 1h Multi-function
BIST     ...
RE: RE: How to get network /wifi to work on a Asus EEE1000H
I saw only one network device:
> Vendor ID = 1969h, Attansic Technology Corp.
> Device ID = 1026h,  L1 Gigabit Ethernet Adapter
I am unfamiliar with this chipset - I don't think
we have a driver for it  :-(
A USB dongle might be the easiest way for you to
get networking.
aboyd
Hacker option:  I see there is a FreeBSD driver for this.
If you are adventurous, you could port that to a NetBSD
driver, which is generally a pretty straight-forward
re-compile for QNX 6.4 io-pkt.
However, I will warn you that the differences between
the BSD source variants can be maddening!  It puzzles
me greatly that the BSD people wish to fracture their
community.
aboyd
Re: RE: RE: How to get network /wifi to work on a Asus EEE1000H
Hello, thank you for the answer, unfortunately i had disabled the wifi, so it was not in the report.  So i have taken
the report ones more.  Can you tell me if there is a driver for the wifi card?
Can you point me to a tutorial, howto make the driver for the network card with help of the BSD?
I have tried QNX some year ago, but i need to learn how  to use  the operating system, can you recommend some learnig
book or place on the net.  I've been looking for some litrature but have'nt find anything yet.
Class          = Network (Other)
Vendor ID      = 14e4h, Broadcom Corporation
Device ID      = 4328h,  BCM4328 802.11a/b/g/n
PCI index      = 0h
Class Codes    = 028000h
Revision ID    = 3h
Bus number     = 1
Device number  = 0
Function num   = 0
Status Reg     = 10h
Command Reg    = 6h
Latency Timer  = 0h
PCI Mem Address = fbefc000h 64bit length 16384 enabled
PCI Mem Address = f6f00000h prefetchable 64bit length 1048576 enabled
Subsystem Vendor ID = 103ch
Subsystem ID        = 1366h
Max Lat        = 0ns
Min Gnt        = 0ns
PCI Int Pin    = INT A
Interrupt line = 11
CPU Interrupt  = bh
Capabilities Pointer = 40h
Capabilities         = 602h - 4000h
Capabilities         = 78h - 4h
Capabilities         = 1h - 8fa0h
Class          = Network (Ethernet)
PCI index      = 0h
Class Codes    = 020000h
Revision ID    = b0h
Bus number     = 3
Device number  = 0
Function num   = 0
Status Reg     = 10h
Command Reg    = 7h
Latency Timer  = 0h
PCI Mem Address = fbfc0000h 64bit length 262144 enabled
PCI IO Address  = ec00h length 128 enabled
Subsystem ID        = 8324h
Max Lat        = 0ns
Min Gnt        = 0ns
PCI Int Pin    = INT A
Interrupt line = 10
CPU Interrupt  = ah
Capabilities         = c002h - 0h
Capabilities         = 1h - 7f85h
Capability ID        = 3h - VPD
Best regard
Sverre J. Bonsaksen
Norway
RE: RE: RE: How to get network /wifi to work on a Asus EEE1000H
I think the correct driver for that family of wifi
chips would be devnp-bcm43xx.so - however looking at
the list of supported DID's for that driver - it's
quite long - I'm not sure if this nic is supported
by default or not by the shipped driver.
In this situation you can pass the DID with a command
line option to the driver - ie "did=0x4328" to see if
you get lucky and they haven't changed the hardware API.
We need to upgrade our BCM43xx wifi source for newer hardware!!
aboyd
Re: How to get network /wifi to work on a Asus EEE1000H
I'm thinking of buying one of these netbooks myself. So if anybody can
recommend one that's got QNX drivers would be great??!?
/P
94321MC) does not work "out of the box".
the "drivers"
> Networking Drivers
> http://community.qnx.com/sf/go/post48341
